Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
Intel msdk dynamic library missing interfaces
jiguan_c_
The problem: Intel msdk dynamic library missing interface as follows: MFXVideoUSER_Load, MFXVideoUSER_UnLoad.This two interfaces are Indispensable when it will decode video。
INDE Version: w_inde_2015.1.021.exe
The System Info: Win7_64bit, E3-1285v3 @ 3.60GHz 4C8T, Intel Iris™ Pro Graphics P6300, 8G(4GX2 DDR3 1600MHz), The graphic driver , version:4223(20140522)
The 32-bit msdk dynamic library is as follows:.
Its interfaces is as follows:
Its header file is as follows:  (we can see the interfaces of 32-bit msdk dynamic are less than the ones of header file)
The 64-bit msdk dynamic library is as follows, it looks that it can’t be used.
Other,The Static library (libmfx.lib) can be used normally.
Shaojuan_Z_Intel
Hi Jiguan,
Looks like some contents of your post can't be displayed in the webpage. Could you repost again? From the information above, the INDE version is old, and the same with driver. Can you please update to the latest MediaSDK from Intel Software Manager? The latest version is 6.0.0.388. After update, if you still see the same issue, please let us know. Thanks.
