3056 Discussions
Intel Media SDK 2016 Installation on Centos 7.2 Kernel 3.10.0.327.22.2.el7.x86_64
Satish_P_
Hello
We are attempting to install Intel Media SDK 2016 on system having following detail but not supported and frequently facing error  like this during second step of installation instruction ./Build......
[rtpl@rtpl MSS]$ ./build_kernel_rpm_CentOS.sh
Error... Not installed intel-linux-media-devel rpm package!
for reference details are here from system analyzer
[root@rtpl Downloads]# python sys_analyzer_linux.py -v
Hardware readiness checks:
 [ OK ] Processor name: Intel(R) Core(TM) i7-5775C CPU @ 3.30GHz
 [ INFO ] Intel Processor
 [ INFO ] Processor brand: Core
 [ INFO ] Processor arch: Broadwell
OS readiness checks:
 [ INFO ] GPU PCI id     : 1622
 [ INFO ] GPU description: BDW GT3 ULT
 [ OK ] GPU visible to OS
 [ INFO ] no nomodeset in GRUB cmdline (good)
 [ INFO ] Linux distro   : CentOS Linux 7.2.1511
 [ INFO ] Linux kernel   : 3.10.0-327.22.2.el7.x86_64
 [ INFO ] glibc version  : 2.17
 [ INFO ] Linux distro suitable for Generic install
 [ INFO ] gcc version    : 4.8.5-4) (>=4.8.2 suggested)
Media Server Studio Install:
 [ OK ] user in video group
 [ OK ] libva.so.1 found
 [ ERROR ] libva not loading Intel iHD
 [ ERROR ] vainfo not reporting codec entry points
 [ INFO ] i915 driver in use by Intel video adapter
 [ ERROR ] no libva include files.  Are Intel components installed?
Component Smoke Tests:
 [ ERROR ] no Media SDK include files.  Are Intel components installed?
 [ ERROR ] no OpenCL include files.  Are Intel components installed?
Media SDK Plugins available:
(for more info see /opt/intel/mediasdk/plugins/plugins.cfg)
 [ ERROR ] no plugins/plugins.cfg.  Are Intel components installed?
is there any limitation for kernel version and Cent 7.2 for media SDK 2016 installation?
Jiandong_Z_Intel
Hi There,
You can found MSS 2016 support CentOS 7.1 in Getting Started Guide - Linux* Installation, CentOS 7.2 will be support in the MSS next release - Intel Media Server Studio 2017. it will coming soon.
Zachary
Satish_P_
ok so we cant use MSS2016 with Centos 7.2 with its default kernel  3.10.0-327.22.2.el7.x86_64 ....but Our Motherboard doesn't allow us to install Centos 7.1 , so for Using Media SDK 2016 Can we downgrade Kernel at Centos 7.2 from its Default Version 327 to 229 which was default Kernel for Cent os 7.1
will this Solution make us able to use MSS2016 over Centos 7.2 ? and reliability and Functionality will not be affected for MSS2016?
Satish P.
