I'm trying to decode audio data encoded by MFXAudioENCODE->EncodeFrameAsync but MFXAudioDECODE->DecodeFrameAsync just keep returning MFX_ERR_MORE_DATA.
This is my code:
HRESULT AudioDecoder::Decode(BYTE *data/*data encoded by encoder(bitstream.data)*/, INT64 dataLength/*data length(bitstream.datalength)*/, UINT64 timestamp/*timestamp(bitstream.datalength)*/)
{//This method will be called wheen encoded data generated. Audio data is being captured and encoded in realtime
mfxStatus res;
mfxAudioFrame frame;
mfxBitstream bitstream;
memset(&frame, 0, sizeof(mfxAudioFrame));
memset(&bitstream, 0, sizeof(mfxBitstream));
bitstream.MaxLength = dataLength;
bitstream.DecodeTimeStamp = timestamp;
bitstream.TimeStamp = timestamp;
bitstream.Data = data;
frame.TimeStamp = timestamp;
I tried to write the data into a file named xxx.acc in here and it can played by player.
General
Complete name : C:\xxx.aac
Format : ADTS
Format/Info : Audio Data Transport Stream
File size : 206 KiB
Overall bit rate mode : Variable
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format version : Version 2
Format profile : LC
Bit rate mode : Variable
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 spf)
Compression mode : Lossy
Stream size : 206 KiB (100%)
res = m_mFXAudioDECODE->DecodeFrameAsync(&bitstream, &frame, &m_syncpoint);//This function just keep returning MFX_ERR_MORE_DATA
if (res) {
if (res == MFX_ERR_MORE_DATA) {
printf("Error: The function requires more data to generate any output{MFX_ERR_MORE_DATA[0x%08X(%d)]}.\n", res, res);
else if (res == MFX_ERR_MORE_BITSTREAM) {
printf("Error: The function requires more bitstream buffers to store output{MFX_ERR_MORE_BITSTREAM[0x%08X(%d)]}.\n", res, res);
else if (res == MFX_ERR_NOT_ENOUGH_BUFFER) {
printf("Error: The output bitstream buffer size is insufficient{MFX_ERR_NOT_ENOUGH_BUFFER[0x%08X(%d)]}.\n", res, res);
else {
printf("Error: cannot decode audio frame[0x%08X(%d)].\n", res, res);
res = m_mFXSession.SyncOperation(m_syncpoint, INFINITE);
if (res) {
printf("Error: cannot sync operations[0x%08X(%d)].\n", res, res);
return S_OK;
What's wrong with my code?
Thank you.
