MFX_ERR_INCOMPATIBLE_VIDEO_PARAM prolem?
andya
use linux media sdk:
i have a problem about MFX_ERR_INCOMPATIBLE_VIDEO_PARAM,why?
h264 stream-->decode(it's ok) -->vpp(sts = MFX_ERR_INCOMPATIBLE_VIDEO_PARAM),i don't know why return the error.
andya
Process:
(network stream)h264->decoder(nv12)->vpp(rgb32).
it's ok but when i revise the source stream width( 1156),vpp return MFX_ERR_INCOMPATIBLE_VIDEO_PARAM.
andya
this is source file.
andya
Anthony_P_Intel
The actual surface width and height have must be multiple of 16, but the "Crop" values can be use to describe the are of the surface that contain data of interest.
Width and height of the video frame in pixels; Width must be a multiple of 16. Height must be a multiple of 16 for progressive frame sequence and a multiple of 32 otherwise.
andya
thanks u repy now width height already multiple of 16 in code. i don't know where code the problem.
h264->nv12->rgb32
		sts = ReadBitStreamData1(&mfxBS, data, length);
                data = NULL;length = 0;
		//sts = ReadBitStreamData1(&mfxBS, _data, _data_end);
		LOG_INFO("line:%d,sts:%d",__LINE__, sts);
		MSDK_CHECK_RESULT(sts, MFX_ERR_NONE, sts);
		sts = pmfxDEC->DecodeHeader(&mfxBS, &mfxVideoParams);
		LOG_INFO("line:%d,sts:%d",__LINE__,sts );
		//mfxVideoParams.mfx.FrameInfo.FourCC=MFX_FOURCC_RGB4;
		//mfxVideoParams.mfx.JPEGColorFormat= MFX_CHROMAFORMAT_YUV444;
		//mfxVideoParams.mfx.JPEGColorFormat= MFX_JPEG_COLORFORMAT_RGB;
		MSDK_IGNORE_MFX_STS(sts, MFX_WRN_PARTIAL_ACCELERATION);
                mfxVideoParams.AsyncDepth = 1;
                printf(" AsyncDepth:%d\n", mfxVideoParams.AsyncDepth);
		// Validate video decode parameters (optional)
		//sts = pmfxDEC->Query(&mfxVideoParams, &mfxVideoParams);
		//MSDK_CHECK_RESULT(sts, MFX_ERR_NONE, sts);
		printf("xx w:%d,h:%d\n", mfxVideoParams.mfx.FrameInfo.CropW, mfxVideoParams.mfx.FrameInfo.CropH);
		// Initialize VPP parameters
		// - For simplistic memory management, system memory surfaces are used to store the raw frames
		//   (Note that when using HW acceleration D3D surfaces are prefered, for better performance)
		memset(&VPPParams, 0, sizeof(VPPParams));
		// Input data
		VPPParams.vpp.In.FourCC         = MFX_FOURCC_NV12;
		VPPParams.vpp.In.ChromaFormat   = MFX_CHROMAFORMAT_YUV420;
		VPPParams.vpp.In.CropX          = 0;
		VPPParams.vpp.In.CropY          = 0;
		VPPParams.vpp.In.CropW          = mfxVideoParams.mfx.FrameInfo.CropW;
		VPPParams.vpp.In.CropH          = mfxVideoParams.mfx.FrameInfo.CropH;
		VPPParams.vpp.In.PicStruct      = MFX_PICSTRUCT_PROGRESSIVE;
		VPPParams.vpp.In.FrameRateExtN  = 30;
		VPPParams.vpp.In.FrameRateExtD  = 1;
		// width must be a multiple of 16
		// height must be a multiple of 16 in case of frame picture and a multiple of 32 in case of field picture
		VPPParams.vpp.In.Width  = MSDK_ALIGN16(VPPParams.vpp.In.CropW);
		VPPParams.vpp.In.Height = (MFX_PICSTRUCT_PROGRESSIVE == VPPParams.vpp.In.PicStruct)?
			MSDK_ALIGN16(VPPParams.vpp.In.CropH) : MSDK_ALIGN32(VPPParams.vpp.In.CropH);
		// Output data
		VPPParams.vpp.Out.FourCC        = MFX_FOURCC_RGB4;
		VPPParams.vpp.Out.ChromaFormat  = MFX_CHROMAFORMAT_YUV420;
		VPPParams.vpp.Out.CropX         = 0;
		VPPParams.vpp.Out.CropY         = 0;
		//VPPParams.vpp.Out.CropW         = VPPParams.vpp.In.CropW/2;  // Resize to half size resolution
		//VPPParams.vpp.Out.CropH         = VPPParams.vpp.In.CropH/2;
		VPPParams.vpp.Out.CropW         = VPPParams.vpp.In.CropW;  // Resize to half size resolution
		VPPParams.vpp.Out.CropH         = VPPParams.vpp.In.CropH;
		VPPParams.vpp.Out.PicStruct     = MFX_PICSTRUCT_PROGRESSIVE;
		VPPParams.vpp.Out.FrameRateExtN = 30;
		VPPParams.vpp.Out.FrameRateExtD = 1;
		VPPParams.vpp.Out.Width  = MSDK_ALIGN16(VPPParams.vpp.Out.CropW);
		VPPParams.vpp.Out.Height = (MFX_PICSTRUCT_PROGRESSIVE == VPPParams.vpp.Out.PicStruct)?
			MSDK_ALIGN16(VPPParams.vpp.Out.CropH) : MSDK_ALIGN32(VPPParams.vpp.Out.CropH);
		VPPParams.IOPattern = MFX_IOPATTERN_IN_SYSTEM_MEMORY | MFX_IOPATTERN_OUT_SYSTEM_MEMORY;
		// Query number of required surfaces for decoder
		mfxFrameAllocRequest DecRequest;
		memset(&DecRequest, 0, sizeof(DecRequest));
		sts = pmfxDEC->QueryIOSurf(&mfxVideoParams, &DecRequest);
		// Query number of required surfaces for VPP
		mfxFrameAllocRequest VPPRequest[2];// [0] - in, [1] - out
		memset(&VPPRequest, 0, sizeof(mfxFrameAllocRequest)*2);
		sts = pmfxVPP->QueryIOSurf(&VPPParams, VPPRequest);
		// Determine the required number of surfaces for decoder output (VPP input) and for VPP output
		nSurfNumDecVPP = DecRequest.NumFrameSuggested + VPPRequest[0].NumFrameSuggested;
		nSurfNumVPPOut = VPPRequest[1].NumFrameSuggested;
		// Allocate surfaces for decoder and VPP In
		// - Width and height of buffer must be aligned, a multiple of 32
		// - Frame surface array keeps pointers all surface planes and general frame info
		mfxU16 width = (mfxU16)MSDK_ALIGN32(DecRequest.Info.Width);
		mfxU16 height = (mfxU16)MSDK_ALIGN32(DecRequest.Info.Height);
		mfxU8  bitsPerPixel = 12;  // NV12 format is a 12 bits per pixel format
		mfxU32 surfaceSize = width * height * bitsPerPixel / 8;
		surfaceBuffers = (mfxU8 *)new mfxU8[surfaceSize * nSurfNumDecVPP];
		pmfxSurfaces = new mfxFrameSurface1*[nSurfNumDecVPP];
		MSDK_CHECK_POINTER(pmfxSurfaces, MFX_ERR_MEMORY_ALLOC);
		for (int i = 0; i < nSurfNumDecVPP; i++)
			pmfxSurfaces = new mfxFrameSurface1;
			memset(pmfxSurfaces, 0, sizeof(mfxFrameSurface1));
			memcpy(&(pmfxSurfaces->Info), &(mfxVideoParams.mfx.FrameInfo), sizeof(mfxFrameInfo));
			pmfxSurfaces->Data.Y = &surfaceBuffers[surfaceSize * i];
			pmfxSurfaces->Data.U = pmfxSurfaces->Data.Y + width * height;
			pmfxSurfaces->Data.V = pmfxSurfaces->Data.U + 1;
			pmfxSurfaces->Data.Pitch = width;
		// Allocate surfaces for VPP Out
		width = (mfxU16)MSDK_ALIGN32(VPPRequest[1].Info.Width);
		height = (mfxU16)MSDK_ALIGN32(VPPRequest[1].Info.Height);
		bitsPerPixel = 32;  // RGB32 format is a 32 bits per pixel format
		surfaceBuffers2 = (mfxU8 *)new mfxU8[surfaceSize * nSurfNumVPPOut];
		pmfxSurfaces2 = new mfxFrameSurface1*[nSurfNumVPPOut];
		MSDK_CHECK_POINTER(pmfxSurfaces2, MFX_ERR_MEMORY_ALLOC);
		for (int i = 0; i < nSurfNumVPPOut; i++)
			pmfxSurfaces2 = new mfxFrameSurface1;
			memset(pmfxSurfaces2, 0, sizeof(mfxFrameSurface1));
			memcpy(&(pmfxSurfaces2->Info), &(VPPParams.vpp.Out), sizeof(mfxFrameInfo));
			pmfxSurfaces2->Data.B = &surfaceBuffers[surfaceSize * i];
			pmfxSurfaces2->Data.G = pmfxSurfaces2->Data.B + 1;
			pmfxSurfaces2->Data.R = pmfxSurfaces2->Data.B + 2;
			pmfxSurfaces2->Data.A = pmfxSurfaces2->Data.B + 3;
			pmfxSurfaces2->Data.Pitch = width*4;
			//pmfxSurfaces2->Data.Y = &surfaceBuffers[surfaceSize * i];
			//pmfxSurfaces2->Data.U = pmfxSurfaces2->Data.Y + width * height;
			//pmfxSurfaces2->Data.V = pmfxSurfaces2->Data.U + 1;
			//pmfxSurfaces2->Data.Pitch = width;
		// Initialize the Media SDK decoder
		sts = pmfxDEC->Init(&mfxVideoParams);
		// Initialize Media SDK VPP
		sts = pmfxVPP->Init(&VPPParams);
                printf("vpp iw:%d,ih:%d,ow:%d,oh:%d\n", VPPParams.vpp.In.Width, VPPParams.vpp.In.Height, VPPParams.vpp.Out.Width, VPPParams.vpp.Out.Height);
		// Start decoding the frames from the stream
		head_flag =1;
#ifdef ENABLE_BENCHMARK
		LARGE_INTEGER tStart, tEnd;
		QueryPerformanceFrequency(&tStart);
		double freq = (double)tStart.QuadPart;
		QueryPerformanceCounter(&tStart);
#endif
	// Stage 1: Main decoding loop
        if(sts == MFX_ERR_INCOMPATIBLE_VIDEO_PARAM)
            sts = pmfxVPP->Reset(&VPPParams);
            return 0;
	while (MFX_ERR_NONE <= sts || MFX_ERR_MORE_DATA == sts || MFX_ERR_MORE_SURFACE == sts)
		if (MFX_WRN_DEVICE_BUSY == sts)
			sleep(1/1000); // Wait if device is busy, then repeat the same call to DecodeFrameAsync
		if (MFX_ERR_MORE_DATA == sts)
            ++nframe;
			//printf("nframe:%d\r\n",nframe++);
                        //sts = ReadBitStreamData(&mfxBS, fSource); // Read more data into input bit stream
			data = NULL; length = 0;
			MSDK_BREAK_ON_ERROR(sts);
		if (MFX_ERR_MORE_SURFACE == sts || MFX_ERR_NONE == sts)
			nIndex = GetFreeSurfaceIndex(pmfxSurfaces, nSurfNumDecVPP); // Find free frame surface
			MSDK_CHECK_ERROR(MFX_ERR_NOT_FOUND, nIndex, MFX_ERR_MEMORY_ALLOC);
		// Decode a frame asychronously (returns immediately)
		sts = pmfxDEC->DecodeFrameAsync(&mfxBS, pmfxSurfaces[nIndex], &pmfxOutSurface, &syncpD);
		// Ignore warnings if output is available,
		// if no output and no action required just repeat the DecodeFrameAsync call
		if (MFX_ERR_NONE < sts && syncpD)
			sts = MFX_ERR_NONE;
		if (MFX_ERR_NONE == sts)
                        //printf("decode w:%d,h:%d\n", pmfxOutSurface->Info.CropW, pmfxOutSurface->Info.CropH);
			nIndex2 = GetFreeSurfaceIndex(pmfxSurfaces2, nSurfNumVPPOut); // Find free frame surface
			MSDK_CHECK_ERROR(MFX_ERR_NOT_FOUND, nIndex2, MFX_ERR_MEMORY_ALLOC);
			for (;;)
				// Process a frame asychronously (returns immediately)
				sts = pmfxVPP->RunFrameVPPAsync(pmfxOutSurface, pmfxSurfaces2[nIndex2], NULL, &syncpV);
				if (MFX_ERR_NONE < sts && !syncpV) // repeat the call if warning and no output
						sleep(1/1000); // wait if device is busy
				else if (MFX_ERR_NONE < sts && syncpV)
					sts = MFX_ERR_NONE; // ignore warnings if output is available
					break;
				else
					break; // not a warning
			// VPP needs more data, let decoder decode another frame as input
				continue;
			else if (MFX_ERR_MORE_SURFACE == sts)
				// Not relevant for the illustrated workload! Therefore not handled.
				// Relevant for cases when VPP produces more frames at output than consumes at input. E.g. framerate conversion 30 fps -> 60 fps
				break;
			else{
			sts = mfxSession.SyncOperation(syncpV, 60000); // Synchronize. Wait until decoded frame is ready
			++nFrame;
			LOG_INFO("SUCESS W:%d,H:%d,P:%d\n", pmfxSurfaces2[nIndex2]->Info.CropW, pmfxSurfaces2[nIndex2]->Info.CropH, pmfxSurfaces2[nIndex2]->Data.Pitch);
                        if(flag)
                            printf("loss!\n");
                        else
			    CopyRGB32(pmfxSurfaces2[nIndex2]->Data.B,(uint32_t*)_frame,pmfxSurfaces2[nIndex2]->Info.CropW,pmfxSurfaces2[nIndex2]->Info.CropH,pmfxSurfaces2[nIndex2]->Data.Pitch);
			return 1;
andya
i found the problem,decode init (width height ) not equal vppinit(width height),decode height > vpp height 16bit,i don't know why.
i fix code:
VPPParams.vpp.In.Width  = mfxVideoParams.mfx.FrameInfo.Width;
VPPParams.vpp.In.Height = mfxVideoParams.mfx.FrameInfo.Height;
