Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
3058 Discussions
MSDK cant support HW acceleration if system connect 2 displays
Zheng_L_
my notebook computer has a NV MX150 independent card and a intel UHD620 integrated card,my program use nv card to do CUDA computing and intel card to do hw accelerated video decoding/encoding, my program works fine when system only use notebook's display,but when I use a second display connected to notebook's HDMI port,the MSDK HW accelerated video decoding/encoding can not work,MFXInit() return MFX_ERR_UNSUPPORTED; I found I must bind my program to Intel card,then the HW acceleration can be worked,but that my program can not do the cuda computing;  nv card,msdk acceleated dec/enc,second display are all my program needed,so how can I get it?
Ramashankar
New Contributor III
Hi Zheng,
I believe you need not to bind your program to any particular card. You can just try to init your session using MFXInit with various hardware flags.
Refer this post: https://software.intel.com/en-us/forums/intel-media-sdk/topic/780596#comment-1923855
Hope it helps.
Zheng_L_
Ramashankar wrote:
Hi Zheng,
Refer this post: https://software.intel.com/en-us/forums/intel-media-sdk/topic/780596#com...
Hope it helps.
Hi,Ramashankar:
   I use MFX_IMPL_HARDWARE_ANY to call MFXInit(),and I also try the MFX_IMPL_HARDWARE2/3/4,but all failed, but my program init the CUDA SDK firstly,then init msdk, am I going to reverse the order?
Mark_L_Intel1
Hi Zheng,
Did you check Appendix D of Media SDK developer guide?
Mark
Let me know if this solves your problem.
