Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
MBBRC and lookahead
Michael_Schmidt
The MBBRC flag improves quality for my videos converted in VBR bitrate mode. When I set this flag in combination with lookahead there is no difference. Is it correct that mbbrc doesn't work with lookahead?
Anthony_P_Intel
Yes, you are correct.  The LookAhead algorithm does not use the MBBRC or ExtBRC options.  This is expected.
Michael_Schmidt
ExtBRC works with lookahead....but very very slow.
Nina_K_Intel
Hi Michael,
You report an interesting observation. The expected behavior is that if both ExtBRC and MFX_RATECONTROL_LA are enabled ExtBRC will be ignored and look ahead will work. There may be some bug in MSDK implementation though.  Could you please tell your driver and MSDK library versions and the exact encoder parameters config, preferably via MSDK Tracer log?
Thanks much,
Nina
Michael_Schmidt
Here an example for the command line: -h264 -w 1920 -h 1080 -extbrc 1 -b 5000 -lad 40 -rc 8 -u 4 -goprefdist 0 -goppicsize 0
This is valid for QSTranscode. LA and extbrc both enabled. When extbrc is set to 1 encoding speed slows down in a strong way. I would expect the same behaviour with Handbrake, although I haven't tried yet. My driver version is 15.31.16.64.3234. MBBRC on the other side will be ignored with Lookahead.
Michael_Schmidt
Same in Handbrake. So for Handbrake the command line with LA and extbrc is the following: lookahead=1:gop-ref-dist=3:gop-pic-size=0:target-usage=4:lookahead-depth=40:num-ref-frame=0:extbrc=1
Nina_K_Intel
Thanks Michael, that's enough for me to investigate. I'll get back with results.
Nina
Nina_K_Intel
Hi Michael,
My investigation shows that extBRC is ignored if LA is set, as it should be, but by the time in code where extBRC is actually dropped from config MSDK already mistakenly changed async depth parameter to 1 from the default 4. This leads to performance drop due to natural slowness of async=1 plus some inconsistency between application pipeline vs. internal task queue depths. This is definitely a bug in MSDK implementation and we are grateful to you for finding and reporting it. Will fix this in one of the nearest driver updates.
To prove my assumption I checked that "la+extbrc+async_depth=1" give same fps as "la+async_depth=1".
Nina
Michael_Schmidt
The newest driver solved it. Are there any other changes beside the extBRC/LA fix?
Petter_L_Intel
Hi Michael,
which driver version did you use?
Petter
Michael_Schmidt
15.33.1.64.3277
Petter_L_Intel
Hi Michael,
3277 (15.33 driver branch) is still not an officially released driver on Intel.com :(
15.33 driver is currently being developed and will have improvements mainly related to Windows 8.1.
Petter
Michael_Schmidt
The 15.33 driver I'm using is WHQL PV and from Intel. Driver releases from downloadcenter are badly outdated. After months no Lookahead. I learned soon or very soon means I don't know when.
Anthony_P_Intel
Yes, we agree and understand the frustration.  The issue of availability of newer drivers on intel.com has been escalated to appropriate teams.
Michael_Schmidt
http://download.gigabyte.eu/FileList/Driver/mb_driver_vga_intel_64_w8.1.exe
15.33.2.64.3282 from Gigabyte. I know from some devs that they prefer to download from downloadcenter and not from other sources which is a problem when there is still no API 1.7 driver.
