The RunEncode() function returned MFX_ERR_NOT_INITIALIZED when I tried to encode a video stream using the h264_enc_filter.
It was the function EncodeFrameAsync() that returned MFX_ERR_NOT_INITIALIZED.
The video capture source has a resolution of 1280*720@50frame/s and the color format is YUY2.
The graph can be run by inserting a AVI Decompressor between Infinite Pin Tee and H264 Encoder, the AVI Decompressor actually changed the color format from YUY2 to RGB32.
What was going wrong with my graph?
Tony Pabon (Intel) wrote:Hi,Tony I had recalled a piece of important information that I didn’t think of before. Due to my own need, I had cancelled if(nMin > (mfxU32)props.cBuffers) { hr = E_FAIL; } in CEncoderInputPin::NotifyAllocator() method.(My post with this issue: http://software.intel.com/en-us/forums/topic/339247) This works fine with my webcam. But the video source was replaced by a hd video capture card this time(as you can see in capturegraph.png). Today, I rebuilt the filter by bringing the buffer number judgment statement back to the NotifyAllocator() method. Now graphedit automatically inserts a AVI Compressor everytime I tried to connect Infinite_Pin_Tee_Filter to h264_enc_filter . I think this implied that Infinite_Pin_Tee_Filter and h264_enc_filter failed to make an agreement(mMin>cBuffers) on the allocator. This is why on yesterday I could directly connect Infinite_Pin_Tee_Filter to h264_enc_filter but the encoder returned an error in runtime. How can I modify the Infinite_Pin_Tee_Filter to collaborate with h264_enc_filter directly and perfectly?(Fortunately, Mircosoft provides the sample code for the infinite_pin_tee in Windows SDK. ).I don't want the existance of AVI Decompressor because it takes a great CPU load. Many thanks. -PatrickHi,
I believe I've reproduced the same issue and I'm investigating.-Tony
Tony Pabon (Intel) wrote:Hi,Tony I had just roughly gone through the infinite_pin_tee source code and discovered that it has overloaded the DecideAllocator() method and it assigned the allocator to the one from the upstream. I will upgrade this post if I make any progress. Thank you. -PatrickHi Patrick,
This would explain some of the behavior I was seeing too. I see others have seen this issue as well (http://software.intel.com/en-us/forums/topic/311877). I suspect the Infinite_Pin_Tee_Filter could be modified to require more cBuffers from the source filter, but I am not familiar with that code.
-Tony
Tony Pabon (Intel) wrote:Hi, I have modified the inifinite pin tee filter to require more buffers in the following code: STDMETHODIMP CTeeInputPin::NotifyAllocator(IMemAllocator *pAllocator, BOOL bReadOnly) { CheckPointer(pAllocator,E_FAIL); CAutoLock lock_it(m_pLock); // Free the old allocator if any if (m_pTee->m_pAllocator) m_pTee->m_pAllocator->Release(); // Store away the new allocator pAllocator->AddRef(); m_pTee->m_pAllocator = pAllocator; //Require 10 buffers ALLOCATOR_PROPERTIES props; pAllocator->GetProperties(&props); props.cBuffers = 10; ALLOCATOR_PROPERTIES actual; pAllocator->SetProperties(&props,&actual); // Notify the base class about the allocator return CBaseInputPin::NotifyAllocator(pAllocator,bReadOnly); } // NotifyAllocator The MFX_ERR_NOT_INITIALIZED error still occurs after the graph starts. (EncodeFrameAsync returns MFX_ERROR_NONE for several times before it returns MFX_ERR_NOT_INITIALIZED). It seems that the samples have not been released in the CBaseEncoder::DeliverNextFrame() method. The running code has not stepped into the sample release statements before the error is thrown. if (!jt->pmfxSurface->Data.Locked) { MSDK_SAFE_DELETE(jt->pmfxSurface); jt->pSample->Release();//has not been executed before MFX_ERR_NOT_INITIALIZED error pEncoder->m_InputList.erase(jt); break; } I’ve uploaded the inftee project files for you to investigate my problem. What else should I do to the inftee filter? Thanks. -PatrickHi Patrick,
-Tony
