Intel MediaSDK Lens distortion correction (using RAW accelerator) can’t get the same corrected image as PTGUI and Matlab,even using the same parameters: a b c d.
1.The meida_raw_accelerator_man.pdf describes the 3rd degree polynomial for correcting lens distortion :
After doing some research and reading articles,we found the polynomial for correcting lens distortion should be:
2.We use polynomial as the correcting polynomial.
Set parameters value: a=0.0925 b=-0.2676 c=-0.0997c=1.2755
Source image: circle.bmp
PTGUI result: result_ptgui.bmp
Matlab result:result_matlab.bmp
MediaSDK result: result_mediasdk_0.bmp
Matlab code:untitle.m
close all; clear all; clc; tic; A = imread('circle.bmp'); img_gray = rgb2gray(A); [m,n,k] = size(A); P =[0.0925 -0.2676 -0.0997 1.2755]; C=[]; x0 = m/2; y0 = n/2; for u=1:m for v=1:n r = sqrt((u-x0)^2+(v-y0)^2); rt = polyval(P,r/x0)*r; if r ==0 C(u,v,1)=A(x0,y0,1); C(u,v,2)=A(x0,y0,2); C(u,v,3)=A(x0,y0,3); else i = fix((u-x0)*rt/r)+x0; j = fix((v-y0)*rt/r)+y0; C(u,v,1)=A(i,j,1); C(u,v,2)=A(i,j,2); C(u,v,3)=A(i,j,3); end end end C = uint8(C); imshow(C); toc;
MediaSDK program: sample_camera_d.exe
MediaSDK command line:
sample_camera_d.exe -i bayer_circle.raw -f bggr -b 16 -w 4000 -h 3000 -lens 0.0925 -0.2676 -0.0997 1.2755 -o result_mediasdk_
PTGUI and Matlab can get the same result with the same params a,b,c and d. But the MediaSDK lens correction fails to get the same result under the same a b c d.
Now ,we call parameters of PTGUI and Matlab as a,b,c,d. The params of MediaSDK are am bm cm dm.we want to know that :
(1)we know the value of the params a b c and d, how to set the value of am bm cm dm to get the same corrected image as PTGUI and Matlab.
(2)What’s the relationship between a b c d and am bm cm dm
(3)Does mediaSDK use polynomial ? If not,what is the mediaSDK polynomial for correcting.And how can we translate a b c d for quick correcting.
ps.does not the sample_camera.exe support the argb16 input format? the problem is described in the topic:
https://software.intel.com/en-us/forums/intel-media-sdk/topic/704495
the source and destination image which is bmp format.And the bayer format of the source image .
thanks.
