Hi
I'm having problems running Intel® Quick Sync Video H.264 Encoder MFT, when the hardware MFT sents METransformHaveOutput(EventType = 602) event, the sample from ProcessOutput is NULL, and the program is blocked in this state. Any Any idea what could be wrong? or are there some examples of hardware MFT?
Here are the outputs
Hardware URL Attribute:AA243E5D-2F73-48c7-97F7-F6FA17651651.
Hardware Friendly Name:Intel?Quick Sync Video H.264 Encoder MFT.
Frame 1
EventType = 601
timeStamp = 0
duration = 49816800
EventType = 601
EventType = 602
Following are parts of my code, and program is blocked at WaitForSingleObject(mEventDrainComplete, INFINITE), the MFT have already turned to METransformHaveOutput while the sample from ProcessOutput is NULL.
#include "hw_enc_common.h"
#include "MpegEncoder_i.h"
#pragma unmanaged
MpegEncoder::MpegEncoder()
mEventHaveInput = CreateEvent(NULL, FALSE, FALSE, NULL);
mEventNeedInput = CreateEvent(NULL, FALSE, FALSE, NULL);
mEventDrainComplete = CreateEvent(NULL, FALSE, FALSE, NULL);
MpegEncoder::~MpegEncoder()
CloseHandle(mEventHaveInput);
CloseHandle(mEventNeedInput);
CloseHandle(mEventDrainComplete);
bool MpegEncoder::Initialize()
bool res;
//try
HRESULT hr;
TESTHR(hr = MFStartup(MF_VERSION));
res = true;
//catch(com_error ex)
// res = false;
return res;
bool MpegEncoder::Create(int width, int height, int rate)
bool res;
HRESULT hr;
error = false;
mRate = rate;
mWidth = width;
mHeight = height;
mpWriter = NULL;
//CoInitializeEx(NULL, COINIT_APARTMENTTHREADED | COINIT_DISABLE_OLE1DDE);
//MFStartup(MF_VERSION);
uint64_t frame_rate = uint64_t(rate) << 32 | 1;
uint64_t frame_size = uint64_t(width) << 32 | height;
//mTrace = new CObTrace(L"H264Encoder_#.log");
//mTrace->SetLogByDate();
//try
IMFMediaTypePtr pType1;
MFCreateMediaType(&pType1);
TESTHR(hr = pType1->SetGUID(MF_MT_MAJOR_TYPE, MFMediaType_Video));
TESTHR(hr = pType1->SetGUID(MF_MT_SUBTYPE, MFVideoFormat_I420));
TESTHR(hr = pType1->SetUINT32(MF_MT_INTERLACE_MODE, 2/*MFVideoInterlaceMode::MFVideoInterlace_Progressive*/));
TESTHR(hr = pType1->SetUINT64(MF_MT_FRAME_RATE, frame_rate));
TESTHR(hr = pType1->SetUINT64(MF_MT_FRAME_SIZE, frame_size));
IMFMediaTypePtr pType2;
MFCreateMediaType(&pType2);
TESTHR(hr = pType2->SetGUID(MF_MT_MAJOR_TYPE, MFMediaType_Video));
TESTHR(hr = pType2->SetGUID(MF_MT_SUBTYPE, MFVideoFormat_NV12));
TESTHR(hr = pType2->SetUINT32(MF_MT_INTERLACE_MODE, 2/*MFVideoInterlaceMode::MFVideoInterlace_Progressive*/));
TESTHR(hr = pType2->SetUINT64(MF_MT_FRAME_RATE, frame_rate));
TESTHR(hr = pType2->SetUINT64(MF_MT_FRAME_SIZE, frame_size));
IMFMediaTypePtr pType3;
MFCreateMediaType(&pType3);
TESTHR(hr = pType3->SetGUID(MF_MT_MAJOR_TYPE, MFMediaType_Video));
TESTHR(hr = pType3->SetGUID(MF_MT_SUBTYPE, MFVideoFormat_H264));
TESTHR(hr = pType3->SetUINT32(MF_MT_AVG_BITRATE, 100000000));
TESTHR(hr = pType3->SetUINT64(MF_MT_FRAME_RATE, frame_rate));
TESTHR(hr = pType3->SetUINT64(MF_MT_FRAME_SIZE, frame_size));
TESTHR(hr = pType3->SetUINT32(MF_MT_INTERLACE_MODE, 2/*MFVideoInterlaceMode::MFVideoInterlace_Progressive*/));
TESTHR(hr = pType3->SetUINT32(MF_MT_MPEG2_PROFILE, 66/*eAVEncH264VProfile::eAVEncH264VProfile_Main*/));
TESTHR(hr = pType3->SetUINT32(MF_MT_ALL_SAMPLES_INDEPENDENT, TRUE));
///////////////////////////////////color convert///////////////////////////////////
IUnknown *spH264EncoderUnk = NULL, *spColorConvertUnk = NULL;
TESTHR(MFTRegisterLocalByCLSID(
__uuidof(CColorConvertDMO),
MFT_CATEGORY_VIDEO_PROCESSOR,
L"",
MFT_ENUM_FLAG_SYNCMFT,
0,
NULL,
0,
NULL
// Create Color Convert
TESTHR(CoCreateInstance(CLSID_CColorConvertDMO, NULL, CLSCTX_INPROC_SERVER,
IID_IUnknown, (void**)&spColorConvertUnk));
TESTHR(spColorConvertUnk->QueryInterface(IID_PPV_ARGS(&mpColorConverter)));
//TESTHR(hr = mpColorConverter.CreateInstance(CLSID_CColorConvertDMO, mpColorConverter));
TESTHR(hr = mpColorConverter->SetOutputType(0, pType2, 0));
TESTHR(hr = mpColorConverter->SetInputType(0, pType1, 0));
///////////////////////////////////////////h264 encoder//////////////////////////////////////
uint32_t count = 0;
IMFActivate **ppActivate = NULL;
TESTHR( MFTEnumEx(
MFT_CATEGORY_VIDEO_ENCODER,
MFT_ENUM_FLAG_ASYNCMFT | MFT_ENUM_FLAG_HARDWARE | MFT_ENUM_FLAG_LOCALMFT,
NULL, // Input type
NULL, // Output type
&ppActivate,
&count
if (SUCCEEDED(hr) && count == 0)
hr = MF_E_TOPO_CODEC_NOT_FOUND;
printf("H264 Encoder MF_E_TOPO_CODEC_NOT_FOUND\n");
// Create the first encoder in the list.
if (SUCCEEDED(hr))
LPWSTR hardwareName = NULL;
TESTHR(ppActivate[0]->GetAllocatedString(MFT_ENUM_HARDWARE_URL_Attribute, &hardwareName, NULL));
wprintf(L"Hardware URL Attribute:%s.\n", hardwareName);
TESTHR(ppActivate[0]->GetAllocatedString(MFT_FRIENDLY_NAME_Attribute, &hardwareName, NULL));
wprintf(L"Hardware Friendly Name:%s.\n", hardwareName);
TESTHR(ppActivate[0]->ActivateObject(IID_PPV_ARGS(&mpH264Encoder)));
for (UINT32 i = 0; i < count; i++)
ppActivate->Release();
CoTaskMemFree(ppActivate);
//TESTHR(hr = mpH264Encoder.CreateInstance(L"{4BE8D3C0-0515-4A37-AD55-E4BAE19AF471}", mpH264Encoder));
IMFAttributesPtr pAttributes;
TESTHR(hr = mpH264Encoder->GetAttributes(&pAttributes));
TESTHR(hr = pAttributes->SetUINT32(MF_TRANSFORM_ASYNC_UNLOCK, TRUE));
TESTHR(hr = pAttributes->SetUINT32(MF_READWRITE_ENABLE_HARDWARE_TRANSFORMS, TRUE));
TESTHR(hr = mpH264Encoder->SetOutputType(0, pType3, 0));
TESTHR(hr = mpH264Encoder->SetInputType(0, pType2, 0));
TESTHR(hr = mpH264Encoder->QueryInterface(IID_IMFMediaEventGenerator, (void**)&mpH264EncoderEventGenerator));
TESTHR(hr = mpH264EncoderEventGenerator->BeginGetEvent(this, NULL));
mpWriter = NULL;
res = true;
//catch (com_error ex)
// mTrace->Trace(1, L"Exception in %s(%d): 0x%08X", ex.GetFilename(), ex.GetLinenum(), ex.Error());
// res = false;
return res;
bool MpegEncoder::Open(const wchar_t *filename)
bool res;
HRESULT hr;
//mTrace->Trace(1, L"New file: %s", filename);
//try
mFilename = filename;
mpWriter = NULL;
ResetEvent(mEventHaveInput);
ResetEvent(mEventNeedInput);
ResetEvent(mEventDrainComplete);
TESTHR(hr = mpH264Encoder->ProcessMessage(MFT_MESSAGE_NOTIFY_START_OF_STREAM, 0));
res = true;
// res = false;
return res;
bool MpegEncoder::Encode(uint8_t * image, uint32_t size, uint64_t timestamp, uint64_t duration)
bool res;
//try
this->image = image;
this->size = size;
this->timestamp = timestamp;
this->duration = duration;
//mTrace->Trace(1, L"New image");
SetEvent(mEventHaveInput);
WaitForSingleObject(mEventNeedInput, INFINITE);
this->image= nullptr;
res = !error;
// res = false;
return res;
bool MpegEncoder::Close()
bool res;
//try
HRESULT hr;
//mTrace->Trace(1, L"End file");
// Retrieve the last samples that might by in the encoder
TESTHR(hr = mpH264Encoder->ProcessMessage(MFT_MESSAGE_NOTIFY_END_OF_STREAM, 0));
TESTHR(hr = mpH264Encoder->ProcessMessage(MFT_MESSAGE_COMMAND_DRAIN, 0));
printf("gg\n");
WaitForSingleObject(mEventDrainComplete, INFINITE);
printf("hh\n");
TESTHR(hr = mpWriter->Finalize());
mpWriter = NULL;
newFile = true;
res = true;
// res = false;
return res;
STDMETHODIMP MpegEncoder::Invoke(IMFAsyncResult* pAsyncResult)
HRESULT hr;
HRESULT hStatus;
IMFMediaEventPtr pEvent;
MediaEventType meType;
//try
TESTHR(hr = mpH264EncoderEventGenerator->EndGetEvent(pAsyncResult, &pEvent));
TESTHR(hr = pEvent->GetType(&meType));
TESTHR(hr = pEvent->GetStatus(&hStatus));
printf("EventType = %d\n", meType);
if (hStatus == S_OK)
if (meType == METransformNeedInput)
HRESULT hr;
BYTE *pbBuffer;
DWORD status;
IMFSamplePtr pYUVSample, pNV12Sample;
IMFMediaBufferPtr pYUVBuffer, pNV12Buffer;
MFT_OUTPUT_STREAM_INFO streaminfo;
//mTrace->Trace(1, L"New METransformNeedInput event");
WaitForSingleObject(mEventHaveInput, INFINITE);
if (image != NULL)
TESTHR(hr = MFCreateMemoryBuffer(size, &pYUVBuffer));
TESTHR(hr = pYUVBuffer->Lock(&pbBuffer, NULL, NULL));
TESTHR(hr = MFCopyImage(pbBuffer, mWidth , image, mWidth , mWidth, mHeight*3/2));
TESTHR(hr = pYUVBuffer->SetCurrentLength(size));
TESTHR(hr = pYUVBuffer->Unlock());
TESTHR(hr = MFCreateSample(&pYUVSample));
TESTHR(hr = pYUVSample->AddBuffer(pYUVBuffer));
TESTHR(hr = pYUVSample->SetSampleDuration(duration));
TESTHR(hr = pYUVSample->SetSampleTime(timestamp));
TESTHR(hr = mpColorConverter->ProcessInput(0, pYUVSample, 0));
MFT_OUTPUT_DATA_BUFFER nv12OutputDataBuffer;
ZeroMemory(&nv12OutputDataBuffer, sizeof(nv12OutputDataBuffer));
TESTHR(hr = mpColorConverter->GetOutputStreamInfo(0, &streaminfo));
TESTHR(hr = MFCreateSample(&pNV12Sample));
TESTHR(hr = MFCreateMemoryBuffer(streaminfo.cbSize, &pNV12Buffer));
TESTHR(hr = pNV12Sample->AddBuffer(pNV12Buffer));
nv12OutputDataBuffer.pSample = pNV12Sample;
TESTHR(hr = mpColorConverter->ProcessOutput(0, 1, &nv12OutputDataBuffer, &status));
if (newFile)
//mTrace->Trace(1, L"Set MFSampleExtension_Discontinuity");
TESTHR(hr = nv12OutputDataBuffer.pSample->SetUINT32(MFSampleExtension_Discontinuity, TRUE));
newFile = false;
TESTHR(hr = mpH264Encoder->ProcessInput(0, nv12OutputDataBuffer.pSample, 0));
SetEvent(mEventNeedInput);
else if (meType == METransformHaveOutput)
DWORD status;
MFT_OUTPUT_DATA_BUFFER h264OutputDataBuffer;
TESTHR(hr = mpH264Encoder->GetOutputStreamInfo(0, &streaminfo));
//mTrace->Trace(1, L"New METransformHaveOutput event");
ZeroMemory(&h264OutputDataBuffer, sizeof(h264OutputDataBuffer));
hr = mpH264Encoder->ProcessOutput(0, 1, &h264OutputDataBuffer, &status);
if (hr == MF_E_TRANSFORM_STREAM_CHANGE)
//mTrace->Trace(1, L"New MF_E_TRANSFORM_STREAM_CHANGE event");
if (h264OutputDataBuffer.dwStatus & MFT_OUTPUT_DATA_BUFFER_FORMAT_CHANGE)
//mTrace->Trace(1, L"New MFT_OUTPUT_DATA_BUFFER_FORMAT_CHANGE event");
// El encoder dice que el formato ha cambiado y necesita que lo configuremos de nuevo
// Leemos el tipo que tiene configurado y se lo volvemos a escribir.
IMFMediaTypePtr pType;
TESTHR(hr = mpH264Encoder->GetOutputAvailableType(0, 0, &pType));
TESTHR(hr = mpH264Encoder->SetOutputType(0, pType, 0));
else if (hr == S_OK)
if (mpWriter == NULL)
IMFByteStreamPtr pByteStream;
IMFMediaSinkPtr pMediaSink;
TESTHR(hr = MFCreateFile(MF_ACCESSMODE_READWRITE, MF_OPENMODE_DELETE_IF_EXIST, MF_FILEFLAGS_NONE, mFilename.c_str(), &pByteStream));
TESTHR(hr = MFCreateMPEG4MediaSink(pByteStream, pType, NULL, &pMediaSink));
TESTHR(hr = MFCreateSinkWriterFromMediaSink(pMediaSink, NULL, &mpWriter));
TESTHR(hr = mpWriter->BeginWriting());
TESTHR(hr = mpWriter->WriteSample(0, h264OutputDataBuffer.pSample));
h264OutputDataBuffer.pSample->Release();
if (h264OutputDataBuffer.pEvents != NULL)
h264OutputDataBuffer.pEvents->Release();
else
TESTHR(hr);
else if (meType == METransformDrainComplete)
//mTrace->Trace(1, L"New METransformDrainComplete event");
TESTHR(hr = mpH264Encoder->ProcessMessage(MFT_MESSAGE_COMMAND_FLUSH, 0));
SetEvent(mEventDrainComplete);
else if (meType == MEError)
PROPVARIANT pValue;
TESTHR(hr = pEvent->GetValue(&pValue));
//mTrace->Trace(1, L"MEError, value: %u", pValue.vt);
error = true;
else
PROPVARIANT pValue;
//mTrace->Trace(1, L"Unknown event type: %lu, Value: %u", meType, pValue.vt);
// printf("Exception in %s(%d): 0x%08X\n", ex.GetFilename(), ex.GetLinenum(), ex.Error());
return S_OK;
Here is the information of my computer
CPU:Intel(R) Core(TM) i7-4790
GPU:Intel HD 4600 with device version 10.18.15.4279
AMD Radeon(TM) R5 240 with device version 20.19.0.32832
Hi There,
Does MSDK sample_encode work for you ? And what is your system configuration ?
Zachary
Hi, Zachary
My system configuration is
Sys: Win10 Pro
And where can I find MSDK sample_encode. My local MSDK folder doesn't contain such sample.
Hi Will,
MSDK samples can be download from: https://software.intel.com/en-us/media-sdk-support/code-samples
Zachary
Hi, Zachary
I've successfully called Intel Quick Sync H.264 Encoder and ICodecAPI, and I can dynamicly change video resolution, frame rate, profile. But when it comes to change bit rate, the .264 bitstream illustrates that the configure doesn't work. Same method works well in windows software H264 Encoder MFT.
Here is the ICodecAPI I uesd
CODECAPI_AVEncCommonRateControlMode = eAVEncCommonRateControlMode_CBR
CODECAPI_AVEncCommonMeanBitRate = 2000000
So how can I dynamicly change bit rate in Intel Quick Sync H.264 Encoder.
Thanks a lot.
