Hi ,
When i run the sample decode example i get the below error:
./sample_decode h264 -i ../content/test_stream.264 -o output.yuv -hw
[ERROR], sts=MFX_ERR_UNSUPPORTED(-3), Init, m_pmfxDEC->Init failed at /home/lab_msdk/buildAgentDir/buildAgent_MediaSDK3/git/mdp_msdk-samples/samples/sample_decode/src/pipeline_decode.cpp:436
[ERROR], sts=MFX_ERR_UNSUPPORTED(-3), main, Pipeline.Init failed at /home/lab_msdk/buildAgentDir/buildAgent_MediaSDK3/git/mdp_msdk-samples/samples/sample_decode/src/sample_decode.cpp:681
Quick help will be highly appreciated.
Following are the system details:
Hardware readiness checks:
[ OK ] Processor name: Intel(R) Core(TM) i3-6100 CPU @ 3.70GHz
[ INFO ] Intel Processor
[ INFO ] Processor brand: Core
[ INFO ] Processor arch: Skylake
OS readiness checks:
[ INFO ] GPU PCI id : 1912
[ INFO ] GPU description: SKL DT GT2
[ OK ] GPU visible to OS
[ INFO ] no nomodeset in GRUB cmdline (good)
[ INFO ] Linux distro : Ubuntu 16.04
[ INFO ] Linux kernel : 4.4.47
[ INFO ] glibc version : 2.23
[ INFO ] gcc version : 20160609 (>=4.8.2 suggested)
[ INFO ] /dev/dri/card0 : YES
[ INFO ] /dev/dri/renderD128 : YES
Intel(R) Media Server Studio Install:
[ OK ] user in video group
[ OK ] libva.so.1 found
[ INFO ] Intel iHD used by libva
[ OK ] vainfo reports valid codec entry points
[ INFO ] i915 driver in use by Intel video adapter
[ OK ] /dev/dri/renderD128 connects to Intel i915
Media SDK Plugins available:
(for more info see /opt/intel/mediasdk/plugins/plugins.cfg)
HEVC Decoder = 15dd936825ad475ea34e35f3f54217a6
HEVC Encoder = e5400a06c74d41f5b12d430bbaa23d0b
HEVC Encoder = 2fca99749fdb49aeb121a5b63ef568f7
Component Smoke Tests:
[ OK ] Media SDK HW API level:1.19
[ OK ] Media SDK SW API level:1.19
[ OK ] OpenCL check:platform:Intel(R) OpenCL GPU OK CPU OK
Hi raghaw,
Did you applied the kernel patches and rebuild the kernel?
According to this article for the generic installation process, the kernel must be rebuilt.
The other issue is, Ubuntu installation is never fully supported and validated, according to the article, we only testes in SkyLake + Kernel 4.4 + MSS2017 or Broadwell + Kernel 3.14.5 + MSS 2016 combinations, but even these conditions are satisfied, it still could be failed.
I suggest to try the CentOS 7.2.1511 distribution with the gold installation for a reliable result.
Mark
