MFX Decoder Failing for sample video
Jordan_C_
I'm trying to decode an AVC stream from a sample file. The file is located at http://jell.yfish.us/ and is called jellyfish-50-mbps-hd-h264.mkv. I removed the MKV container using ffmpeg
ffmpeg.exe -i jellyfish-50-mbps-hd-h264.mkv -c:v copy X:\jellyfish.264
Feeding that file into sample_decode fails with error
Return on error: error code -10, src\pipeline_decode.cpp 642
This is using the SDK Samples version 2016 6.0.0.142. The sample plays correctly using VLC. What am I doing wrong?
-J
Jiandong_Z_Intel
Hi Jordan,
Can you check if MSDK sample_multi_transcode work for you ?
Can you also share log from system_analyzer tool located at (mediasdk/tools/analyzer) ? This will help provide us your system details.
Zachary
