Is VPP Composition available On 3rd Generation Intel Core Processors?
____2
Hi, Is VPP Composition available On 3rd Generation Intel Core Processors?
and Now Is VPP Composition available On windows platform?
Sravanthi_K_Intel
VPP Composition is available today in Windows and Linux. You can download the samples from here and sample_vpp example shows how to add composition. https://software.intel.com/en-us/intel-media-server-studio-support/code-samples
Please see this thread as well - https://software.intel.com/en-us/forums/topic/540105
On 3rd gen - No, VPP composition was not available. We recommend developers to implement the SW version of composition here.
____2
Thanks a lot.
And if I use Media SDK client in windows 7, Which version should I adopt?
Sravanthi_K_Intel
The latest Media SDK works on the OS you mention - so you can try that one.
I may have misunderstood your question - Can you kindly rephrase it?
____2
Thank you, SRAVANTHI K.
I means if I want to use VPP Composition in Windows 7, Which version of Media SDK shoud I adopt? And should I upgrade the drivers in windows 7?
Sravanthi_K_Intel
Hello there - The latest API available for Windows is 1.15 - so if you can download that version (the install process installs the required driver as well), that will work for composition.
