Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
MFXClose throws exception
Jordan_C_
I get the following exception when trying to close my MFX session.
The stack trace is
I am able to "continue" from this exception, but it's very annoying. What am I doing wrong?
I'm using MFX 1.17 on Windows x64. The stack trace indicates that it may have something to do with freeing surfaces. I'm using custom allocated system memory surfaces that I manually destroy before calling Close. Is that wrong?
-Jordan
Jordan_C_
The issue appears to go away when I initialize the session with MFX_IMPL_VIA_D3D11. I suspect there's a bug in the teardown implementation for D3D9.
James_B_9
Is this on Skylake?  I get the same problem, which resolves itself if I switch to DirectX 11.  I also found that using
mfxInitParam::GPUCopy = MFX_GPUCOPY_OFF
removed the problem, does this work for you?
James.
Jordan_C_
Yes, this is on a Skylake. I tried your fix and that also works for me. Good find. I'm not sure which is the preferable fix.
Surbhi_M_Intel
Thanks Jordan and James for reporting this issue, we will check at our end and fix this bug,
-Surbhi
