Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
3058 Discussions
Is VPP Composition available On 3rd Generation Intel Core Processors?
____2
Hi, Is VPP Composition available On 3rd Generation Intel Core Processors?
and Now Is VPP Composition available On windows platform?
Sravanthi_K_Intel
VPP Composition is available today in Windows and Linux. You can download the samples from here and sample_vpp example shows how to add composition. https://software.intel.com/en-us/intel-media-server-studio-support/code-samples
Please see this thread as well - https://software.intel.com/en-us/forums/topic/540105
On 3rd gen - No, VPP composition was not available. We recommend developers to implement the SW version of composition here.
____2
Thanks a lot.
And if I use Media SDK client in windows 7, Which version should I adopt?
Sravanthi_K_Intel
The latest Media SDK works on the OS you mention - so you can try that one.
I may have misunderstood your question - Can you kindly rephrase it?
____2
Thank you, SRAVANTHI K.
I means if I want to use VPP Composition in Windows 7, Which version of Media SDK shoud I adopt? And should I upgrade the drivers in windows 7?
Sravanthi_K_Intel
Hello there - The latest API available for Windows is 1.15 - so if you can download that version (the install process installs the required driver as well), that will work for composition.
