Joining videos together with rotation
Liron_K_
I have an app which records video from both the front and back camera, and I want to be able to stitch the videos together into one long video.
When I try this, (with the following code), any videos from the rear camera are flipped upside down.
Basically, what I think I need is a way to join the videos with setting a different rotation effect on the different video segments.
Additionally, the performance is pretty slow - is there a way to speed this up?
Liron
Code:
public Task<Void> mergeVideos(List<RecordedFileInfo> files, final File outputFile, Context c)
  final Task<Void>.TaskCompletionSource task = Task.create();
  IProgressListener progressListener = new IProgressListener()
    @Override
    public void onMediaStart()
      Logger.d(TAG, "onMediaStart", null);
    @Override
    public void onMediaProgress(float progress)
      final float mediaProgress = progress;
    @Override
    public void onMediaDone()
      Logger.d(TAG, "onMediaDone", null);
      if(outputFile.exists())
        Logger.d(TAG, "onMediaDone", "Success");
        task.setResult(null);
      else
        Logger.d(TAG, "onMediaDone", "Failed");
        task.setError(new Exception("Something went wrong during video merge"));
    @Override
    public void onMediaPause()
      Logger.d(TAG, "onMediaPause", null);
    @Override
    public void onMediaStop()
      Logger.d(TAG, "onMediaStop", null);
    @Override
    public void onError(Exception exception)
      Logger.LogException(TAG, "onError", exception);
      final Exception e = exception;
      task.setError(e);
  AndroidMediaObjectFactory factory = new AndroidMediaObjectFactory(c);
  MediaComposer composer = new MediaComposer(factory, progressListener);
  MediaFileInfo mediaFileInfo = null;
  long i = 0;
  try
    for(RecordedFileInfo f : files)
      //Get rotation
      File file = f.getFile();
      MediaMetadataRetriever retriever = new MediaMetadataRetriever();
      retriever.setDataSource(file.getAbsolutePath());
      String extractMetadata = retriever.extractMetadata(MediaMetadataRetriever.METADATA_KEY_VIDEO_ROTATION);
      int angle = Integer.parseInt(extractMetadata);
      android.net.Uri uri = android.net.Uri.fromFile(file);
      com.intel.inde.mp.Uri fileUri = new com.intel.inde.mp.Uri(uri.toString());
      composer.addSourceFile(fileUri);
      if(mediaFileInfo == null)
        composer.setTargetFile(outputFile.getAbsolutePath());
        mediaFileInfo = new MediaFileInfo(new AndroidMediaObjectFactory(c));
        mediaFileInfo.setUri(fileUri);
        AudioFormat af = (AudioFormat)mediaFileInfo.getAudioFormat();
        VideoFormat vf = (VideoFormat)mediaFileInfo.getVideoFormat();
        configureVideoEncoder(composer, vf, angle);
        configureAudioEncoder(composer, af);
      //Fix rotation;
      RotateEffect effect = new RotateEffect(angle, EglUtil.getInstance());
      effect.setSegment(new Pair<Long, Long>(0L, 0L));  // Apply to all stream
      composer.addVideoEffect(effect);
      i++;
    composer.start();
  catch(Exception ex)
    Logger.LogException(TAG, "Failed to setup video merger", ex);
    return Task.forError(ex);
  return task.getTask();
protected void configureVideoEncoder(MediaComposer mediaComposer, VideoFormat formatToCopy, int angle)
  VideoFormatAndroid targetFormat;
  Resolution frameSize = formatToCopy.getVideoFrameSize();
  String videoMimeType = formatToCopy.getMimeType();
  if(angle == 90 || angle == 270 || angle == -90)
    frameSize = new Resolution(frameSize.height(), frameSize.width());
  targetFormat = new VideoFormatAndroid(videoMimeType, frameSize.width(), frameSize.height());
  //TODO: Get this value from somewhere
  try
    targetFormat.setVideoBitRateInKBytes(formatToCopy.getVideoBitRateInKBytes());
  catch(RuntimeException ex)
    targetFormat.setVideoBitRateInKBytes(5000);//formatToCopy.getVideoBitRateInKBytes());
  try
    targetFormat.setVideoFrameRate(formatToCopy.getVideoFrameRate());
    targetFormat.setVideoFrameRate(30);
  try
    targetFormat.setVideoIFrameInterval(formatToCopy.getVideoIFrameInterval());
    targetFormat.setVideoIFrameInterval(1);
  targetFormat.setInteger(MediaFormat.KEY_MAX_INPUT_SIZE, 0);
  mediaComposer.setTargetVideoFormat(targetFormat);
protected void configureAudioEncoder(MediaComposer mediaComposer, AudioFormat formatToCopy)
  AudioFormatAndroid targetFormat;
  int sampleRate, channelCount;
  try
    sampleRate = formatToCopy.getAudioSampleRateInHz();
    sampleRate = 48000;
  try
    channelCount = formatToCopy.getAudioChannelCount();
    channelCount = 2;
  targetFormat = new AudioFormatAndroid(formatToCopy.getMimeType(), sampleRate, channelCount);
  try
    targetFormat.setAudioBitrateInBytes(formatToCopy.getAudioBitrateInBytes());
    targetFormat.setAudioBitrateInBytes(96 * 1024);
  try
    targetFormat.setAudioProfile(formatToCopy.getAudioProfile());
    targetFormat.setAudioProfile(MediaCodecInfo.CodecProfileLevel.AACObjectLC);//formatToCopy.getAudioProfile());
  mediaComposer.setTargetAudioFormat(targetFormat);
public class RotateEffect extends VideoEffect
  public RotateEffect(int angle, IEglUtil eglUtil)
    super(angle, eglUtil);
Harshdeep_B_Intel
We have Media for Mobile which includes feature support for joining two videos captured. You can download Media for Mobile from INDE here: https://software.intel.com/en-us/intel-inde and samples from https://software.intel.com/en-us/media-for-mobile-support/code-samples
You can align videos before using the joining feature from Media for mobile. Currently we do not support rotate feature effect. In regard to performance\fps differ from device to device in capturing scenario. Most of devices give normal performance, but there are several exceptions depending on the device.
Liron_K_
Please see the code in my original post. I am using Media for Mobile, but not getting the effect that I need.
Since the videos that I have as inputs have different rotations (the front camera is rotated 90 and the back camera is rotated 270) when I join them together without using the RotateEffect, the are both rotated sideways (in opposite directions). Once I add the Rotate effect, then the front camera is rotated correctly and the back camera is upside down.
Also, the code that I have above on a Samsung S4 takes about 10 seconds to run to join 2 10 second videos, which doesn't seem very good to me.
Sincerely,
Liron
Harshdeep_B_Intel
Can you please provide us the snapshots of the video when joined by using/not using RotateEffect. Let me check with our team and update you in regard to performance on a Samsung S4 device.
Liron_K_
Videos attached.
You can see that in either case, the output is wrong, unfortunately. The one input video has a rotation of 90 and the other one has a rotation of 270, which is what the android Camera is generating when doing the record.
Nikolay_A_Intel
Hi Liron,
In order to correct rotation you have to change
//Fix rotation;
to something like this:
//Fix rotation;
RotateEffect effect1 = new RotateEffect(<angle1>, EglUtil.getInstance());
effect1.setSegment(new FileSegment(0L, <duration1>));  // Apply to 1st stream
composer.addVideoEffect(effect1);
RotateEffect effect2 = new RotateEffect((<angle2>, EglUtil.getInstance());
effect2.setSegment(new FileSegment(<duration1>, <duration2>));  // Apply to 2nd stream
composer.addVideoEffect(effect2);
What performance do you really expect? 2x real-time seems quite good for me
