Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
2946 Discussions
Intel Media sdk fail to run under Valgrind with unhandled instructions
zheng_s_
I use Valgrind to check memory leaking of my application. but Valgrind always fail with some unhandled instruction.
Here is the log message before Valgrind quit
vex amd64->IR: unhandled instruction bytes: 0x66 0x41 0xF 0x38 0x2A 0x2 0x66 0x41
vex amd64->IR:   REX=1 REX.W=0 REX.R=0 REX.X=0 REX.B=1
vex amd64->IR:   VEX=0 VEX.L=0 VEX.nVVVV=0x0 ESC=0F38
vex amd64->IR:   PFX.66=1 PFX.F2=0 PFX.F3=0
==27941== valgrind: Unrecognised instruction at address 0x6fa8e22.
==27941==    at 0x6FA8E22: ??? (in /opt/intel-media/lib64/libmfxhw64-p.so.1.8)
==27941==    by 0x69438CF: ???
==27941==    by 0x7CE3B7F: ???
==27941==    by 0x6F9BC96: ??? (in /opt/intel-media/lib64/libmfxhw64-p.so.1.8)
==27941==    by 0x69CF419: ??? (in /opt/intel-media/lib64/libmfxhw64-p.so.1.8)
==27941==    by 0x69DA928: ??? (in /opt/intel-media/lib64/libmfxhw64-p.so.1.8)
==27941==    by 0x69DB47F: ??? (in /opt/intel-media/lib64/libmfxhw64-p.so.1.8)
==27941==    by 0x69DCE86: ??? (in /opt/intel-media/lib64/libmfxhw64-p.so.1.8)
==27941==    by 0x6A1DF65: ??? (in /opt/intel-media/lib64/libmfxhw64-p.so.1.8)
==27941==    by 0x6A1CE46: ??? (in /opt/intel-media/lib64/libmfxhw64-p.so.1.8)
==27941==    by 0x6A1BEE2: ??? (in /opt/intel-media/lib64/libmfxhw64-p.so.1.8)
==27941==    by 0x6E7E806: ??? (in /opt/intel-media/lib64/libmfxhw64-p.so.1.8)
==27941==    by 0x616F7B5: start_thread (in /lib64/libpthread-2.11.3.so)
==27941==    by 0x5ECAD6C: clone (in /lib64/libc-2.11.3.so)
==27941== Your program just tried to execute an instruction that Valgrind
==27941== did not recognise.  There are two possible reasons for this.
==27941== 1. Your program has a bug and erroneously jumped to a non-code
==27941==    location.  If you are running Memcheck and you just saw a
==27941==    warning about a bad jump, it's probably your program's fault.
==27941== 2. The instruction is legitimate but Valgrind doesn't handle it,
==27941==    i.e. it's Valgrind's fault.  If you think this is the case or
==27941==    you are not sure, please let us know and we'll try to fix it.
==27941== Either way, Valgrind will now raise a SIGILL signal which will
==27941== probably kill your program.
zheng_s_
fix it by upgrading the Valgrind to 3.9.0
