3058 Discussions
MSS 2016 Generic install: /dev/dri/ absent (Core i7-4770)
Konstantin_K_3
Hello.
I've installed sdk (SDK2016Production16.4.4), patched kernel, rebuilt libdrm/libva, but `vainfo` fails and `/dev/dri` is absent. I followed ubuntu installation guide step by step. There were no errors. And after reboot I have kernel 3.14.5 active. But there no `dev/dri` path, `vainfo` shows:
error: failed to initialize display
Aborted
and `lsmod` have no `i915` record.
I can load it with:
# modprobe i915
# lsmod | grep i915
i915                  661290  0
drm_kms_helper         31885  1 i915
drm                   213209  2 i915,drm_kms_helper
i2c_algo_bit           12841  1 i915
i2c_core               24304  5 drm,i915,i2c_i801,drm_kms_helper,i2c_algo_bit
video                  17804  1 i915
button                 12944  1 i915
But it changes nothing in `vainfo` and `/dev/dri`
CPU: Core(TM) i7-4770 CPU @ 3.40GHz (Cores 8)
`lspci -nn | grep VGA`
00:02.0 VGA compatible controller [0300]: Intel Corporation Haswell Integrated Graphics Controller [8086:0412] (rev 06)
`uname-r`:
Linux Debian-78-wheezy-64-minimal 3.14.5 #2 SMP Fri May 27 03:48:48 MSK 2016 x86_64 GNU/Linux
How to fix this issue?
Jeffrey_M_Intel1
Hi Konstantin,
Here is a prototype system analyzer for Linux to help diagnose issues like this:
https://software.intel.com/en-us/articles/mss-sys-analyzer-linux
There are more details on manual diagnostics here:
http://www.intel.com/content/www/us/en/cloud-computing/quicksync-video-ffmpeg-install-valid.html
From your description I suspect that you may have booted with 'nomodeset' or i915.modeset=0, but hopefully these references will help fill in more details.
Konstantin_K_3
Hi Jeffrey,
Thank you for reply. You are right, there was `nomodeset` in grub. I've removed it, updated grub, rebooted, but issue is still here.
System Analyzer output:
Hardware readiness checks:
 [ OK ] Processor name: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
 [ INFO ] Intel Processor
 [ INFO ] Processor brand: Core
 [ INFO ] Processor arch: Haswell
OS readiness checks:
 [ INFO ] GPU PCI id     : 0412
 [ INFO ] GPU description: HSW_D GT2 desktop
 [ OK ] GPU visible to OS
 [ INFO ] no nomodeset in GRUB cmdline (good)
 [ INFO ] Linux distro   : debian 7.8
 [ INFO ] Linux kernel   : 3.14.5
 [ INFO ] glibc version  : 2.13
 [ INFO ] Linux distro suitable for Generic install
 [ INFO ] gcc version    : 4.7.2 (>=4.8.2 suggested)
Media Server Studio Install:
 [ OK ] user in video group
 [ OK ] libva.so.1 found
 [ ERROR ] libva not loading Intel iHD
 [ ERROR ] vainfo not reporting codec entry points
 [ ERROR ] Intel video adapter not using i915
 [ ERROR ] no /dev/dri/renderD* interfaces found
Component Smoke Tests:
 [ OK ] Media SDK HW API level:1.17
 [ OK ] Media SDK SW API level:1.17
 [ OK ] OpenCL check:
Media SDK Plugins available:
(for more info see /opt/intel/mediasdk/plugins/plugins.cfg)
    H264LA Encoder 	= 588f1185d47b42968dea377bb5d0dcb4
    VP8 Decoder 	= f622394d8d87452f878c51f2fc9b4131
Am I need to do something else in addition to removing `nomodeset`?
Now reading "quicksync-video-ffmpeg-install-valid.pdf" to find more info…
Konstantin_K_3
# lspci -vv -nn -s 00:02.0
00:02.0 VGA compatible controller [0300]: Intel Corporation Haswell Integrated Graphics Controller [8086:0412] (rev 06) (prog-if 00 [VGA controller])
	Subsystem: Micro-Star International Co., Ltd. Device [1462:7816]
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0
	Interrupt: pin A routed to IRQ 11
	Region 0: Memory at f7800000 (64-bit, non-prefetchable) [size=4M]
	Region 2: Memory at e0000000 (64-bit, prefetchable) [size=256M]
	Region 4: I/O ports at f000 [size=64]
	Expansion ROM at <unassigned> [disabled]
	Capabilities: [90] MSI: Enable- Count=1/1 Maskable- 64bit-
		Address: 00000000  Data: 0000
	Capabilities: [d0] Power Management version 2
		Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
		Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
	Capabilities: [a4] PCI Advanced Features
		AFCap: TP+ FLR+
		AFCtrl: FLR-
		AFStatus: TP-
But "quicksync-video-ffmpeg-install-valid.pdf" says there should be "Kernel driver in use: i915" after Capabilities (who and why disabled Copy to clipboard in that pdf???). So again we see, kernel driver is not used.
Pdf says about `/sys/bus/pci/devices/0000:00:02.0` path, and I checked it. The strange thing is `/sys/bus/pci/devices/0000:00:02.0/enabled` which is `0`. I don't know much about linuxes, but looks like the device is disabled.
At the same time I see the following in dmesg:
[    0.262344] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[    0.262414] vgaarb: loaded
[    0.262461] vgaarb: bridge control possible 0000:00:02.0
It's remote server, and I can't check BIOS settings. There no X-server or any gui. Can this be a problem?
How can I enable the device?
Jeffrey_M_Intel1
Thanks for gathering the info. No GUI or X Windows is not a problem.  However,  since lspci is not saying the GPU is visible to the OS, there may not be much you can do without access to the system.  Causes could be:
  • BIOS doesn't enable processor graphics
  • Chipset or other HW doesn't enable graphics
There may be an option in your BIOS to enable processor graphics.  For HW, if your processor is a Xeon your chipset should be C226.  If you  don't see the graphics option in your BIOS, your OEM may be better able to help you with next steps.
Konstantin_K_3
Hi Jeffrey,
Thanks for your answer. The server is remote, so I can't access it's BIOS easily.
So I got another server and installed Centos 7.1 on it. The MSS worked fine. `lsmod` showed that `i915` is loaded (even before MSS installation). And after installation I can see device is enabled in `/sys/bus/pci/devices/0000:00:02.0/enable` (there is "1" inside this file).
But I need to run MSS on Debian/Ubuntu. So I've reinstalled Debian 8.5 on the same server.
Now `lsmod` shows no loaded `i915` drivers. And there is "0" inside `/sys/bus/pci/devices/0000:00:02.0/enable`.
What can be the problem?
Konstantin_K_3
Finally I've solved the issue. It was os pre-configuration.
The i915 module was disabled in `/etc/modprobe.d/` blacklist. I enabled it, and tests passed fine. Sample encoding/decoding works too.
