Currently I am using Intel QuickSync SDK ver 2013 and doing Hardware based Mpeg (Mpeg2 DVD) and H264 Encoding.
But recorded Mpeg file is not properly play in Windows Media player and in VLC player there is frame drop equal to no of GOP in files.
During analysis of recorded Mpeg file, I found that
1. SRC is not set properly. First I frame is start from 740 ms.
2. Also get error Sequence_end_code NOT FOUND, in Stream E0!
3. VBV Buffer Size = 273 -> (546 KB)
Please encoder setting whch we set for Mpeg Recording
BRCParamMultiplier 0 unsigned short
+ FrameInfo {reserved=0x0000000002277698 FrameId={...} FourCC=842094158 ...} mfxFrameInfo
FrameId {TemporalId=0 PriorityId=0 DependencyId=0 ...} mfxFrameId
TemporalId 0 unsigned short
PriorityId 0 unsigned short
DependencyId 0 unsigned short
QualityId 0 unsigned short
ViewId 0 unsigned short
FourCC 842094158
Width 720
Height 576
CropX 0
CropY 0
CropW 720
CropH 576
FrameRateExtN 25
FrameRateExtD 1
reserved3 0
AspectRatioW 2304
AspectRatioH 2160
PicStruct 4
ChromaFormat 1
CodecId 843534413
CodecProfile 64
CodecLevel 8
NumThread 0
TargetUsage 0
GopPicSize 15
GopRefDist 3
GopOptFlag 1
IdrInterval 1
RateControlMethod 1
InitialDelayInKB 0
QPI 0
Accuracy 0
BufferSizeInKB 0
TargetKbps 6000
QPP 6000
MaxKbps 6000
QPB 6000
Convergence 6000
NumSlice 0
NumRefFrame 0
EncodedOrder 0
DecodedOrder 0
ExtendedPicStruct 15
TimeStampCalc 3
SliceGroupsPresent 1
JPEGChromaFormat 0
Rotation 15
JPEGColorFormat 3
InterleavedDec 1
Interleaved 0
Quality 15
RestartInterval 3
I attach sample Media File.
I also attach my System configuration and Quicksync version detail also (Machine config.jpg)
Thanking You.
Parag Gandhi
Hi Parag,
We will look into the reported scenario in detail and get back you shortly. Thanks for your feedback.
Petter
Hi again Parag,
With SRC do you mean SCR(System Clock Reference)?
What is your concern about the VBV buffer size value?
Regarding sequence end code. You can explicitly insert this by setting the parameter EndOfSequence in mfxExtCodingOption.
Petter
