Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
Intel Media SDK AAC Encoder
johnsonliu_
The post from http://software.intel.com/en-us/forums/topic/311820  mentioned that Media SDK 2.0.12.24071 includes
 "Intel Media SDK AAC Encoder". Is this version of Media SDK still available for download for testing ? Or is there any source code
for AAC Encoder ?
Thanks for your help.
Petter_L_Intel
Hi, Yes, Intel Media SDK contains a binary DirectShow AAC encoder filter (source code not available). The filter is provided to enable exploration/prototyping of complete DirectShow pipelines and is not intended to be used in products. Please refer to the SDK EULA for more details. Also, the AAC filter likely does not provide all the features or performance that may be required for production level solution. So, the recommendation for product level solutions is to explore alternative commercial or open AAC filters. Regards, Petter
Tomasz_Z_
Please confirm if it still applies to Intel Media SDK 2014. Is there any form of AAC encoder provided with Intel Media SDK which could be used for commercial purposes?
Tomek
Harshdeep_B_Intel
Currently we don't provide stand alone AAC encoder along with MediaSDK. With MediaSDK 2015 which can downloaded from INDE https://software.intel.com/en-us/intel-inde. where ultimate version has a Audio plugin for Windows which includes the support. Yes, it can be used for commercial purposes.
Tomasz_Z_
Hi Harsh,
Let me clarify my question. Is the AAC encoder from INDE redistributable? Can it be shipped with commercial products?
Tomek
Harshdeep_B_Intel
Yes, if the applicable files are listed in the "redist" file. Then you can distribute those files provided they comply with all the terms and conditions of EULA. If they are not listed, you may not distribute those files.
geneziz
Hi
  Is it possible to use it as DirectShow filter? Or have DirectShow sample like for video encoder/decoder?
  I'm not able to find any samples for Audio part of INDE...
