Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
Intel vaapi error: can't connect to X server
mfoglio
I am using an EC2 with Ubuntu 18.04, CPU Intel(R) Xeon(R) Platinum 8259CL CPU @ 2.50GHz, and a Nvidia Tesla T4. It seems `vainfo` reports a problematic setup:
error: can't connect to X server!
libva info: VA-API version 1.1.0
libva info: va_getDriverName() returns -1
libva error: va_getDriverName() failed with unknown libva error,driver_name=(null)
vaInitialize failed with error code -1 (unknown libva error),exit
My goal is to use vaapi accelerated HW decoding with gstreamer in Python.
`lspci | grep VGA` returns:
Note:
- I installed on the EC2 the Nvidia drivers (not sure if they could interfere with Intel's graphic card)
- I also installed OpenVINO
- I was following this guide http://lifestyletransfer.com/how-to-install-gstreamer-vaapi-plugins-on-ubuntu/ for the setup and I got stuck at the point when I run `vaapi`
How can I fix this?
JaideepK_Intel
We are investigating your issue at our end and we will get back to you soon.
Jaideep
JaideepK_Intel
Sorry for delay, “vainfo” normally reports the availability of the libVA on Linux platform which is the layer that connect media SDK library and kernel driver, if it is not available, Media SDK cannot use hardware acceleration in Linux.
Xeon Processors:
For Media SDK, we must make sure “Quick Sync” is included in the integrated GPU. So Xeon(R) Platinum 8259CL will not work. We only include GPU in Xeon E3.
If Nvidia's GPU takes the primary position, the integrated GPU might not be accessible. Please go through below links:
  1. https://github.com/Intel-Media-SDK/MediaSDK/issues/167
  2. https://github.com/Intel-Media-SDK/MediaSDK/issues/1067
  3. https://github.com/Intel-Media-SDK/MediaSDK/issues/2477
Jaideep
JaideepK_Intel
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue. Thank you!
Jaideep
JaideepK_Intel
I have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Jaideep
