Hi all,
I am using MediaServerStudioEssentials2017R3 on CentOS Linux release 7.3.1611 (Core).
I am able to run sample decode applicaition with -sw but getting error with -hw option.
Any help will be appreciated. Please check below snapshot for logs.
[user@localhost Downloads]$ python sys_analyzer_linux.py -v
Hardware readiness checks:
[ OK ] Processor name: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
[ INFO ] Intel Processor
[ INFO ] Processor brand: Core
[ INFO ] Processor arch: Skylake
OS readiness checks:
[ INFO ] GPU PCI id : 1912
[ INFO ] GPU description: SKL DT GT2
[ OK ] GPU visible to OS
[ INFO ] no nomodeset in GRUB cmdline (good)
[ INFO ] Linux distro : CentOS Linux 7.3.1611
[ INFO ] Linux kernel : 3.10.0-514.26.2.el7.x86_64
[ INFO ] glibc version : 2.17
[ INFO ] Linux distro suitable for Generic install
[ INFO ] gcc version : 4.8.5-11) (>=4.8.2 suggested)
Media Server Studio Install:
[ OK ] user in video group
[ OK ] libva.so.1 found
[ INFO ] Intel iHD used by libva
[ OK ] vainfo reports valid codec entry points
[ INFO ] i915 driver in use by Intel video adapter
[ OK ] /dev/dri/renderD128 connects to Intel i915
Component Smoke Tests:
[ OK ] Media SDK HW API level:1.23
[ OK ] Media SDK SW API level:1.23
[ OK ] OpenCL check:platform:Intel(R) OpenCL GPU OK CPU OK
// Sample test with sw
[ankit@localhost x64]$ ./sample_decode h264 -i out.264 -o /home/ankit/out1.yuv -sw
Decoding Sample Version 8.0.24.698
Input video AVC
Output format NV12
Input:
Resolution 3840x2160
Crop X,Y,W,H 0,0,0,0
Output:
Frame rate 30.00
Memory type system
MediaSDK impl sw
MediaSDK version 1.23
Decoding started
Frame number: 751, fps: 13.769, fread_fps: 0.000, fwrite_fps: 14.0504
Decoding finished
// Sample test with hw
[user@localhost x64]$ ./sample_decode h264 -i out.264 -o /home/user/out1.yuv -hw
libva info: VA-API version 0.99.0
libva info: va_getDriverName() returns 0
libva info: User requested driver 'iHD'
libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so
libva info: Found init function __vaDriverInit_0_32
libva info: va_openDriver() returns 0
[ERROR], sts=MFX_ERR_UNSUPPORTED(-3), Init, m_pmfxDEC->Init failed at /home/lab_msdk/buildAgentDir/buildAgent_MediaSDK1/git/mdp_msdk-lib/samples/sample_decode/src/pipeline_decode.cpp:446
[ERROR], sts=MFX_ERR_UNSUPPORTED(-3), main, Pipeline.Init failed at /home/lab_msdk/buildAgentDir/buildAgent_MediaSDK1/git/mdp_msdk-lib/samples/sample_decode/src/sample_decode.cpp:719
Hi Ankit,
Do other codecs like mpeg2 or HEVC work well in hw mode on your machine?
Best wishes,
Anna
JPEG also doesn't work with -hw.
And h265 doesn't work with sw as well.
Ankit
Hi Ankit,
How did you install Media Server Studio? It seems like you have wrong kernel. You need to install 3.10.0-514.el7.x86_64 kernel.
That's expected that h265 doesn't work in -sw mode, because sw implementation is available only in Intel(R) Media Server Studio Professional Edition (you have Essentials edition).
Best wishes,
Anna
