Intel media sdk H.264 decoder handle leak
Kazuya_K_
I think bug in MediaSDK.
OS : Windows7 (x64)
SDK:API version 1.11
1. Create instance and initialize.
2. Execute decode operation.
3. Close operation.(reference to the sample code)
When performing the above operation, handle count increases one.
If does not execute decode, handle count does not increase.(create instance -> initialize -> close)
I think the wait handle that was created in asynchronous decoding has not been released.
If this is a bug, I hope to be fixed in the next release.
(Sorry, I'm using the online translation services.)
Harshdeep_B_Intel
We have new MSDK API release version 1.13 . Please run sample application again from the new version and send me logs. Also send me logs from System analyzer to know about HW configuration, with information of which MSDK sample you are using.
Kazuya_K_
thank you for reply.
I have updated the SDK to version 1.13.
And rebuild the code, but did not improve.
My application was created in reference to the "intel_media_sdk_tutorial_041813 (simple_2_decode d3d)".
System Analyzer Log(HW configuration)
Intel Media SDK System Analyzer (64 bit)
The following versions of Media SDK API are supported by platform/driver:
    Version    Target    Supported    Dec    Enc
    1.0    HW    Yes        X    X
    1.0    SW    Yes        X    X
    1.1    HW    Yes        X    X
    1.1    SW    Yes        X    X
    1.3    HW    Yes        X    X
    1.3    SW    Yes        X    X
    1.4    HW    Yes        X    X
    1.4    SW    Yes        X    X
    1.5    HW    Yes        X    X
    1.5    SW    Yes        X    X
    1.6    HW    Yes        X    X
    1.6    SW    Yes        X    X
    1.7    HW    Yes        X    X
    1.7    SW    Yes        X    X
    1.8    HW    Yes        X    X
    1.8    SW    Yes        X    X
Graphics Devices:
    Name                                         Version             State
    Intel(R) HD Graphics 4000                    10.18.10.4061       Active
System info:
    CPU:    Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
    OS:    Microsoft Windows 7 Professional
    Arch:    64
Installed Media SDK DirectShow filters:
Installed Intel Media Foundation Transforms:
  Intelョ Hardware M-JPEG Decoder MFT : {00C69F81-0524-48C0-A353-4DD9D54F9A6E}
  Intelョ Hardware VC-1 Decoder MFT : {059A5BAE-5D7A-4C5E-8F7A-BFD57D1D6AAA}
  Intelョ Hardware H.264 Decoder MFT : {45E5CE07-5AC7-4509-94E9-62DB27CF8F96}
  Intelョ Hardware MPEG-2 Decoder MFT : {CD5BA7FF-9071-40E9-A462-8DC5152B1776}
  Intelョ Quick Sync Video H.264 Encoder MFT : {4BE8D3C0-0515-4A37-AD55-E4BAE19AF471}
  Intelョ Hardware Preprocessing MFT : {EE69B504-1CBF-4EA6-8137-BB10F806B014}
Harshdeep_B_Intel
I see that you are creating your own application using a tutorial. I highly suggest to use the our Samples as reference as they are regularly updated and we can look into further if you see the similar issue with the samples. Also, update the graphic driver to the latest from: https://downloadcenter.intel.com/ ;
Kazuya_K_
Driver version is the latest way.(10.18.10.4061)
Change "Intel Media Samples 6.0.0.98947 \ sample_decode" as shown below
#if defined(_WIN32) || defined(_WIN64)
int _tmain(int argc, TCHAR *argv[])
#else
int main(int argc, char *argv[])
#endif
	CDecodingPipeline*   Pipeline; // pipeline for decoding, includes input file reader, decoder and output file writer
	for(int count=0; count < 1000; count++)
		sInputParams        Params;   // input parameters from command line
		//CDecodingPipeline   Pipeline; // pipeline for decoding, includes input file reader, decoder and output file writer
		Pipeline = new CDecodingPipeline();
		mfxStatus sts = MFX_ERR_NONE; // return value check
		sts = ParseInputString(argv, (mfxU8)argc, &Params);
		MSDK_CHECK_PARSE_RESULT(sts, MFX_ERR_NONE, 1);
		if (Params.bIsMVC)
			Pipeline->SetMultiView();//Pipeline.SetMultiView();
		sts = Pipeline->Init(&Params);//sts = Pipeline.Init(&Params);
		MSDK_CHECK_RESULT(sts, MFX_ERR_NONE, 1);
		// print stream info
		Pipeline->PrintInfo();//Pipeline.PrintInfo();
		msdk_printf(MSDK_STRING("Decoding started\n"));
		for (;;)
			sts = Pipeline->RunDecoding();//sts = Pipeline.RunDecoding();
			if (MFX_ERR_INCOMPATIBLE_VIDEO_PARAM == sts || MFX_ERR_DEVICE_LOST == sts || MFX_ERR_DEVICE_FAILED == sts)
				if (MFX_ERR_INCOMPATIBLE_VIDEO_PARAM == sts)
					msdk_printf(MSDK_STRING("\nERROR: Incompatible video parameters detected. Recovering...\n"));
				else
					msdk_printf(MSDK_STRING("\nERROR: Hardware device was lost or returned unexpected error. Recovering...\n"));
					sts = Pipeline->ResetDevice();//sts = Pipeline.ResetDevice();
				sts = Pipeline->ResetDecoder(&Params);//sts = Pipeline.ResetDecoder(&Params);
				continue;
			else
				break;
		msdk_printf(MSDK_STRING("\nDecoding finished\n"));
		delete Pipeline;
		Pipeline = NULL;
    return 0;
Other parts are not changed.
When you compile and run this code, also an increase in handle count is seen.
(Command line arguments: h264 -d3d -hw -i test.h264)
Harshdeep_B_Intel
The operation you are performing  in the For loop where  you are creating a pipeline in the beginning and deleting it in the end of every run. On next run, when pipeline is created, it is not completely Null. So basically the operation you are trying to run by just modifying  the sample to work will not work as it was never  designed to handle the pipeline loop in the way you are making calls. But, I will send this information to the team and update.
Laurent_M_
I have also an handle leak with H264 decoder.
I use some tools to detect where the problem occurs.
I think the problem is in the function MFXVideoDECODE_DecodeFrameAsync. This function call CreateEvent but event isn't close.
I work with IPP for 10 years. When we discovered a bug in IPP sample, it's possible to fix it, but unfortunately we haven't source code with IMS.
How to resolve this issue?
Do I need a driver update?
Edit: The problem depends of hardware/driver version
System 1: HANDLE LEAK
CPU : Intel i7-3770K
Motherboard : Intel DZ77BH-55K
GPU : Intel HD 4000 version 10.18.10.4061
OS : Windows 7 64bits
Software : x86 or x64
System 2: NO HANDLE LEAK
CPU : Intel i5-4250U
NUC D54250WYK
GPU : Intel HD 5000 version 10.18.14.4080
OS : WES 7 64bits
Software : x86
Laurent
Harshdeep_B_Intel
Hi Laurent,
Please create a new thread with the issue you are facing with logs from System analyzer and information about the sample you are seeing this issue. This will help us better track the issues separately and avoid confusion.
