3058 Discussions
Intel® Quick Sync Video H.264 Encoder MFT MFT_OUTPUT_DATA_BUFFER_NO_SAMPLE
bogdan_d_
I'm having problems running Intel® Quick Sync Video H.264 Encoder MFT. The setup, ProcessInput and ProcessOutput are all returning S_OK but the sample from ProcessOutput is NULL and the status is MFT_OUTPUT_DATA_BUFFER_NO_SAMPLE. Any idea what could be wrong?
This is the output:
Start encoding
ProcessInput frame 1
ProcessInput frame 2
ProcessInput frame 3
ProcessInput frame 4
ProcessOutput MFT_OUTPUT_DATA_BUFFER_NO_SAMPLE
from the following code (ignore any leaks that are unrelated to my issue):
void main()
    HRESULT hr = S_OK;
    hr = CoInitializeEx(NULL, COINIT_APARTMENTTHREADED);
    if (FAILED(hr)) {
        OutputDebugString(L"CoInitializeEx failed\n");
        return;
    hr = MFStartup(MF_VERSION);
    if (FAILED(hr)) {
        OutputDebugString(L"MFStartup failed\n");
        return;
    IMFActivate **devices = NULL;
    IMFTransform *encoder = NULL;
    IMFMediaEventGenerator *eventGenerator = NULL;
    GUID inFormat = MFVideoFormat_NV12;
    GUID outFormat = MFVideoFormat_H264;
    MFT_REGISTER_TYPE_INFO inputInfo = { MFMediaType_Video, inFormat };
    MFT_REGISTER_TYPE_INFO outputInfo = { MFMediaType_Video, outFormat };
    uint32_t flags = MFT_ENUM_FLAG_HARDWARE;
    uint32_t count;
    uint32_t fps = 25;
    uint32_t width = 1280;
    uint32_t height = 720;
    IMFAttributes *attributes;
    uint32_t asynch;
    uint32_t len = 0;
    MFCalculateImageSize(inFormat, width, height, &len);
    hr = MFTEnumEx(MFT_CATEGORY_VIDEO_ENCODER, flags, &inputInfo, &outputInfo, &devices, &count);
    if (FAILED(hr)) {
        OutputDebugString(L"MFTEnumEx failed\n");
        return;
    if (count == 0) {
        OutputDebugString(L"No devices\n");
        return;
    LPWSTR szFriendlyName = NULL;
    hr = devices[0]->GetAllocatedString(MFT_FRIENDLY_NAME_Attribute, &szFriendlyName, NULL);
    OutputDebugString(szFriendlyName);
    OutputDebugString(L"\n");
    hr = devices[0]->ActivateObject(IID_PPV_ARGS(&encoder));
    if (FAILED(hr)) {
        OutputDebugString(L"ActivateObject failed\n");
        return;
    for (size_t idx = 0; idx < count; ++idx) {
        devices[idx]->Release();
    CoTaskMemFree(devices);
    encoder->QueryInterface(&eventGenerator);
    hr = encoder->GetAttributes(&attributes);
    if (FAILED(hr)) {
        return;
    hr = attributes->GetUINT32(MF_TRANSFORM_ASYNC, &asynch);
    hr = attributes->SetUINT32(MF_TRANSFORM_ASYNC_UNLOCK, TRUE);
    attributes->Release();
    if (FAILED(hr)) {
        return;
    DWORD inputCount = 0, outputCount = 0, inputId = 0, outputId = 0;
    hr = encoder->GetStreamCount(&inputCount, &outputCount);
    if (FAILED(hr)) {
        return;
    if (inputCount == 0 || outputCount == 0) {
        return;
    DWORD *inputIds = new DWORD[inputCount];
    DWORD *outputIds = new DWORD[outputCount];
    hr = encoder->GetStreamIDs(inputCount, inputIds, outputCount, outputIds);
    auto cleanStreamIds = [&inputIds, &outputIds] {
        delete[] inputIds;
        inputIds = NULL;
        delete[] outputIds;
        outputIds = NULL;
    if (FAILED(hr)) {
        if (hr != E_NOTIMPL) {
            OutputDebugString(L"GetStreamIDs failed\n");
            cleanStreamIds();
            return;
    else {
        inputId = inputIds[0];
        outputId = outputIds[0];
    cleanStreamIds();
    IMFMediaType *outputType = NULL;
    hr = MFCreateMediaType(&outputType);
    if (FAILED(hr)) {
        OutputDebugString(L"MFCreateMediaType outputType failed\n");
        return;
    hr = outputType->SetGUID(MF_MT_MAJOR_TYPE, MFMediaType_Video);
    hr = outputType->SetGUID(MF_MT_SUBTYPE, outFormat);
    hr = outputType->SetUINT32(MF_MT_AVG_BITRATE, 10000000);
    hr = MFSetAttributeSize(outputType, MF_MT_FRAME_SIZE, width, height);
    hr = MFSetAttributeRatio(outputType, MF_MT_FRAME_RATE, fps, 1);
    hr = outputType->SetUINT32(MF_MT_INTERLACE_MODE, MFVideoInterlace_Progressive);
    hr = outputType->SetUINT32(MF_MT_MPEG2_PROFILE, eAVEncH264VProfile_High);
    hr = outputType->SetUINT32(MF_MT_MPEG2_LEVEL, eAVEncH264VLevel3_1);
    hr = outputType->SetUINT32(CODECAPI_AVEncCommonRateControlMode, eAVEncCommonRateControlMode_CBR);
    hr = encoder->SetOutputType(outputId, outputType, 0);
    if (FAILED(hr)) {
        OutputDebugString(L"SetOutputType failed\n");
        return;
    IMFMediaType *inputType = NULL;
    hr = MFCreateMediaType(&inputType);
    if (FAILED(hr)) {
        OutputDebugString(L"MFCreateMediaType inputType failed\n");
        return;
    hr = inputType->SetGUID(MF_MT_MAJOR_TYPE, MFMediaType_Video);
    hr = inputType->SetGUID(MF_MT_SUBTYPE, inFormat);
    hr = inputType->SetUINT32(MF_MT_INTERLACE_MODE, MFVideoInterlace_Progressive);
    hr = MFSetAttributeSize(inputType, MF_MT_FRAME_SIZE, width, height);
    hr = MFSetAttributeRatio(inputType, MF_MT_FRAME_RATE, fps, 1);
    hr = MFSetAttributeRatio(inputType, MF_MT_PIXEL_ASPECT_RATIO, 1, 1);
    hr = encoder->SetInputType(inputId, inputType, 0);
    if (FAILED(hr)) {
        OutputDebugString(L"SetInputType failed\n");
        return;
    hr = encoder->ProcessMessage(MFT_MESSAGE_COMMAND_FLUSH, 0);
    hr = encoder->ProcessMessage(MFT_MESSAGE_NOTIFY_BEGIN_STREAMING, 0);
    hr = encoder->ProcessMessage(MFT_MESSAGE_NOTIFY_START_OF_STREAM, 0);
    OutputDebugString(L"Start encoding\n");
    uint32_t frame = 1;
    IMFMediaEvent *event = NULL;
    MediaEventType type;
    do
        hr = eventGenerator->GetEvent(0, &event);
        hr = event->GetType(&type);
        switch (type)
        case METransformNeedInput: {
            IMFSample *newSample = NULL;
            IMFMediaBuffer *buffer;
            hr = MFCreateMemoryBuffer(len, &buffer);
            byte *bufferData;
            hr = buffer->Lock(&bufferData, NULL, NULL);
            memset(bufferData, 0, len);
            hr = buffer->Unlock();
            hr = buffer->SetCurrentLength(len);
            hr = MFCreateSample(&newSample);
            hr = newSample->AddBuffer(buffer);
            uint64_t sampleDuration = 0;
            MFFrameRateToAverageTimePerFrame(fps, 1, &sampleDuration);
            newSample->SetSampleDuration(sampleDuration);
            hr = encoder->ProcessInput(0, newSample, 0);
            if (FAILED(hr)) {
                OutputDebugString(L"ProcessInput failed\n");
                return;
            else
                WCHAR outMessage[128];
                memset(outMessage, 0, 128 * sizeof(WCHAR));
                wsprintf(outMessage, L"ProcessInput frame %u\n", frame);
                OutputDebugString(outMessage);
                ++frame;
            break;
        case METransformHaveOutput: {
            MFT_OUTPUT_DATA_BUFFER data = { outputId, NULL, 0, NULL };
            MFT_OUTPUT_STREAM_INFO outInfo;
            hr = encoder->GetOutputStreamInfo(outputId, &outInfo);
            if (!(outInfo.dwFlags & MFT_OUTPUT_STREAM_PROVIDES_SAMPLES)) {
                OutputDebugString(L"!MFT_OUTPUT_STREAM_PROVIDES_SAMPLES not handled\n");
                return;
            DWORD status = 0;
            hr = encoder->ProcessOutput(MFT_OUTPUT_STREAM_PROVIDES_SAMPLES, 1, &data, &status);
            if (FAILED(hr)) {
                OutputDebugString(L"ProcessOutput failed\n");
                return;
            if (data.dwStatus == MFT_OUTPUT_DATA_BUFFER_NO_SAMPLE) {
                OutputDebugString(L"ProcessOutput MFT_OUTPUT_DATA_BUFFER_NO_SAMPLE\n");
                return;
            break;
        default:
            break;
    } while (true);
Also, here is the output from mediasdk_ss_analyzer:
The following versions of Media SDK API are supported by platform/driver
[opportunistic detection of MSDK API > 1.16]:
        Version Target  Supported       Dec     Enc
        1.0     HW      Yes             X       X
        1.0     SW      Yes             X       X
        1.1     HW      Yes             X       X
        1.1     SW      Yes             X       X
        1.2     HW      Yes             X       X
        1.2     SW      Yes             X       X
        1.3     HW      Yes             X       X
        1.3     SW      Yes             X       X
        1.4     HW      Yes             X       X
        1.4     SW      Yes             X       X
        1.5     HW      Yes             X       X
        1.5     SW      Yes             X       X
        1.6     HW      Yes             X       X
        1.6     SW      Yes             X       X
        1.7     HW      Yes             X       X
        1.7     SW      Yes             X       X
        1.8     HW      Yes             X       X
        1.8     SW      Yes             X       X
        1.9     HW      Yes             X       X
        1.9     SW      Yes             X       X
        1.10    HW      Yes             X       X
        1.10    SW      Yes             X       X
        1.11    HW      Yes             X       X
        1.11    SW      Yes             X       X
        1.12    HW      Yes             X       X
        1.12    SW      Yes             X       X
        1.13    HW      Yes             X       X
        1.13    SW      Yes             X       X
        1.14    HW      Yes             X       X
        1.14    SW      Yes             X       X
        1.15    HW      Yes             X       X
        1.15    SW      Yes             X       X
        1.16    HW      Yes             X       X
        1.16    SW      Yes             X       X
        1.17    HW      Yes             X       X
        1.17    SW      Yes             X       X
Graphics Devices:
        Name                                         Version             State
        Intel(R) HD Graphics                         20.19.15.4320       Active
System info:
        CPU:    Intel(R) Pentium(R) CPU  N3700  @ 1.60GHz
        OS:     Microsoft Windows 10 Home Single Language
        Arch:   64-bit
Installed Media SDK packages (be patient...processing takes some time):
        Intel(R) Media Samples 6.0.0.68
        Intel(R) Media SDK 2016
Analysis complete... [press ENTER]
Harshdeep_B_Intel
Hi Bogdan,
Thank you for sharing the detailed log of your system. Looking into issue and based on our investigation, the status returned "MFT_OUTPUT_DATA_BUFFER_NO_SAMPLE"  is not specifically due to hardware MFT (Intel® Quick Sync Video H.264 Encoder MFT) but due to no MFT sample ready for this stream.
For MSFT website reference here: https://technet.microsoft.com/es-es/ms704014, "If the MFT has multiple output streams, the streams might produce output at different rates, so some streams might have output while other streams do not. If a stream did not any produce output, the MFT sets the MFT_OUTPUT_DATA_BUFFER_NO_SAMPLE flag in the dwStatus member of the MFT_OUTPUT_DATA_BUFFER structure for that stream". I suggest checking with MSFT support team on this issue. Hope this information helps.
bogdan_d_
Hi Harsh,
Thank you for your answer.
The MFT has only 1 output stream (only 1 input stream too).
Also, running the same code with an NVIDIA hardware MFT, I have no issues on getting encoded frames (below is the output from it):
NVIDIA H.264 Encoder MFT
Start encoding
ProcessOutput Got output
Bogdan
Harshdeep_B_Intel
Hi Bogdan,
Thank you for sharing this information. If the MFT has only 1 output stream, then further investigation is needed. Can you please share a log from mediasdk_tracer (https://software.intel.com/en-us/articles/media-sdk-tools). Also, I have shared a tool via private message. Please share the logs from the tools, where logs could provide us more visibility into this issue.
bogdan_d_
Hi Harsh,
Attached are the logs from mediasdk_tracer.
Please note that I didn't get any private messages from you, so I cannot provide any logs from the tool that you shared via private message.
Bogdan
Harshdeep_B_Intel
Hi Bogdan,
Thank you for the log. Please check you inbox for Intel forum messages and I did re-send the message again too. Also, after brief look at the code (above) I suspect the issue is caused by MFT_OUTPUT_STREAM_PROVIDES_SAMPLES flag as it is not supported by Intel H.264 Encoder HMFT. Please try and remove this flag to isolate the problem, let me know how it goes.
Tammo_H_
EDIT: Never mind. In my case it was a problem with the encoder wanting to renegotiate the output format and my code miscounting the METransformHaveOutput callbacks.
Hey,
I have the exact same problem, and it's clearly not related to the MFT_OUTPUT_STREAM_PROVIDES_SAMPLES flag - providing a sample in the MFT_OUTPUT_DATA_BUFFER structure doesn't help.
My code is completely independent from Bogdan's, and it's working flawlessly on NVidia/AMD GPUs and Microsoft's software encoder MFT, so there's definitely something fishy going on there.
