Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
Intel Media SDK within a locked desktop (session 0)
OTorg
New Contributor III
When we will have access to the GPU decoding/encoding within a locked desktop (from session 0) after all? This will increase the performance of server/terminal applications dramatically. And, therefore, determined the choice of the "right" hardware manufacturer. As far as I know, to date, only nvidia tesla provides such opportunities.
Petter_L_Intel
Thanks for clarifying, I completely understand what it is you are after now.
Unfortunately, as you also point out, we cannot use Media SDK with HW acceleration in a Windows service due to OS restrictions. This is a well known limitation that we do not have control over. We may explore alternative approaches in future releases of the SDK but for now there is nothing we can do.
This subject was also discussed in earlier forum thread, including reference to external forum thread where potential workarounds are discussed.
http://software.intel.com/en-us/forums/showthread.php?t=84258&o=a&s=lr
Petter
Petter_L_Intel
Hi dj_alek,
Can you expand a bit more on your issue. What do you mean by locked desktop? Are you referring to machine that does not have a display attached?
Petter
OTorg
New Contributor III
I mean access to the hardware decoding/encoding/resizing/etc (GPU, not CPU). DirectX layer is used for this purpose.
Hardware DX isn't available at session 0 (services sandbox). Microsoft says: for security reasons - onlyinteractive user (who sees the desktop on a locally mounted display) can access hardware DX. So, need to create separate process on behalf of the interactive user. Furthermore, local desktop must never be locked (via Win+L, for example).
Thus, we have the serious complexity of implementation (and absence of hardwarefor some times) withusers switching, serverappliances, etc.What kind of "increased security"in question, when we make a server with never locked desktop?To which sticker "in any case, do not block the desktop!!!"is attached:)
In my opinion, allowing access to hardware from session 0 is disadvantageous to operating systems manufacturers, but is profitable for GPU manufacturers.Not a bad decision: to add a driver of some "calculation device" (with separate access control settings, not restricted to interactive user only), in addition to videocard driver, imho.
Petter_L_Intel
Petter
OTorg
New Contributor III
I'll be glad to see it in future versions.
