Hello.
Source code example in the
Intel_Media_Developers_Guide.pdf, 4.3.5 Query version and implementation
contains two insignificant syntax errors (Maybe its already corrected in the latest releases of sdk).
But the real confusion is it reports wrong version on the different hardware. On some CPU i get strange API version numbers after MFXQueryVersion even with MFX_ERR_NONE status is returned. I use MFXQueryVersion to detect highest supported API level and later try to initialize session using this versions, As a result MFXInit fails. I wondering whats wrong?
Hi Anton,
Thank you for your question. Currently the highest API level is 1.10, which is being used by developers for the development and is not supported yet. In general it would be good to use the lowest version possible depending upon the functionality you need. Version 1.9 is the highest version which can be used today.
Regarding the wrong version being reported on different hardware-
When you print the version, it prints the highest version(which is available), not what we is being currently used in the program. It is kind of check that tells us the highest available API version. I hope i have got you right, but feel free to let us know if the issue is different.
-Surbhi
Hi. Still confused a little bit. When you say "which is available" does this mean "can be supported on some hardware" or "this SHOULD work on this cpu which i am running"?
BTW, if MFXQuery does not return the highest API level "supported on this cpu" how can i find the highest supported level? Calling MFXInit increasing the version numbers (and clean up ofcourse) and stop when fail?
WBR
Hi Anton,
The highest version which is available by Media SDK, not necessarily that it will run on your HW.
To check the capabilities on your HW, Check the mediasdk_sys_analyzer which can be found in <downloaded folder>\tools\mediasdk_sys_analyzer. You can a readme document in that folder giving a basic overview about that tool. This should tell you the API version which are supported by your HW and SW.
-Surbhi
Thank you for clarification.
