Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
2946 Discussions
MPEG2 Encoder failed to initialize due to too low (?) TargetKbps
koby_s_
Hi
I am trying to encode a yuv file to mpeg2 with sample_encode but I keep getting error -14 ( = MFX_ERR_INCOMPATIBLE_VIDEO_PARAM ).
I tried both with software and hardware implementations.
The command line I used:
Software:
sample_encode.exe mpeg2 -i n6000k.yuv -f 29.97 -b 500 -w 1280 -h 720 -sw -o a.mpg2
Return on error: error code -14,        src\pipeline_encode.cpp 1202
Return on error: error code -14,        src\pipeline_encode.cpp 1117
Return on error: error code 1,  src\sample_encode.cpp   744
Frame number: 0
Hardware:
sample_encode.exe mpeg2 -i n6000k.yuv -f 29.97 -b 500 -w 1280 -h 720 -hw -o a.mpg2
Frame number: 0
The problem is solved if I increase the bitrate (software starts to work with 720kbps and hardware start to work with 616 kbps) or if i change the destination resolution and keep the bitrate
Is there any bitrate limitation in the mpeg2 encoder?
Attached is h264 source that I decoded using sample_decode and used its YUV output as input to the sample_encode.
I am using a Core i7-3632QM machine with intel HD Graphics 4000, windows 10
Thank you
Koby
Jiandong_Z_Intel
Hi Koby,
Can you share log from system_analyzer tool located at (mediasdk/tools/analyzer) ? This will help provide your system details.
Zachary
koby_s_
sure
This error is also happened on Core i7-4790R, using sw/hw implementations.
Thank you
koby
Jiandong_Z_Intel
Hi Koby,
Thanks for your information. I can reproduce this issue.
I am checking with MSDK dev team. I will get back soon.
Zachary
koby_s_
Thank you
Waiting for their response
Koby
koby_s_
Hi Zachary
Is there any update?
Thank you
Jiandong_Z_Intel
Hi Koby,
Currently, no update from dev team.
Can you check if following change work for you ?
diff --git a/samples/sample_encode/src/pipeline_encode.cpp b/samples/sample_encode/src/pipeline_encode.cpp
index b406c9e..e5ee494 100644
--- a/samples/sample_encode/src/pipeline_encode.cpp
+++ b/samples/sample_encode/src/pipeline_encode.cpp
@@ -442,8 +442,9 @@ mfxStatus CEncodingPipeline::InitMfxEncParams(sInputParams *pInParams)
         m_CodingOption2.LookAheadDepth = pInParams->nLADepth;
         m_CodingOption2.MaxSliceSize   = pInParams->nMaxSliceSize;
         m_CodingOption2.BRefType = pInParams->nBRefType;
-        m_EncExtParams.push_back((mfxExtBuffer *)&m_CodingOption2);
+    m_CodingOption2.BitrateLimit = MFX_CODINGOPTION_OFF;
+    m_EncExtParams.push_back((mfxExtBuffer *)&m_CodingOption2);
     // In case of HEVC when height and/or width divided with 8 but not divided with 16
Zachary
koby_s_
Hi Zachary
Sorry for the late response.
I applied the code changes but unfortunately it didn't help.
Koby
Jiandong_Z_Intel
Hi Koby,
Sorry for late reply. following may help -
While you can limit bitrate generated by MPEG-2 Encoder by manipulating bitrate settings and VBV parameters, at certain point you’ll get major mosaic-like corruptions in output stream.  We have following remarks on this topic in Release Notes:
  • The MPEG-2 encoder may produce output that under-runs the MPEG-2 video buffer
    verifier model (VBV) on some streams. We suggest the following guideline of the
    parameter values to be followed to keep VBV compliance.
    § MPEG2 buffer usage is mainly restricted by the number of bits used for I
    frame. The minimum size of each 16x16 blocks of intra frame at highest QP is
    about 50 bits. The minimum initial buffer fullness (InitVBVBufferFullnessInBit)
    should be at least twice the size of the initial I frame, and the minimum buffer
    size (vbv_buffer_size) should be twice of the initial buffer fullness (4 times of
    the initial I frame).
  • Setting too low bitrate for MPEG-2 Encoder may produce mosaic visual artifacts on
    complex content with fast motion or scene changes. For example bitrate 5.6 Mbps is
    too low for 1080@25p, increasing bitrate to 8.5 Mbps produce much better quality
    stream.
Zachary
