I'm using the INDE Media SDK, 6.0.0.388 and using the encoder API for a real time video streaming application. Encoding runs fine for about 15 minutes but after that calls to MFXVideoCore_SyncOperation() keeps returning MFX_WRN_IN_EXECUTION. When I use a 'wait' of e.g. 60000 as used in the tutorials (mediasdk-tutorials-0.0.3/simple_3_encode_vmem_async) the call will block until it times out after 60 seconds. Waiting for 60 seconds for a real time stream is of course not usable and therefore I've set the wait parameter to MFXVideoCode_SyncOperation() to 10 ms. When I use 10ms, I keep receiving MFX_WRN_IN_EXECUTION.
My encode function looks like this (I removed some redundant checks):
int VideoEncoderQuickSync::encode(MediaPacket* pkt) { uint32_t size = 0; uint8_t* size_ptr = NULL; mfxStatus status = MFX_ERR_NONE; VideoEncoderQuickSyncTask* task = NULL; VideoEncoderQuickSyncSurface* surf = NULL; VideoFrameEncoded encoded_frame; if (0 != getFreeTask(&task)) { /* When there are now free tasks, we sync. Because we're doing a conference video stream we cannot wait forever; 10ms is more the max. */ task = tasks[task_dx]; status = MFXVideoCORE_SyncOperation(session, task->syncpoint, 10); if (MFX_ERR_NONE != status) { /* Dropping frame, this is where we always get MFX_WRN_IN_EXCECUTION. */ pkt->makeFree(); return 0; } else { task_dx = (task_dx + 1) % tasks.size(); if (0 != writeEncodedTask(task)) { /* Never happens. */ return -7; } /* Reset the bitstream and syncpoint. When we don't reset the bitstream we get MFX_ERR_NOT_ENOUGH_BUFFER results when calling MFXVideoENCODE_EncodeFrameAsync */ task->syncpoint = NULL; task->bitstream.DataLength = 0; task->bitstream.DataOffset = 0; task->bitstream.TimeStamp = 0; task->bitstream.DecodeTimeStamp = 0; /* At this point we freed up a task, so getFreeTask() receives a free one and we can continue execution. */ task = NULL; if (0 != getFreeTask(&task)) { SX_ERROR("Even after syncing we couldn't get a free task."); return -9; } } } /* Get a free surface. We have our own struct which has a surface and pkt member. The surface member is mfxFrameSurface1. The pkt member is a pointer to the raw input data (NV12). We need to keep these together so we know when we can reuse the pkt again. */ if (0 != getFreeSurface(&surf)) { SX_ERROR("Failed to get a free surface."); return -8; } if (NULL != surf->pkt) { /* When we found a free surface, we can make reuse the previously set pkt member with NV12, so we can reuse it in the application again. */ surf->pkt->makeFree(); } /* Wrap the input pkt into the surface. */ surf->surface->Data.Y = pkt->video_plane[0]; surf->surface->Data.UV = pkt->video_plane[1]; surf->surface->Data.TimeStamp = pkt->pts; surf->surface->Data.Pitch = pkt->video_width[0]; /* @todo use PitchLow / PitchHigh */ surf->pkt = pkt; for (;;) { status = MFXVideoENCODE_EncodeFrameAsync(session, NULL, surf->surface, &task->bitstream, &task->syncpoint); if (MFX_ERR_NONE < status && !task->syncpoint) { if (MFX_WRN_DEVICE_BUSY == status) { /* Sleep a bit here ... (never happens) */ sleep_millis(1); } } else if (MFX_ERR_NONE < status && task->syncpoint) { status = MFX_ERR_NONE; break; } else if (MFX_ERR_NOT_ENOUGH_BUFFER == status) { SX_ERROR("Bitstream buffer size is insufficient."); break; } else { break; } } return 0; }
What am I doing wrong? and how can I solve this?
Thanks!
I've got a small update for this issue. I'm pretty sure this issue is caused by either a misunderstanding of the encoder parameters or a bug in the encoders itself. When I change the encoder parameters to "low latency" parameters as used in the smiple_encode_vmem_lowlat.cpp example everything works great and I've tested streaming for 2 hours w/o any issues.
I'll paste the settings below that work, though I would love to hear some feedback about this; I'm curious why / what is causing this.
mfxVideoParam mfxEncParams; memset(&mfxEncParams, 0, sizeof(mfxEncParams)); mfxEncParams.mfx.CodecId = MFX_CODEC_AVC; mfxEncParams.mfx.TargetUsage = MFX_TARGETUSAGE_BALANCED; mfxEncParams.mfx.TargetKbps = options.values.Bitrate; mfxEncParams.mfx.RateControlMethod = MFX_RATECONTROL_VBR; mfxEncParams.mfx.FrameInfo.FrameRateExtN = options.values.FrameRateN; mfxEncParams.mfx.FrameInfo.FrameRateExtD = options.values.FrameRateD; mfxEncParams.mfx.FrameInfo.FourCC = MFX_FOURCC_NV12; mfxEncParams.mfx.FrameInfo.ChromaFormat = MFX_CHROMAFORMAT_YUV420; mfxEncParams.mfx.FrameInfo.PicStruct = MFX_PICSTRUCT_PROGRESSIVE; mfxEncParams.mfx.FrameInfo.CropX = 0; mfxEncParams.mfx.FrameInfo.CropY = 0; mfxEncParams.mfx.FrameInfo.CropW = options.values.Width; mfxEncParams.mfx.FrameInfo.CropH = options.values.Height; mfxEncParams.mfx.FrameInfo.Width = MSDK_ALIGN16(options.values.Width); mfxEncParams.mfx.FrameInfo.Height = (MFX_PICSTRUCT_PROGRESSIVE == mfxEncParams.mfx.FrameInfo.PicStruct) ? MSDK_ALIGN16(options.values.Height) : MSDK_ALIGN32(options.values.Height); mfxEncParams.IOPattern = MFX_IOPATTERN_IN_VIDEO_MEMORY; // Configuration for low latency mfxEncParams.AsyncDepth = 1; mfxEncParams.mfx.GopRefDist = 1; mfxExtCodingOption extendedCodingOptions; memset(&extendedCodingOptions, 0, sizeof(extendedCodingOptions)); extendedCodingOptions.Header.BufferId = MFX_EXTBUFF_CODING_OPTION; extendedCodingOptions.Header.BufferSz = sizeof(extendedCodingOptions); extendedCodingOptions.MaxDecFrameBuffering = 1; mfxExtBuffer* extendedBuffers[1]; extendedBuffers[0] = (mfxExtBuffer*) & extendedCodingOptions; mfxEncParams.ExtParam = extendedBuffers; mfxEncParams.NumExtParam = 1;
The following parameters is what I changed to make encoding work for long periods:
mfxEncParams.AsyncDepth = 1; mfxEncParams.mfx.GopRefDist = 1; extendedCodingOptions.MaxDecFrameBuffering = 1;
Any ideas what may cause the issue what I described in my previous post?
D
