MSS 2015 R6: Loading of VA display was failed
Luka_K_
I installed 2015 R6 on a fresh CentOS 7.1. Unfortunately when I try sample_decode_drm I have following error:
[root@server samples]./sample_decode_drm h264 -i content/test_stream.264 -o test.yuv
terminate called after throwing an instance of 'std::invalid_argument'
what():  Loading of VA display was failed
Aborted
Here are details about system:
[root@server]# cat /etc/redhat-release
CentOS Linux release 7.1.1503 (Core)
[root@server]uname -r
3.10.0-229.1.2.39163.MSSr4.el7.centos.x86_64
[root@server]lsmod | grep i915
i915                  938175  3
drm_kms_helper         98226  1 i915
drm                   311336  2 i915,drm_kms_helper
i2c_algo_bit           13413  2 igb,i915
i2c_core               40325  6 drm,igb,i915,i2c_i801,drm_kms_helper,i2c_algo_bit
video                  19263  1 i915
[root@server]# cat /proc/cpuinfo | grep 'model name'
model name    : Intel(R) Core(TM) i7-4860EQ CPU @ 1.80GHz
[root@server]lspci -nn
00:00.0 Host bridge [0600]: Intel Corporation Crystal Well DRAM Controller [8086:0d04] (rev 08)
00:01.0 PCI bridge [0604]: Intel Corporation Crystal Well PCI Express x16 Controller [8086:0d01] (rev 08)
00:02.0 VGA compatible controller [0300]: Intel Corporation Crystal Well Integrated Graphics Controller [8086:0d26] (rev 08)
00:03.0 Audio device [0403]: Intel Corporation Crystal Well HD Audio Controller [8086:0d0c] (rev 08)
00:16.0 Communication controller [0780]: Intel Corporation 8 Series/C220 Series Chipset Family MEI Controller #1 [8086:8c3a] (rev 04)
00:16.3 Serial controller [0700]: Intel Corporation 8 Series/C220 Series Chipset Family KT Controller [8086:8c3d] (rev 04)
00:19.0 Ethernet controller [0200]: Intel Corporation Ethernet Connection I217-LM [8086:153a] (rev 05)
00:1a.0 USB controller [0c03]: Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI #2 [8086:8c2d] (rev 05)
00:1d.0 USB controller [0c03]: Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI #1 [8086:8c26] (rev 05)
00:1f.0 ISA bridge [0601]: Intel Corporation QM87 Express LPC Controller [8086:8c4f] (rev 05)
00:1f.2 SATA controller [0106]: Intel Corporation 8 Series/C220 Series Chipset Family 6-port SATA Controller 1 [AHCI mode] [8086:8c03] (rev 05)
00:1f.3 SMBus [0c05]: Intel Corporation 8 Series/C220 Series Chipset Family SMBus Controller [8086:8c22] (rev 05)
01:00.0 Ethernet controller [0200]: Intel Corporation I210 Gigabit Backplane Connection [8086:1537] (rev 03)
Am I doing something wrong? This CPU should be supported?
Jiandong_Z_Intel
Hi There,
Have you followed the steps mentioned in the getting started guide for the installation?
Can you run following command line and share the output ?
[root@server samples]# strace ./sample_decode_drm h264 -i content/test_stream.264 -o test.yuv
Only add strace before your command line.
Zachary
Luka_K_
I followed instructions.
[root@server release]# strace ./sample_decode_drm h264 -i content/test_stream.264 -o test.yuv
execve("./sample_decode_drm", ["./sample_decode_drm", "h264", "-i", "content/test_stream.264", "-o", "test.yuv"], [/* 26 vars */]) = 0
brk(0)                                  = 0x7f2603cb2000
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f26023e8000
access("/etc/ld.so.preload", R_OK)      = -1 ENOENT (No such file or directory)
open("/etc/ld.so.cache", O_RDONLY|O_CLOEXEC) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=39731, ...}) = 0
mmap(NULL, 39731, PROT_READ, MAP_PRIVATE, 3, 0) = 0x7f26023de000
close(3)                                = 0
open("/lib64/libdl.so.2", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\320\16\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=19512, ...}) = 0
mmap(NULL, 2109744, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f2601fc4000
mprotect(0x7f2601fc7000, 2093056, PROT_NONE) = 0
mmap(0x7f26021c6000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f26021c6000
close(3)                                = 0
open("/lib64/libpthread.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\240l\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=141616, ...}) = 0
mmap(NULL, 2208864, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f2601da8000
mprotect(0x7f2601dbe000, 2097152, PROT_NONE) = 0
mmap(0x7f2601fbe000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x16000) = 0x7f2601fbe000
mmap(0x7f2601fc0000, 13408, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f2601fc0000
close(3)                                = 0
open("/lib64/libva.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\220/\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=90664, ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f26023dd000
mmap(NULL, 2190240, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f2601b91000
mprotect(0x7f2601ba6000, 2093056, PROT_NONE) = 0
mmap(0x7f2601da5000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x14000) = 0x7f2601da5000
mmap(0x7f2601da7000, 2976, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f2601da7000
close(3)                                = 0
open("/lib64/libdrm.so.2", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\0202\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=49840, ...}) = 0
mmap(NULL, 2145168, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f2601985000
mprotect(0x7f2601990000, 2093056, PROT_NONE) = 0
mmap(0x7f2601b8f000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xa000) = 0x7f2601b8f000
close(3)                                = 0
open("/lib64/libva-drm.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0000\r\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=11352, ...}) = 0
mmap(NULL, 2105560, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f2601782000
mprotect(0x7f2601784000, 2093056, PROT_NONE) = 0
mmap(0x7f2601983000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0x7f2601983000
close(3)                                = 0
open("/lib64/libstdc++.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\20\265\5\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=991744, ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f26023dc000
mmap(NULL, 3171360, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f260147b000
mprotect(0x7f2601564000, 2093056, PROT_NONE) = 0
mmap(0x7f2601763000, 40960, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xe8000) = 0x7f2601763000
mmap(0x7f260176d000, 82976, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f260176d000
close(3)                                = 0
open("/lib64/libm.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\260T\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=1141552, ...}) = 0
mmap(NULL, 3150168, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f2601179000
mprotect(0x7f260127a000, 2093056, PROT_NONE) = 0
mmap(0x7f2601479000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x100000) = 0x7f2601479000
close(3)                                = 0
open("/lib64/libgcc_s.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\360*\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=88720, ...}) = 0
mmap(NULL, 2184192, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f2600f63000
mprotect(0x7f2600f78000, 2093056, PROT_NONE) = 0
mmap(0x7f2601177000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x14000) = 0x7f2601177000
close(3)                                = 0
open("/lib64/libc.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\0\34\2\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=2107760, ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f26023db000
mmap(NULL, 3932736, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f2600ba2000
mprotect(0x7f2600d58000, 2097152, PROT_NONE) = 0
mmap(0x7f2600f58000, 24576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1b6000) = 0x7f2600f58000
mmap(0x7f2600f5e000, 16960, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f2600f5e000
close(3)                                = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f26023da000
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f26023d8000
arch_prctl(ARCH_SET_FS, 0x7f26023d8740) = 0
mprotect(0x7f2600f58000, 16384, PROT_READ) = 0
mprotect(0x7f2601177000, 4096, PROT_READ) = 0
mprotect(0x7f2601479000, 4096, PROT_READ) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f26023d7000
mprotect(0x7f2601763000, 32768, PROT_READ) = 0
mprotect(0x7f26021c6000, 4096, PROT_READ) = 0
mprotect(0x7f2601da5000, 4096, PROT_READ) = 0
mprotect(0x7f2601b8f000, 4096, PROT_READ) = 0
mprotect(0x7f2601983000, 4096, PROT_READ) = 0
mprotect(0x7f2601fbe000, 4096, PROT_READ) = 0
mprotect(0x7f260261e000, 8192, PROT_READ) = 0
mprotect(0x7f26023e9000, 4096, PROT_READ) = 0
munmap(0x7f26023de000, 39731)           = 0
set_tid_address(0x7f26023d8a10)         = 26449
set_robust_list(0x7f26023d8a20, 24)     = 0
rt_sigaction(SIGRTMIN, {0x7f2601dae780, [], SA_RESTORER|SA_SIGINFO, 0x7f2601db7130}, NULL, 8) = 0
rt_sigaction(SIGRT_1, {0x7f2601dae810, [], SA_RESTORER|SA_RESTART|SA_SIGINFO, 0x7f2601db7130}, NULL, 8) = 0
rt_sigprocmask(SIG_UNBLOCK, [RTMIN RT_1], NULL, 8) = 0
getrlimit(RLIMIT_STACK, {rlim_cur=8192*1024, rlim_max=RLIM64_INFINITY}) = 0
futex(0x7f260177f96c, FUTEX_WAKE_PRIVATE, 2147483647) = 0
futex(0x7f260177f978, FUTEX_WAKE_PRIVATE, 2147483647) = 0
brk(0x7f2603cd4000)                     = 0x7f2603cd4000
brk(0)                                  = 0x7f2603cd4000
open("content/test_stream.264", O_RDONLY) = 3
openat(AT_FDCWD, "/sys/bus/pci/devices", O_RDONLY|O_NONBLOCK|O_DIRECTORY|O_CLOEXEC) = 4
getdents(4, /* 15 entries */, 32768)    = 464
getdents(4, /* 0 entries */, 32768)     = 0
close(4)                                = 0
open("/sys/bus/pci/devices/0000:00:00.0/class", O_RDONLY) = 4
fstat(4, {st_mode=S_IFREG|0444, st_size=4096, ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f26023e7000
read(4, "0x060000\n", 4096)             = 9
close(4)                                = 0
munmap(0x7f26023e7000, 4096)            = 0
open("/sys/bus/pci/devices/0000:00:01.0/class", O_RDONLY) = 4
read(4, "0x060400\n", 4096)             = 9
close(4)                                = 0
open("/sys/bus/pci/devices/0000:00:02.0/class", O_RDONLY) = 4
read(4, "0x030000\n", 4096)             = 9
close(4)                                = 0
open("/sys/bus/pci/devices/0000:00:02.0/vendor", O_RDONLY) = 4
read(4, "0x8086\n", 4096)               = 7
close(4)                                = 0
open("/sys/bus/pci/devices/0000:00:02.0/device", O_RDONLY) = 4
read(4, "0x0d26\n", 4096)               = 7
close(4)                                = 0
open("/sys/bus/pci/devices/0000:00:03.0/class", O_RDONLY) = 4
read(4, "0x040300\n", 4096)             = 9
close(4)                                = 0
open("/sys/bus/pci/devices/0000:00:16.0/class", O_RDONLY) = 4
read(4, "0x078000\n", 4096)             = 9
close(4)                                = 0
open("/sys/bus/pci/devices/0000:00:16.3/class", O_RDONLY) = 4
read(4, "0x070002\n", 4096)             = 9
close(4)                                = 0
open("/sys/bus/pci/devices/0000:00:19.0/class", O_RDONLY) = 4
read(4, "0x020000\n", 4096)             = 9
close(4)                                = 0
open("/sys/bus/pci/devices/0000:00:1a.0/class", O_RDONLY) = 4
read(4, "0x0c0320\n", 4096)             = 9
close(4)                                = 0
open("/sys/bus/pci/devices/0000:00:1d.0/class", O_RDONLY) = 4
close(4)                                = 0
open("/sys/bus/pci/devices/0000:00:1f.0/class", O_RDONLY) = 4
read(4, "0x060100\n", 4096)             = 9
close(4)                                = 0
open("/sys/bus/pci/devices/0000:00:1f.2/class", O_RDONLY) = 4
read(4, "0x010601\n", 4096)             = 9
close(4)                                = 0
open("/sys/bus/pci/devices/0000:00:1f.3/class", O_RDONLY) = 4
read(4, "0x0c0500\n", 4096)             = 9
close(4)                                = 0
open("/sys/bus/pci/devices/0000:01:00.0/class", O_RDONLY) = 4
close(4)                                = 0
openat(AT_FDCWD, "/opt/intel/mediasdk/lib64", O_RDONLY|O_NONBLOCK|O_DIRECTORY|O_CLOEXEC) = 4
getdents(4, /* 7 entries */, 32768)     = 248
close(4)                                = 0
futex(0x7f26021c70d0, FUTEX_WAKE_PRIVATE, 2147483647) = 0
open("/opt/intel/mediasdk/lib64/libmfxhw64-p.so.1.16", O_RDONLY|O_CLOEXEC) = 4
read(4, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\260V\3\0\0\0\0\0"..., 832) = 832
fstat(4, {st_mode=S_IFREG|0755, st_size=10646952, ...}) = 0
mmap(NULL, 12807528, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 4, 0) = 0x7f25fff6b000
mprotect(0x7f260096d000, 2097152, PROT_NONE) = 0
mmap(0x7f2600b6d000, 151552, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 4, 0xa02000) = 0x7f2600b6d000
mmap(0x7f2600b92000, 64872, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f2600b92000
close(4)                                = 0
mprotect(0x7f2600b6d000, 73728, PROT_READ) = 0
open("/root/.mfx_trace", O_RDONLY)      = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/sys/devices/system/cpu", O_RDONLY|O_NONBLOCK|O_DIRECTORY|O_CLOEXEC) = 4
getdents(4, /* 21 entries */, 32768)    = 592
close(4)                                = 0
brk(0x7f2603cf7000)                     = 0x7f2603cf7000
mmap(NULL, 8392704, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7f25ff76a000
mprotect(0x7f25ff76a000, 4096, PROT_NONE) = 0
clone(child_stack=0x7f25fff69fb0, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x7f25fff6a9d0, tls=0x7f25fff6a700, child_tidptr=0x7f25fff6a9d0) = 26450
mmap(NULL, 8392704, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7f25fef69000
mprotect(0x7f25fef69000, 4096, PROT_NONE) = 0
clone(child_stack=0x7f25ff768fb0, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x7f25ff7699d0, tls=0x7f25ff769700, child_tidptr=0x7f25ff7699d0) = 26451
mmap(NULL, 8392704, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7f25fe768000
mprotect(0x7f25fe768000, 4096, PROT_NONE) = 0
clone(child_stack=0x7f25fef67fb0, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x7f25fef689d0, tls=0x7f25fef68700, child_tidptr=0x7f25fef689d0) = 26452
mmap(NULL, 8392704, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7f25fdf67000
mprotect(0x7f25fdf67000, 4096, PROT_NONE) = 0
clone(child_stack=0x7f25fe766fb0, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x7f25fe7679d0, tls=0x7f25fe767700, child_tidptr=0x7f25fe7679d0) = 26453
mmap(NULL, 8392704, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7f25fd766000
mprotect(0x7f25fd766000, 4096, PROT_NONE) = 0
clone(child_stack=0x7f25fdf65fb0, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x7f25fdf669d0, tls=0x7f25fdf66700, child_tidptr=0x7f25fdf669d0) = 26454
mmap(NULL, 8392704, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7f25fcf65000
mprotect(0x7f25fcf65000, 4096, PROT_NONE) = 0
clone(child_stack=0x7f25fd764fb0, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x7f25fd7659d0, tls=0x7f25fd765700, child_tidptr=0x7f25fd7659d0) = 26455
mmap(NULL, 8392704, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7f25fc764000
mprotect(0x7f25fc764000, 4096, PROT_NONE) = 0
clone(child_stack=0x7f25fcf63fb0, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x7f25fcf649d0, tls=0x7f25fcf64700, child_tidptr=0x7f25fcf649d0) = 26456
mmap(NULL, 8392704, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7f25fbf63000
mprotect(0x7f25fbf63000, 4096, PROT_NONE) = 0
clone(child_stack=0x7f25fc762fb0, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x7f25fc7639d0, tls=0x7f25fc763700, child_tidptr=0x7f25fc7639d0) = 26457
close(4)                                = 0
close(4)                                = 0
close(4)                                = 0
close(4)                                = 0
close(4)                                = 0
close(4)                                = 0
close(4)                                = 0
close(4)                                = 0
close(4)                                = 0
close(4)                                = 0
close(4)                                = 0
close(4)                                = 0
close(4)                                = 0
close(4)                                = 0
close(4)                                = 0
close(4)                                = 0
close(4)                                = 0
brk(0)                                  = 0x7f2603cf7000
brk(0x7f2603d18000)                     = 0x7f2603d18000
mmap(NULL, 8392704, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7f25fb762000
mprotect(0x7f25fb762000, 4096, PROT_NONE) = 0
clone(child_stack=0x7f25fbf61fb0, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x7f25fbf629d0, tls=0x7f25fbf62700, child_tidptr=0x7f25fbf629d0) = 26458
mmap(NULL, 8392704, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7f25faf61000
mprotect(0x7f25faf61000, 4096, PROT_NONE) = 0
clone(child_stack=0x7f25fb760fb0, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x7f25fb7619d0, tls=0x7f25fb761700, child_tidptr=0x7f25fb7619d0) = 26459
mmap(NULL, 8392704, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7f25fa760000
mprotect(0x7f25fa760000, 4096, PROT_NONE) = 0
clone(child_stack=0x7f25faf5ffb0, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x7f25faf609d0, tls=0x7f25faf60700, child_tidptr=0x7f25faf609d0) = 26460
mmap(NULL, 8392704, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7f25f9f5f000
mprotect(0x7f25f9f5f000, 4096, PROT_NONE) = 0
clone(child_stack=0x7f25fa75efb0, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x7f25fa75f9d0, tls=0x7f25fa75f700, child_tidptr=0x7f25fa75f9d0) = 26461
mmap(NULL, 8392704, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7f25f975e000
mprotect(0x7f25f975e000, 4096, PROT_NONE) = 0
clone(child_stack=0x7f25f9f5dfb0, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x7f25f9f5e9d0, tls=0x7f25f9f5e700, child_tidptr=0x7f25f9f5e9d0) = 26462
mmap(NULL, 8392704, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7f25f8f5d000
mprotect(0x7f25f8f5d000, 4096, PROT_NONE) = 0
clone(child_stack=0x7f25f975cfb0, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x7f25f975d9d0, tls=0x7f25f975d700, child_tidptr=0x7f25f975d9d0) = 26463
mmap(NULL, 8392704, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7f25f875c000
mprotect(0x7f25f875c000, 4096, PROT_NONE) = 0
clone(child_stack=0x7f25f8f5bfb0, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x7f25f8f5c9d0, tls=0x7f25f8f5c700, child_tidptr=0x7f25f8f5c9d0) = 26464
mmap(NULL, 8392704, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7f25f7f5b000
mprotect(0x7f25f7f5b000, 4096, PROT_NONE) = 0
clone(child_stack=0x7f25f875afb0, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x7f25f875b9d0, tls=0x7f25f875b700, child_tidptr=0x7f25f875b9d0) = 26465
stat("/opt/intel/mediasdk/lib64/libmfxplugin64_hw.so", 0x7fff90179150) = -1 ENOENT (No such file or directory)
open("/opt/intel/mediasdk/plugins/plugins.cfg", O_RDONLY) = 4
fstat(4, {st_mode=S_IFREG|0644, st_size=643, ...}) = 0
lseek(4, 0, SEEK_SET)                   = 0
read(4, "[H264LA_Encoder_588f1185d47b4296"..., 4096) = 643
lseek(4, 643, SEEK_SET)                 = 643
read(4, "", 4096)                       = 0
read(4, "[H264LA_Encoder_588f1185d47b4296"..., 430) = 430
lseek(4, 430, SEEK_SET)                 = 430
read(4, "[VP8_Encoder_bffc518cde134df98a9"..., 4096) = 213
close(4)                                = 0
close(4)                                = 0
readlink("/proc/self/exe", "/root/MediaSamples_Linux_5.0.160"..., 4095) = 108
openat(AT_FDCWD, "/root/MediaSamples_Linux_5.0.1604371.71/samples/__cmake/intel64.make.release/__bin/release", O_RDONLY|O_NONBLOCK|O_DIRECTORY|O_CLOEXEC) = 4
getdents(4, /* 18 entries */, 32768)    = 720
close(4)                                = 0
futex(0x7f2603cd9de4, FUTEX_WAKE_OP_PRIVATE, 1, 1, 0x7f2603cd9de0, {FUTEX_OP_SET, 0, FUTEX_OP_CMP_GT, 1}) = 1
futex(0x7f2603cd9e10, FUTEX_WAKE_PRIVATE, 1) = 1
futex(0x7f2603cd9e4c, FUTEX_WAKE_OP_PRIVATE, 1, 1, 0x7f2603cd9e48, {FUTEX_OP_SET, 0, FUTEX_OP_CMP_GT, 1}) = 1
futex(0x7f2603cd9e78, FUTEX_WAKE_PRIVATE, 1) = 1
futex(0x7f2603cd9eb4, FUTEX_WAKE_OP_PRIVATE, 1, 1, 0x7f2603cd9eb0, {FUTEX_OP_SET, 0, FUTEX_OP_CMP_GT, 1}) = 1
futex(0x7f2603cd9ee0, FUTEX_WAKE_PRIVATE, 1) = 1
futex(0x7f2603cd9f1c, FUTEX_WAKE_OP_PRIVATE, 1, 1, 0x7f2603cd9f18, {FUTEX_OP_SET, 0, FUTEX_OP_CMP_GT, 1}) = 1
futex(0x7f2603cd9f48, FUTEX_WAKE_PRIVATE, 1) = 1
futex(0x7f2603cd9f84, FUTEX_WAKE_OP_PRIVATE, 1, 1, 0x7f2603cd9f80, {FUTEX_OP_SET, 0, FUTEX_OP_CMP_GT, 1}) = 1
futex(0x7f2603cd9fb0, FUTEX_WAKE_PRIVATE, 1) = 1
futex(0x7f2603cd9fec, FUTEX_WAKE_OP_PRIVATE, 1, 1, 0x7f2603cd9fe8, {FUTEX_OP_SET, 0, FUTEX_OP_CMP_GT, 1}) = 1
futex(0x7f2603cda018, FUTEX_WAKE_PRIVATE, 1) = 1
futex(0x7f2603cda054, FUTEX_WAKE_OP_PRIVATE, 1, 1, 0x7f2603cda050, {FUTEX_OP_SET, 0, FUTEX_OP_CMP_GT, 1}) = 1
futex(0x7f2603cda080, FUTEX_WAKE_PRIVATE, 1) = 1
futex(0x7f2603cda0bc, FUTEX_WAKE_OP_PRIVATE, 1, 1, 0x7f2603cda0b8, {FUTEX_OP_SET, 0, FUTEX_OP_CMP_GT, 1}) = 1
futex(0x7f2603cda0e8, FUTEX_WAKE_PRIVATE, 1) = 1
munmap(0x7f25fb762000, 8392704)         = 0
munmap(0x7f25faf61000, 8392704)         = 0
munmap(0x7f25fa760000, 8392704)         = 0
munmap(0x7f25f9f5f000, 8392704)         = 0
mmap(NULL, 1052672, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f26022d6000
fstat(3, {st_mode=S_IFREG|0777, st_size=267554, ...}) = 0
read(3, "\0\0\0\1\t\20\0\0\0\1'd\0\f\254.\302\315\260\21\0\0\3\0\1\0\0\3\0<\340`"..., 1048576) = 267554
read(3, "", 778240)                     = 0
close(4)                                = 0
open("test.yuv", O_WRONLY|O_CREAT|O_TRUNC, 0666) = 4
openat(AT_FDCWD, "/sys/bus/pci/devices", O_RDONLY|O_NONBLOCK|O_DIRECTORY|O_CLOEXEC) = 5
getdents(5, /* 15 entries */, 32768)    = 464
getdents(5, /* 0 entries */, 32768)     = 0
close(5)                                = 0
open("/sys/bus/pci/devices/0000:00:00.0/class", O_RDONLY) = 5
fstat(5, {st_mode=S_IFREG|0444, st_size=4096, ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f26023e6000
read(5, "0x060000\n", 4096)             = 9
close(5)                                = 0
munmap(0x7f26023e6000, 4096)            = 0
open("/sys/bus/pci/devices/0000:00:01.0/class", O_RDONLY) = 5
read(5, "0x060400\n", 4096)             = 9
close(5)                                = 0
open("/sys/bus/pci/devices/0000:00:02.0/class", O_RDONLY) = 5
read(5, "0x030000\n", 4096)             = 9
close(5)                                = 0
open("/sys/bus/pci/devices/0000:00:02.0/vendor", O_RDONLY) = 5
read(5, "0x8086\n", 4096)               = 7
close(5)                                = 0
open("/sys/bus/pci/devices/0000:00:02.0/device", O_RDONLY) = 5
read(5, "0x0d26\n", 4096)               = 7
close(5)                                = 0
open("/sys/bus/pci/devices/0000:00:03.0/class", O_RDONLY) = 5
read(5, "0x040300\n", 4096)             = 9
close(5)                                = 0
open("/sys/bus/pci/devices/0000:00:16.0/class", O_RDONLY) = 5
read(5, "0x078000\n", 4096)             = 9
close(5)                                = 0
open("/sys/bus/pci/devices/0000:00:16.3/class", O_RDONLY) = 5
read(5, "0x070002\n", 4096)             = 9
close(5)                                = 0
open("/sys/bus/pci/devices/0000:00:19.0/class", O_RDONLY) = 5
read(5, "0x020000\n", 4096)             = 9
close(5)                                = 0
open("/sys/bus/pci/devices/0000:00:1a.0/class", O_RDONLY) = 5
read(5, "0x0c0320\n", 4096)             = 9
close(5)                                = 0
open("/sys/bus/pci/devices/0000:00:1d.0/class", O_RDONLY) = 5
close(5)                                = 0
open("/sys/bus/pci/devices/0000:00:1f.0/class", O_RDONLY) = 5
read(5, "0x060100\n", 4096)             = 9
close(5)                                = 0
open("/sys/bus/pci/devices/0000:00:1f.2/class", O_RDONLY) = 5
read(5, "0x010601\n", 4096)             = 9
close(5)                                = 0
open("/sys/bus/pci/devices/0000:00:1f.3/class", O_RDONLY) = 5
read(5, "0x0c0500\n", 4096)             = 9
close(5)                                = 0
open("/sys/bus/pci/devices/0000:01:00.0/class", O_RDONLY) = 5
close(5)                                = 0
open("/dev/dri/renderD128", O_RDWR)     = -1 ENOENT (No such file or directory)
open("/dev/dri/card0", O_RDWR)          = -1 ENOENT (No such file or directory)
futex(0x7f2601178190, FUTEX_WAKE_PRIVATE, 2147483647) = 0
write(2, "terminate called after throwing "..., 48terminate called after throwing an instance of ') = 48
write(2, "std::invalid_argument", 21std::invalid_argument)   = 21
write(2, "'\n", 2'
)                      = 2
write(2, "  what():  ", 11  what():  )             = 11
write(2, "Loading of VA display was failed", 32Loading of VA display was failed) = 32
write(2, "\n", 1
)                       = 1
rt_sigprocmask(SIG_UNBLOCK, [ABRT], NULL, 8) = 0
tgkill(26449, 26449, SIGABRT)           = 0
--- SIGABRT {si_signo=SIGABRT, si_code=SI_TKILL, si_pid=26449, si_uid=0} ---
+++ killed by SIGABRT +++
Aborted
Jiandong_Z_Intel
Thanks your output.
From the log we can see -
Can you check two files using following command line ?
$ ls /dev/dri -l
Another:  vainfo is also failed, should be the same error. right ?
$ vainfo
Zachary
Luka_K_
$ ls /dev/dri -l
ls: cannot access /dev/dri: No such file or directory
$vainfo
error: can't connect to X server!
error: failed to initialize display
Aborted
Yes I've noticed missing /dev/dri/card0. I'm not sure if helps but this is headless system.
Jiandong_Z_Intel
On my end, this is output for "ls /dev/dri/ -l"
[lmsdk@localhost ~]$ ls /dev/dri/ -l
total 0
crw-rw----+ 1 root video 226,   0 Jul 15 07:00 card0
crw-------. 1 root video 226,  64 Jun 29 12:44 controlD64
crw-rw----. 1 root video 226, 128 Jun 29 12:44 renderD128
I also want to check your i915 modules by following command:
[lmsdk@localhost ~]$ modinfo i915 | grep "Media Server Studio"
description:    Intel Graphics Media Server Studio 2015 R6.39163
I suggest you rebuild your KMD by run build_kernel_rpm_CentOS.sh and notice if there are any errors happened.
Zachary
Luka_K_
I don't have /dev/dri at all.
description:    Intel Graphics Media Server Studio 2015 R4.39163
When I run ./build_kernel_rpm_CentOS.sh as regular user from /MSS I have few possible errors:
Compiling 53 OIDs
  - Including cert /MSS/rpmbuild/BUILD/kernel-3.10.0-229.1.2.el7/linux-3.10.0-229.1.2.39163.MSSr4.el7.centos.x86_64/centos-kpatch.x509
  - Including cert /MSS/rpmbuild/BUILD/kernel-3.10.0-229.1.2.el7/linux-3.10.0-229.1.2.39163.MSSr4.el7.centos.x86_64/centos-ldup.x509
  - Including cert signing_key.x509
/MSS/rpmbuild/BUILD/kernel-3.10.0-229.1.2.el7/linux-3.10.0-229.1.2.39163.MSSr4.el7.centos.x86_64/usr/include/linux/kexec.h:60: userspace cannot reference function or variable defined in the kernel
+ make ARCH=x86_64 INSTALL_HDR_PATH=/MSS/rpmbuild/SOURCES/../BUILDROOT/kernel-3.10.0-229.1.2.39163.MSSr4.el7.centos.x86_64/usr headers_check
/MSS/rpmbuild/SOURCES/../BUILDROOT/kernel-3.10.0-229.1.2.39163.MSSr4.el7.centos.x86_64/usr/include/linux/kexec.h:60: userspace cannot reference function or variable defined in the kernel
When I run: rpm -Uvh --force kernel-3.10.*.rpm I get following:
$ rpm -Uvh --force kernel-3.10.*.rpm
Preparing...                          ################################# [100%]
Updating / installing...
   1:kernel-3.10.0-229.1.2.39163.MSSr4################################# [100%]
After reboot everything is same again. Do you have idea why I'm seeing R4 all the way? I'm sure I downloaded R6.
Luka_K_
You were right for some reason kernel module is not loaded. lspci -k should show something like:
00:02.0 VGA compatible controller: Intel Corporation Crystal Well Integrated Graphics Controller (rev 08)
	Subsystem: Intel Corporation Device 2112
	Kernel driver in use: i915
	Kernel modules: i915
Currently I have:
I'm searching for cause now...
Jiandong_Z_Intel
Using following command line can set R6 all the way.
$ ./build_kernel_rpm_CentOS.sh  6    ## add 6 parameter.
Because following code in build_kernel_rpm_CentOS.sh
if [ "$#" -eq 1 ]; then
    INTEL_MSS_RELEASE_NUM=$1
else
    INTEL_MSS_RELEASE_NUM=4
fi
Just reminder in media_server_studio_getting_started_guide.pdf like following:
Add the user(s) who will run Intel Media Server Studio – SDK applications to the video group
# usermod -a -G video [LOGIN]
(as regular user)
$ ./build_kernel_rpm_CentOS.sh  6   ## don't use root user
Have you check dmesg output by following command line ?
$ dmesg | grep i915
Luka_K_
$ dmesg | grep i915
[    3.232756] snd_hda_intel 0000:00:03.0: Cannot turn on display power on i915
Luka_K_
For some reason nomodeset boot flag was active. After removing that line driver is loaded...
Luka_K_
I can confirm that sample_encode_drm and sample_decode_drm are now working. i915 is loaded correctly after removing nomodeset.
Jiandong_Z_Intel
Great you make it work.
Zachary
Tyrone_B_1
Hi, I'm having a similar issue. I installed the latest Intel Media Server Studio Essentials 2015R6 onto a clean install of CentOS 7.1 following the instructions in the getting started guide. I am running on an Intel Core i7-3612QE CPU @ 2.10GHz, which I believe should support QuickSync.
After installation, I get the following error when I try to run sample_encode_drm:
./sample_encode_drm h264 -i ../content/test_stream_176x96.yuv -o test.264 -w 176 -h 96 -hw
libva info: VA-API version 0.35.0
libva info: va_getDriverName() returns 0
libva info: User requested driver 'iHD'
libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so
libva info: Found init function __vaDriverInit_0_32
libva error: /opt/intel/mediasdk/lib64/iHD_drv_video.so init failed
libva info: va_openDriver() returns 1
Unrecognized device ID 0166Unrecognized device ID 0166Aborted (core dumped)
I tried the suggestion here to disable nomodeset without any luck. Any guidance would be greatly appreciated.
The environment tests generally seem to pass:
[root@localhost debug]# cat /etc/redhat-release
[root@localhost debug]# uname -r
[root@localhost debug]# lsmod | grep i915
i915 938175 3
i2c_algo_bit 13413 1 i915
drm 311336 5 i915,drm_kms_helper
i2c_core 40325 5 drm,i915,i2c_i801,drm_kms_helper,i2c_algo_bit
​video 19263 1 i915
[root@localhost debug]# cat /proc/cpuinfo | grep 'model name'
model name    : Intel(R) Core(TM) i7-3612QE CPU @ 2.10GHz
[root@localhost debug]# modinfo i915 | grep "Media Server Studio"
[root@localhost debug]# ls /dev/dri -l
total 0
crw-rw----+ 1 root video 226,   0 Aug 18 12:59 card0
crw-------. 1 root video 226,  64 Aug 18 12:59 controlD64
crw-rw----. 1 root video 226, 128 Aug 18 12:59 renderD128
[root@localhost debug]# lspci -nn
00:00.0 Host bridge [0600]: Intel Corporation 3rd Gen Core processor DRAM Controller [8086:0154] (rev 09)
00:02.0 VGA compatible controller [0300]: Intel Corporation 3rd Gen Core processor Graphics Controller [8086:0166] (rev 09)
00:19.0 Ethernet controller [0200]: Intel Corporation 82579LM Gigabit Network Connection [8086:1502] (rev 04)
00:1a.0 USB controller [0c03]: Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #2 [8086:1e2d] (rev 04)
00:1c.0 PCI bridge [0604]: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 1 [8086:1e10] (rev c4)
00:1c.7 PCI bridge [0604]: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 8 [8086:1e1e] (rev c4)
00:1d.0 USB controller [0c03]: Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #1 [8086:1e26] (rev 04)
00:1f.0 ISA bridge [0601]: Intel Corporation QM77 Express Chipset LPC Controller [8086:1e55] (rev 04)
00:1f.2 SATA controller [0106]: Intel Corporation 7 Series Chipset Family 6-port SATA Controller [AHCI mode] [8086:1e03] (rev 04)
00:1f.3 SMBus [0c05]: Intel Corporation 7 Series/C210 Series Chipset Family SMBus Controller [8086:1e22] (rev 04)
02:00.0 PCI bridge [0604]: Pericom Semiconductor Device [12d8:e113]
Does the error 'unrecognized device ID 0166' suggest that my graphics controller is unsupported for QuickSync?
Here's the strace output:
[root@localhost debug]# strace ./sample_encode_drm h264 -i /home/tbekiares/Downloads/MediaServerStudioEssentials2015R6/MediaSamples_Linux_bins_6.0.16043175.175/content/test_stream_176x96.yuv -o test.264 -w 176 -h 96 -hw
execve("./sample_encode_drm", ["./sample_encode_drm", "h264", "-i", "/home/tbekiares/Downloads/MediaS"..., "-o", "test.264", "-w", "176", "-h", "96", "-hw"], [/* 29 vars */]) = 0
brk(0)                                  = 0x7fb7066a3000
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7fb70524e000
fstat(3, {st_mode=S_IFREG|0644, st_size=78328, ...}) = 0
mmap(NULL, 78328, PROT_READ, MAP_PRIVATE, 3, 0) = 0x7fb70523a000
close(3)                                = 0
mmap(NULL, 2105560, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7fb704e2b000
mprotect(0x7fb704e2d000, 2093056, PROT_NONE) = 0
mmap(0x7fb70502c000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0x7fb70502c000
close(3)                                = 0
mmap(NULL, 2145168, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7fb704c1f000
mprotect(0x7fb704c2a000, 2093056, PROT_NONE) = 0
mmap(0x7fb704e29000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xa000) = 0x7fb704e29000
close(3)                                = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7fb705239000
mmap(NULL, 2190240, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7fb704a08000
mprotect(0x7fb704a1d000, 2093056, PROT_NONE) = 0
mmap(0x7fb704c1c000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x14000) = 0x7fb704c1c000
mmap(0x7fb704c1e000, 2976, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7fb704c1e000
close(3)                                = 0
mmap(NULL, 2109744, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7fb704804000
mprotect(0x7fb704807000, 2093056, PROT_NONE) = 0
mmap(0x7fb704a06000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7fb704a06000
close(3)                                = 0
mmap(NULL, 2208864, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7fb7045e8000
mprotect(0x7fb7045fe000, 2097152, PROT_NONE) = 0
mmap(0x7fb7047fe000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x16000) = 0x7fb7047fe000
mmap(0x7fb704800000, 13408, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7fb704800000
close(3)                                = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7fb705238000
mmap(NULL, 3171360, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7fb7042e1000
mprotect(0x7fb7043ca000, 2093056, PROT_NONE) = 0
mmap(0x7fb7045c9000, 40960, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xe8000) = 0x7fb7045c9000
mmap(0x7fb7045d3000, 82976, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7fb7045d3000
close(3)                                = 0
mmap(NULL, 3150168, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7fb703fdf000
mprotect(0x7fb7040e0000, 2093056, PROT_NONE) = 0
mmap(0x7fb7042df000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x100000) = 0x7fb7042df000
close(3)                                = 0
mmap(NULL, 2184192, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7fb703dc9000
mprotect(0x7fb703dde000, 2093056, PROT_NONE) = 0
mmap(0x7fb703fdd000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x14000) = 0x7fb703fdd000
close(3)                                = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7fb705237000
mmap(NULL, 3932736, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7fb703a08000
mprotect(0x7fb703bbe000, 2097152, PROT_NONE) = 0
mmap(0x7fb703dbe000, 24576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1b6000) = 0x7fb703dbe000
mmap(0x7fb703dc4000, 16960, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7fb703dc4000
close(3)                                = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7fb705236000
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7fb705234000
arch_prctl(ARCH_SET_FS, 0x7fb705234740) = 0
mprotect(0x7fb703dbe000, 16384, PROT_READ) = 0
mprotect(0x7fb703fdd000, 4096, PROT_READ) = 0
mprotect(0x7fb7042df000, 4096, PROT_READ) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7fb705233000
mprotect(0x7fb7045c9000, 32768, PROT_READ) = 0
mprotect(0x7fb7047fe000, 4096, PROT_READ) = 0
mprotect(0x7fb704a06000, 4096, PROT_READ) = 0
mprotect(0x7fb704c1c000, 4096, PROT_READ) = 0
mprotect(0x7fb704e29000, 4096, PROT_READ) = 0
mprotect(0x7fb70502c000, 4096, PROT_READ) = 0
mprotect(0x7fb7054c9000, 12288, PROT_READ) = 0
mprotect(0x7fb70524f000, 4096, PROT_READ) = 0
munmap(0x7fb70523a000, 78328)           = 0
set_tid_address(0x7fb705234a10)         = 2652
set_robust_list(0x7fb705234a20, 24)     = 0
rt_sigaction(SIGRTMIN, {0x7fb7045ee780, [], SA_RESTORER|SA_SIGINFO, 0x7fb7045f7130}, NULL, 8) = 0
rt_sigaction(SIGRT_1, {0x7fb7045ee810, [], SA_RESTORER|SA_RESTART|SA_SIGINFO, 0x7fb7045f7130}, NULL, 8) = 0
futex(0x7fb7045e596c, FUTEX_WAKE_PRIVATE, 2147483647) = 0
futex(0x7fb7045e5978, FUTEX_WAKE_PRIVATE, 2147483647) = 0
brk(0x7fb7066c4000)                     = 0x7fb7066c4000
brk(0)                                  = 0x7fb7066c4000
open("/home/tbekiares/Downloads/MediaServerStudioEssentials2015R6/MediaSamples_Linux_bins_6.0.16043175.175/content/test_stream_176x96.yuv", O_RDONLY) = 3
open("test.264", O_RDWR|O_CREAT|O_TRUNC, 0666) = 4
getdents(5, /* 13 entries */, 32768)    = 400
close(5)                                = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7fb70524d000
close(5)                                = 0
munmap(0x7fb70524d000, 4096)            = 0
close(5)                                = 0
close(5)                                = 0
read(5, "0x0166\n", 4096)               = 7
close(5)                                = 0
close(5)                                = 0
close(5)                                = 0
open("/sys/bus/pci/devices/0000:00:1c.0/class", O_RDONLY) = 5
close(5)                                = 0
open("/sys/bus/pci/devices/0000:00:1c.7/class", O_RDONLY) = 5
close(5)                                = 0
close(5)                                = 0
close(5)                                = 0
close(5)                                = 0
close(5)                                = 0
open("/sys/bus/pci/devices/0000:02:00.0/class", O_RDONLY) = 5
close(5)                                = 0
openat(AT_FDCWD, "/opt/intel/mediasdk/lib64", O_RDONLY|O_NONBLOCK|O_DIRECTORY|O_CLOEXEC) = 5
getdents(5, /* 7 entries */, 32768)     = 248
close(5)                                = 0
futex(0x7fb704a070d0, FUTEX_WAKE_PRIVATE, 2147483647) = 0
open("/opt/intel/mediasdk/lib64/libmfxhw64-p.so.1.16", O_RDONLY|O_CLOEXEC) = 5
read(5, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\260V\3\0\0\0\0\0"..., 832) = 832
fstat(5, {st_mode=S_IFREG|0755, st_size=10646952, ...}) = 0
mmap(NULL, 12807528, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 5, 0) = 0x7fb702dd1000
mprotect(0x7fb7037d3000, 2097152, PROT_NONE) = 0
mmap(0x7fb7039d3000, 151552, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 5, 0xa02000) = 0x7fb7039d3000
mmap(0x7fb7039f8000, 64872, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7fb7039f8000
close(5)                                = 0
mprotect(0x7fb7039d3000, 73728, PROT_READ) = 0
openat(AT_FDCWD, "/sys/devices/system/cpu", O_RDONLY|O_NONBLOCK|O_DIRECTORY|O_CLOEXEC) = 5
getdents(5, /* 21 entries */, 32768)    = 592
close(5)                                = 0
brk(0x7fb7066e7000)                     = 0x7fb7066e7000
mmap(NULL, 8392704, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7fb7025d0000
mprotect(0x7fb7025d0000, 4096, PROT_NONE) = 0
clone(child_stack=0x7fb702dcffb0, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x7fb702dd09d0, tls=0x7fb702dd0700, child_tidptr=0x7fb702dd09d0) = 2653
mmap(NULL, 8392704, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7fb701dcf000
mprotect(0x7fb701dcf000, 4096, PROT_NONE) = 0
clone(child_stack=0x7fb7025cefb0, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x7fb7025cf9d0, tls=0x7fb7025cf700, child_tidptr=0x7fb7025cf9d0) = 2654
mmap(NULL, 8392704, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7fb7015ce000
mprotect(0x7fb7015ce000, 4096, PROT_NONE) = 0
clone(child_stack=0x7fb701dcdfb0, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x7fb701dce9d0, tls=0x7fb701dce700, child_tidptr=0x7fb701dce9d0) = 2655
mmap(NULL, 8392704, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7fb700dcd000
mprotect(0x7fb700dcd000, 4096, PROT_NONE) = 0
clone(child_stack=0x7fb7015ccfb0, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x7fb7015cd9d0, tls=0x7fb7015cd700, child_tidptr=0x7fb7015cd9d0) = 2656
mmap(NULL, 8392704, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7fb7005cc000
mprotect(0x7fb7005cc000, 4096, PROT_NONE) = 0
clone(child_stack=0x7fb700dcbfb0, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x7fb700dcc9d0, tls=0x7fb700dcc700, child_tidptr=0x7fb700dcc9d0) = 2657
mmap(NULL, 8392704, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7fb6ffdcb000
mprotect(0x7fb6ffdcb000, 4096, PROT_NONE) = 0
clone(child_stack=0x7fb7005cafb0, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x7fb7005cb9d0, tls=0x7fb7005cb700, child_tidptr=0x7fb7005cb9d0) = 2658
mmap(NULL, 8392704, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7fb6ff5ca000
mprotect(0x7fb6ff5ca000, 4096, PROT_NONE) = 0
clone(child_stack=0x7fb6ffdc9fb0, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x7fb6ffdca9d0, tls=0x7fb6ffdca700, child_tidptr=0x7fb6ffdca9d0) = 2659
mmap(NULL, 8392704, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7fb6fedc9000
mprotect(0x7fb6fedc9000, 4096, PROT_NONE) = 0
clone(child_stack=0x7fb6ff5c8fb0, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x7fb6ff5c99d0, tls=0x7fb6ff5c9700, child_tidptr=0x7fb6ff5c99d0) = 2660
close(5)                                = 0
close(5)                                = 0
close(5)                                = 0
close(5)                                = 0
close(5)                                = 0
close(5)                                = 0
close(5)                                = 0
close(5)                                = 0
close(5)                                = 0
close(5)                                = 0
close(5)                                = 0
close(5)                                = 0
close(5)                                = 0
close(5)                                = 0
close(5)                                = 0
mmap(NULL, 8392704, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7fb6fe5c8000
mprotect(0x7fb6fe5c8000, 4096, PROT_NONE) = 0
clone(child_stack=0x7fb6fedc7fb0, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x7fb6fedc89d0, tls=0x7fb6fedc8700, child_tidptr=0x7fb6fedc89d0) = 2661
mmap(NULL, 8392704, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7fb6fddc7000
mprotect(0x7fb6fddc7000, 4096, PROT_NONE) = 0
clone(child_stack=0x7fb6fe5c6fb0, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x7fb6fe5c79d0, tls=0x7fb6fe5c7700, child_tidptr=0x7fb6fe5c79d0) = 2662
mmap(NULL, 8392704, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7fb6fd5c6000
mprotect(0x7fb6fd5c6000, 4096, PROT_NONE) = 0
clone(child_stack=0x7fb6fddc5fb0, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x7fb6fddc69d0, tls=0x7fb6fddc6700, child_tidptr=0x7fb6fddc69d0) = 2663
mmap(NULL, 8392704, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7fb6fcdc5000
mprotect(0x7fb6fcdc5000, 4096, PROT_NONE) = 0
clone(child_stack=0x7fb6fd5c4fb0, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x7fb6fd5c59d0, tls=0x7fb6fd5c5700, child_tidptr=0x7fb6fd5c59d0) = 2664
mmap(NULL, 8392704, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7fb6fc5c4000
mprotect(0x7fb6fc5c4000, 4096, PROT_NONE) = 0
clone(child_stack=0x7fb6fcdc3fb0, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x7fb6fcdc49d0, tls=0x7fb6fcdc4700, child_tidptr=0x7fb6fcdc49d0) = 2665
mmap(NULL, 8392704, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7fb6fbdc3000
mprotect(0x7fb6fbdc3000, 4096, PROT_NONE) = 0
clone(child_stack=0x7fb6fc5c2fb0, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x7fb6fc5c39d0, tls=0x7fb6fc5c3700, child_tidptr=0x7fb6fc5c39d0) = 2666
mmap(NULL, 8392704, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7fb6fb5c2000
mprotect(0x7fb6fb5c2000, 4096, PROT_NONE) = 0
clone(child_stack=0x7fb6fbdc1fb0, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x7fb6fbdc29d0, tls=0x7fb6fbdc2700, child_tidptr=0x7fb6fbdc29d0) = 2667
mmap(NULL, 8392704, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7fb6fadc1000
mprotect(0x7fb6fadc1000, 4096, PROT_NONE) = 0
clone(child_stack=0x7fb6fb5c0fb0, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x7fb6fb5c19d0, tls=0x7fb6fb5c1700, child_tidptr=0x7fb6fb5c19d0) = 2668
stat("/opt/intel/mediasdk/lib64/libmfxplugin64_hw.so", 0x7fff5e961140) = -1 ENOENT (No such file or directory)
open("/opt/intel/mediasdk/plugins/plugins.cfg", O_RDONLY) = 5
fstat(5, {st_mode=S_IFREG|0644, st_size=643, ...}) = 0
lseek(5, 0, SEEK_SET)                   = 0
read(5, "[H264LA_Encoder_588f1185d47b4296"..., 4096) = 643
lseek(5, 643, SEEK_SET)                 = 643
read(5, "", 4096)                       = 0
read(5, "[H264LA_Encoder_588f1185d47b4296"..., 430) = 430
lseek(5, 430, SEEK_SET)                 = 430
brk(0)                                  = 0x7fb7066e7000
brk(0x7fb70670e000)                     = 0x7fb70670e000
read(5, "[VP8_Encoder_bffc518cde134df98a9"..., 4096) = 213
close(5)                                = 0
close(5)                                = 0
readlink("/proc/self/exe", "/home/tbekiares/Downloads/MediaS"..., 4095) = 126
openat(AT_FDCWD, "/home/tbekiares/Downloads/MediaSamples_Linux_6.0.16043175.175/samples/__cmake/intel64.make.debug/__bin/debug", O_RDONLY|O_NONBLOCK|O_DIRECTORY|O_CLOEXEC) = 5
getdents(5, /* 12 entries */, 32768)    = 440
close(5)                                = 0
futex(0x7fb7066c9614, FUTEX_WAKE_OP_PRIVATE, 1, 1, 0x7fb7066c9610, {FUTEX_OP_SET, 0, FUTEX_OP_CMP_GT, 1}) = 1
futex(0x7fb7066c9640, FUTEX_WAKE_PRIVATE, 1) = 1
futex(0x7fb7066c967c, FUTEX_WAKE_OP_PRIVATE, 1, 1, 0x7fb7066c9678, {FUTEX_OP_SET, 0, FUTEX_OP_CMP_GT, 1}) = 1
futex(0x7fb7066c96a8, FUTEX_WAKE_PRIVATE, 1) = 1
futex(0x7fb7066c96e4, FUTEX_WAKE_OP_PRIVATE, 1, 1, 0x7fb7066c96e0, {FUTEX_OP_SET, 0, FUTEX_OP_CMP_GT, 1}) = 1
futex(0x7fb7066c9710, FUTEX_WAKE_PRIVATE, 1) = 1
futex(0x7fb7066c974c, FUTEX_WAKE_OP_PRIVATE, 1, 1, 0x7fb7066c9748, {FUTEX_OP_SET, 0, FUTEX_OP_CMP_GT, 1}) = 1
futex(0x7fb7066c9778, FUTEX_WAKE_PRIVATE, 1) = 1
futex(0x7fb7066c97b4, FUTEX_WAKE_OP_PRIVATE, 1, 1, 0x7fb7066c97b0, {FUTEX_OP_SET, 0, FUTEX_OP_CMP_GT, 1}) = 1
futex(0x7fb7066c97e0, FUTEX_WAKE_PRIVATE, 1) = 1
futex(0x7fb7066c981c, FUTEX_WAKE_OP_PRIVATE, 1, 1, 0x7fb7066c9818, {FUTEX_OP_SET, 0, FUTEX_OP_CMP_GT, 1}) = 1
futex(0x7fb7066c9848, FUTEX_WAKE_PRIVATE, 1) = 1
futex(0x7fb7066c9884, FUTEX_WAKE_OP_PRIVATE, 1, 1, 0x7fb7066c9880, {FUTEX_OP_SET, 0, FUTEX_OP_CMP_GT, 1}) = 1
futex(0x7fb7066c98b0, FUTEX_WAKE_PRIVATE, 1) = 1
futex(0x7fb7066c98ec, FUTEX_WAKE_OP_PRIVATE, 1, 1, 0x7fb7066c98e8, {FUTEX_OP_SET, 0, FUTEX_OP_CMP_GT, 1}) = 1
futex(0x7fb7066c9918, FUTEX_WAKE_PRIVATE, 1) = 1
munmap(0x7fb6fe5c8000, 8392704)         = 0
munmap(0x7fb6fddc7000, 8392704)         = 0
munmap(0x7fb6fd5c6000, 8392704)         = 0
munmap(0x7fb6fcdc5000, 8392704)         = 0
close(5)                                = 0
close(5)                                = 0
close(5)                                = 0
close(5)                                = 0
close(5)                                = 0
close(5)                                = 0
close(5)                                = 0
close(5)                                = 0
close(5)                                = 0
close(5)                                = 0
close(5)                                = 0
close(5)                                = 0
close(5)                                = 0
close(5)                                = 0
open("/dev/dri/renderD128", O_RDWR)     = 5
fstat(5, {st_mode=S_IFCHR|0660, st_rdev=makedev(226, 128), ...}) = 0
open("/etc/libva.conf", O_RDONLY)       = -1 ENOENT (No such file or directory)
write(2, "libva info: VA-API version 0.35."..., 34libva info: VA-API version 0.35.0
) = 34
ioctl(5, 0xc0406400, 0x7fb7066c69d0)    = 0
write(2, "libva info: va_getDriverName() r"..., 41libva info: va_getDriverName() returns 0
) = 41
geteuid()                               = 0
getuid()                                = 0
write(2, "libva info: User requested drive"..., 40libva info: User requested driver 'iHD'
) = 40
geteuid()                               = 0
getuid()                                = 0
write(2, "libva info: Trying to open /opt/"..., 70libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so
) = 70
open("/opt/intel/mediasdk/lib64/iHD_drv_video.so", O_RDONLY|O_CLOEXEC) = 6
read(6, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\240\371\0\0\0\0\0\0"..., 832) = 832
fstat(6, {st_mode=S_IFREG|0755, st_size=28826704, ...}) = 0
mmap(NULL, 30948696, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 6, 0) = 0x7fb6fd045000
mprotect(0x7fb6fde93000, 2097152, PROT_NONE) = 0
mmap(0x7fb6fe093000, 13828096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 6, 0xe4e000) = 0x7fb6fe093000
mmap(0x7fb6fedc3000, 23896, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7fb6fedc3000
close(6)                                = 0
open("/etc/ld.so.cache", O_RDONLY|O_CLOEXEC) = 6
fstat(6, {st_mode=S_IFREG|0644, st_size=78328, ...}) = 0
mmap(NULL, 78328, PROT_READ, MAP_PRIVATE, 6, 0) = 0x7fb70523a000
close(6)                                = 0
open("/lib64/libdrm_intel.so.1", O_RDONLY|O_CLOEXEC) = 6
read(6, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\00000\0\0\0\0\0\0"..., 832) = 832
fstat(6, {st_mode=S_IFREG|0755, st_size=137896, ...}) = 0
mmap(NULL, 2230496, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 6, 0) = 0x7fb6fce24000
mprotect(0x7fb6fce44000, 2093056, PROT_NONE) = 0
mmap(0x7fb6fd043000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 6, 0x1f000) = 0x7fb6fd043000
close(6)                                = 0
open("/lib64/librt.so.1", O_RDONLY|O_CLOEXEC) = 6
read(6, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\300\"\0\0\0\0\0\0"..., 832) = 832
fstat(6, {st_mode=S_IFREG|0755, st_size=44088, ...}) = 0
mmap(NULL, 2128952, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 6, 0) = 0x7fb6fabb9000
mprotect(0x7fb6fabc0000, 2093056, PROT_NONE) = 0
mmap(0x7fb6fadbf000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 6, 0x6000) = 0x7fb6fadbf000
close(6)                                = 0
open("/usr/lib64/tls/x86_64/libpciaccess.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib64/tls/x86_64", 0x7fff5e963c30) = -1 ENOENT (No such file or directory)
open("/usr/lib64/tls/libpciaccess.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib64/tls", {st_mode=S_IFDIR|0555, st_size=6, ...}) = 0
open("/usr/lib64/x86_64/libpciaccess.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib64/x86_64", 0x7fff5e963c30) = -1 ENOENT (No such file or directory)
open("/usr/lib64/libpciaccess.so.0", O_RDONLY|O_CLOEXEC) = 6
read(6, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0@#\0\0\0\0\0\0"..., 832) = 832
fstat(6, {st_mode=S_IFREG|0755, st_size=40776, ...}) = 0
mmap(NULL, 2134536, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 6, 0) = 0x7fb6fa9af000
mprotect(0x7fb6fa9b7000, 2097152, PROT_NONE) = 0
mmap(0x7fb6fabb7000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 6, 0x8000) = 0x7fb6fabb7000
close(6)                                = 0
mprotect(0x7fb6fabb7000, 4096, PROT_READ) = 0
mprotect(0x7fb6fadbf000, 4096, PROT_READ) = 0
mprotect(0x7fb6fd043000, 4096, PROT_READ) = 0
mprotect(0x7fb6fe093000, 8192, PROT_READ) = 0
write(2, "libva info: Found init function "..., 52libva info: Found init function __vaDriverInit_0_32
) = 52
open("/proc/mounts", O_RDONLY)          = 6
fstat(6, {st_mode=S_IFREG|0444, st_size=0, ...}) = 0
read(6, "rootfs / rootfs rw 0 0\nproc /pro"..., 1024) = 1024
read(6, " 0\ncgroup /sys/fs/cgroup/devices"..., 1024) = 1024
close(6)                                = 0
open("/sys/kernel/config/Registry/HKCU/LibVa/XML AutoGen Enable", O_RDONLY) = -1 ENOENT (No such file or directory)
ioctl(5, 0x80106463, 0x7fff5e964850)    = 0
geteuid()                               = 0
getuid()                                = 0
ioctl(5, 0xc0106446, 0x7fff5e964870)    = 0
ioctl(5, 0xc0106446, 0x7fff5e964860)    = 0
ioctl(5, 0xc0186473, 0x7fff5e964870)    = 0
ioctl(5, 0x40086409, 0x7fff5e964840)    = 0
open("/sys/kernel/config/Registry/HKCU/LibVa/VC1Enabled", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/sys/kernel/config/Registry/HKCU/LibVa/VP9 Decode Mode", O_RDONLY) = -1 ENOENT (No such file or directory)
ioctl(5, 0xc0106446, 0x7fff5e9647e0)    = 0
openat(AT_FDCWD, "/sys/bus/pci/drivers/i915", O_RDONLY|O_NONBLOCK|O_DIRECTORY|O_CLOEXEC) = 6
getdents(6, /* 9 entries */, 32768)     = 264
open("/sys/bus/pci/drivers/i915/bind/config", O_RDONLY) = -1 ENOTDIR (Not a directory)
open("/sys/bus/pci/drivers/i915/0000:00:02.0/config", O_RDONLY) = 7
fstat(7, {st_mode=S_IFREG|0644, st_size=256, ...}) = 0
read(7, "\206\200f\1\7\4\220\0\t\0\0\3\0\0\0\0\4\0\200\367\0\0\0\0\f\0\0\340\0\0\0\0"..., 4096) = 256
close(7)                                = 0
close(6)                                = 0
openat(AT_FDCWD, "/sys/devices/system/cpu", O_RDONLY|O_NONBLOCK|O_DIRECTORY|O_CLOEXEC) = 6
getdents(6, /* 21 entries */, 32768)    = 592
getdents(6, /* 0 entries */, 32768)     = 0
close(6)                                = 0
fstat(1, {st_mode=S_IFCHR|0620, st_rdev=makedev(136, 0), ...}) = 0
futex(0x7fb6fedc34e0, FUTEX_WAKE_PRIVATE, 1) = 0
write(2, "libva error: /opt/intel/mediasdk"..., 68libva error: /opt/intel/mediasdk/lib64/iHD_drv_video.so init failed
) = 68
write(2, "libva info: va_openDriver() retu"..., 38libva info: va_openDriver() returns 1
) = 38
close(5)                                = 0
open("/dev/dri/card0", O_RDWR)          = 5
fstat(5, {st_mode=S_IFCHR|0660, st_rdev=makedev(226, 0), ...}) = 0
) = 34
ioctl(5, 0xc0406400, 0x7fb7066c6a10)    = 0
ioctl(5, 0x80046402, 0x7fff5e964ba0)    = 0
ioctl(5, 0xc0286405, 0x7fff5e964ad0)    = 0
) = 41
geteuid()                               = 0
getuid()                                = 0
) = 40
geteuid()                               = 0
getuid()                                = 0
) = 70
) = 52
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7fb70524c000
close(7)                                = 0
munmap(0x7fb70524c000, 4096)            = 0
close(6)                                = 0
close(6)                                = 0
) = 68
) = 38
close(5)                                = 0
futex(0x7fb703fde190, FUTEX_WAKE_PRIVATE, 2147483647) = 0
write(2, "'\n", 2'
)                      = 2
write(2, "\n", 1
)                       = 1
write(1, "Unrecognized device ID 0166Unrec"..., 54Unrecognized device ID 0166Unrecognized device ID 0166) = 54
tgkill(2652, 2652, SIGABRT)             = 0
--- SIGABRT {si_signo=SIGABRT, si_code=SI_TKILL, si_pid=2652, si_uid=0} ---
+++ killed by SIGABRT (core dumped) +++
and the output from vainfo:
[root@localhost debug]# vainfo
vaInitialize failed with error code 1 (operation failed),exit
thoughts?
Thanks!
Ty
Jiandong_Z_Intel
Hi There,
From following output:
Your CPU i7-3612QE is not support by Media Server Studio R6, You can refer
Essential/Community Edition Release Notes - Linux* page 2 System Requirements parts for more details.
Maybe you should upgrade your HW.
Zahcary
Tyrone_B_1
ah, I didn't realize the latest SDK wasn't backwards compatible to older (Gen3) i7s. Do you happen to know the last release of the Media SDK compatible with Gen3 i7s?
thx!
Ty
Surbhi_M_Intel
Hi Tyrone,
All the Media Server Studio releases supports n and n-1 generations. Therefore we have a support for 4th and 5th generation now. Gen3 was last supported on MSS 2015 R3 I believe but that is not available on the product download. Only the latest releases are available and we do not support 3rd generation and below.
Hope that answers your query.
Surbhi
