Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
JPEG Encoding greyscale image from buffer
Sid023
Hi all,
What i have to do is quite easy:
i just need to encode a simple bmp image 1 bytePerPixel in greyscale exploiting HW acceleration.
The image is already loaded in an array(unsigned char *) of w*h elements, where w and h are respectively the width and the size of the image.
As a first step i created a sample application to encode a single image based on files saved in samples/common of the Media sdk. This application is very simple and works properly as expected, but the problem is that it does not completely exploit hw acceleration, a warning message appears right after the encoder init() function.
After that i integrate in my application the vaapi allocator, always from the samples/common files, the warning message about the partial HW acceletion is no longer shown, the encoding time is improved, i got any other errors/warnings but the output image(saved to a file) doesn't make sense, it is just like a noise, it is made of white and black squares.
I'd like to ask you what i'm doing wrong in my code, and if you could recreate this simple application to encode a greyscale image contained in a buffer.
thanks for the support
AthiraM_Intel
Could you please share the below details:
  1. Media SDK Version
  2. OS you are using
  3. Sample reproducer code and the exact steps you followed
  4. Screenshots of the error
  5. What samples you are using from samples/common file
Sid023
thanks for reply me back.
The target device is based on Elkharth-Lake (Atom x6000E) and uses the intel Yocto image with pre-installed Media SDK and libVA (core-image-sato-sdk-intel-corei7-64).
I set MFX_CHROMAFORMAT_MONOCHROME as encoder chroma format and MFX_FOURCC_NV12 as FrameInfo.FourCC parameters.
When i use vaapi/sysmem allocator then the warning related the partial hw accelleration (after the encoder->init()) disappers, I don't get any error/warnings at all, but the output jpeg file is just like a noise (black and white squares).
If i don't use any allocators i get the partial acceleration warning but the output jpeg file is correct.
for the allocator part i use following files that i found in samples/common:
sysmem_allocator.cpp
vaapi_allocator.cpp
vaapi_device.cpp
common_vaapi.cpp
vaapi_utils_drm.cpp
I also tried the same code on my PC:
Intel i7-6600U
Mesa HD Graphic 520
Ubuntu 20.04 LST
Intel Media SDK 22.1.0
In both cases, using allocator and not using it, the result is the same: the program chrash during the following instruction;
session.SyncOperation(syncp, 60000)
with error:
/opt/src/msdk/_studio/mfx_lib/encode_hw/mjpeg/src/mfx_mjpeg_encode_vaapi.cpp:491: virtual mfxStatus MfxHwMJpegEncode::VAAPIEncoder::QueryStatus(MfxHwMJpegEncode::DdiTask&): Assertion `0x00000000 == vaSts' failed.
in this case if i use YUV420 as chromaFormat instead MONOCHROME, the program always run ok but the encoded output image is a GREEN-scale image and not a greyscale one.
Thanks in advance,
S.
AthiraM_Intel
Thanks for sharing the details.
Could you please share sample reproducer code and the exact steps you followed, so that we could try the same from our end.
Sid023
i just modify a bit the "simple_3_encode" example you provided in github, and i set the Y(luma) plane of the encoder surface with the input image buffer image buffer.
Of course i can share the mfxEncoder parameters:
params->mfx.CodecId = MFX_CODEC_JPEG;
params->mfx.FrameInfo.FrameRateExtN = 60;
params->mfx.FrameInfo.FrameRateExtD = 1;
params->IOPattern = MFX_IOPATTERN_IN_SYSTEM_MEMORY;
params->mfx.FrameInfo.FourCC = MFX_FOURCC_NV12;
params->mfx.FrameInfo.ChromaFormat = MFX_CHROMAFORMAT_MONOCHROME;
params->mfx.FrameInfo.PicStruct = MFX_PICSTRUCT_PROGRESSIVE;
params->mfx.FrameInfo.Width = MSDK_ALIGN16(imgWidth);
params->mfx.FrameInfo.Height = MSDK_ALIGN16(imgHeight)
params->mfx.FrameInfo.CropX = 0;
params->mfx.FrameInfo.CropY = 0;
params->mfx.FrameInfo.CropW = imgWidth;
params->mfx.FrameInfo.CropH = imgHeight;
// JPEG encoder settings overlap with other encoders settings in mfxInfoMFX structure
params->mfx.Interleaved = 1;
params->mfx.Quality = quality;
params->mfx.RestartInterval = 0;
I found an handy workarond to get correct output images and exploiting HW acceleration, but i think it is not optimized and the econding time could further reduce.
I set YUV420 as chromaFormat instead MONOCHROME as explained before, but this time in order to avoid green images i also set the value of UV plane to 128 even if it should not be needed since the image is a grayscale one.
memcpy(encoderSurfaces[i].Data.Y, imgBuffer, width * height)
memset(encoderSurfaces[i].Data.UV, 128, width * height / 2); // YUV420 workaround
With the UV plane set to 128 the images are grayscale ones, but this seems very strange to me, i'm working with 1byte grayscale images, the havent any other chroma information, just the brightness. Having set YUV420 of course takes into account also the UV plan and not only the Y one and doing this i believe the solution is not optimized.
I thought that using chroma format MONOCHROME whould have been better in terms of encoding time since it shouldn't take into account U, V planes, but when i use it i get images made of black and white squares.
Which would it be the best way(the faster one) to proceed in order to encode an image of 1 byte per pixel in greyscale without any other chroma info?
which are the correct encoder parameters?
Thanks in advance,
S.
Sid023
Do you have any news regarding the jpeg encoding of a monochrome image?
In my programe i'm encoding greyscale images of 1280X960 pixels, but i try to encode pictures of different size i get once again an output image that is like a noise. Are there some size limitations? Could you haelp me?
thanks
AthiraM_Intel
We are checking on it internally, will let you know the updates soon.
Sid023
thank you!
Do you have any updates?
Kevin_O_Intel1
This appears to be an issue with libVA. You can submit the issue here:
libva/CONTRIBUTING.md at aeba58590726ab08b924e6a2ad0078d74c5dd01b · intel/libva (github.com)
But I will do the same.
Sid023
Thanks for your reply.
Could you provide more details about this libVA issue?
