Media (Intel® oneAPI Video Processing Library, Intel Media SDK)
Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
For the latest information on Intel’s response to the Log4j/Log4Shell vulnerability, please see Intel-SA-00646
2912 Discussions
MFX_ERR_GPU_HANG when using several decoding/encoding applications
OTorg
New Contributor III
Mark_L_Intel1
Thanks so much,
I can reproduce it with following error message, could you confirm? My environment is skull Cannon NUC and Windows 10, driver 6373.
Encoding Sample Version 8.4.27.378
Input file format       NV12
Output video            AVC
Source picture:
        Resolution      720x576
        Crop X,Y,W,H    0,0,720,576
Destination picture:
        Resolution      720x576
Frame rate      25.00
Bit rate(Kbps)  3000
Gop size        28
Ref dist        4
Ref number      4
Idr Interval    0
Target usage    speed
Memory type     system
Media SDK impl          hw
Media SDK version       1.27
Processing started
Frame number: 286800
[ERROR], sts=MFX_ERR_GPU_HANG(-21), CEncTaskPool::SynchronizeFirstTask, SyncOperation failed at src\pipeline_encode.cpp:157
[ERROR], sts=MFX_ERR_GPU_HANG(-21), CEncodingPipeline::GetFreeTask, m_TaskPool.SynchronizeFirstTask failed at src\pipeline_encode.cpp:1748
[ERROR], sts=MFX_ERR_GPU_HANG(-21), CEncodingPipeline::Run, m_pmfxENC->EncodeFrameAsync failed at src\pipeline_encode.cpp:1961
[ERROR], sts=MFX_ERR_GPU_HANG(-21), wmain, pPipeline->Run failed at src\sample_encode.cpp:1301
Frame number: 286872
Encoding fps: 227
C:\Users\test\Documents\Intel® Media SDK 2018 R2 - Media Samples 8.4.27.378\_bin\x64>
I didn't get it at the first run(about 20minutes), but I got it at the second run(about 30minutes) but I don't know when it happened since I saw it when I came back to screen.
It looks like 4 console spawned during the run time(see the attached screen capture), at the start, "Console 1" only spawned 2 consoles, and I think "console 4" and "console 5" were spawned after "console 2" and "console 3" crashed. When I came back, "console 5" was running but "console 4" was hanged.
I have submitted the bug and will keep you updated.
Mark
OTorg
New Contributor III
Hi Mark,
Yes, I confirm that this is the bug I was talking about.
OTorg
New Contributor III
Hi!
Is there any news on MFX_ERR_GPU_HANG fixing?
Mark_L_Intel1
Not yet, I will ask them to do a brief check. Could you check it again next Wednesday?
Mark
OTorg
New Contributor III
Yes, I can. Waiting for instructions...
Mark_L_Intel1
Hi Alek,
Sorry for the late response, I discuss with dev team about this issue and the original issue you reported. They start working on it now.
They will first check if these are bugs or not and if they are, they are going to fix them.
Mark
Mark_L_Intel1
Hi Alek,
My apology, I might miss responding to this issue, dev team had a suggestion:
They want to see if you can try MSS 2018-R2.3 and see if this release can solve the issue.
Again my apology for not updating the solution, can you make a try on this release?
Mark Liu
OTorg
New Contributor III
Hi Mark,
Where can I find windows binaries of that release?
Mark_L_Intel1
Sorry Alek,
This is my mistake, my post was not relevant to your issue.
For your issue, the latest update is, we started the investigation, it is at early stage and I will give you update when we found something.
Mark
BMart1
New Contributor II
Our Windows application that does several simultaneous real-time encodings also suffers from MFX_ERR_GPU_HANG, even with the latest driver version 27.20.100.8336. Any news regarding a fix?
Bruno
Luis_at_Intel
Hi @BMart1,
This issue is still under investigation, we will provide an update when available. Thank you for your patience.
Luis
Ref. 59912
Mark_L_Intel1
Hi Bruno,
This issue was reported and tracked very well. Based on the record, we had a discussion on it about June, we decided to delay it since the other urgent project and resume when our resources are available.
Is your GPU hang issue is the same as Alek? If it is different, you can submit a different request either on Forum or online support center.
Mark
BMart1
New Contributor II
Hi Mark,
It's hard to tell from the outside whether the issue is identical or not. Our app certainly is different. We do multiple real time encodes and get the same -21 error.
Bruno
Mark_L_Intel1
Hi Bruno,
Thanks for the comment.
Understood your situation. It should take time to create a reproducer, this would always be preferred so if you happen to have it, please post. Otherwise, I will focus on fixing this report.
I will add your comment to the report.
Mark
