I have just done a fresh install of the latest CentOS 7 CentOS-7-x86_64-Everything-1611.iso.
I downloaded the MediaServerStudioEssentials2017.tar.gz, and executed MediaServerStudioEssentials2017/SDK2017Production16.5/CentOS/install_sdk_CentOS.sh with sudo.
But the script complains the failed dependencies when installing kmod-ukmd rpm with the following message:
Installing kmod-ukmd-16.5-55964... error: Failed dependencies: kernel(dma_buf_attach) = 0xfa625ae7 is needed by kmod-ukmd-16.5-55964.el7.x86_64 kernel(dma_buf_detach) = 0x96af1fbc is needed by kmod-ukmd-16.5-55964.el7.x86_64 kernel(dma_buf_export) = 0xc29ffda2 is needed by kmod-ukmd-16.5-55964.el7.x86_64 kernel(dma_buf_fd) = 0x839654d1 is needed by kmod-ukmd-16.5-55964.el7.x86_64 kernel(dma_buf_get) = 0x3d69c155 is needed by kmod-ukmd-16.5-55964.el7.x86_64 kernel(dma_buf_map_attachment) = 0xb82925d1 is needed by kmod-ukmd-16.5-55964.el7.x86_64 kernel(dma_buf_put) = 0xf7ec7b43 is needed by kmod-ukmd-16.5-55964.el7.x86_64 kernel(dma_buf_unmap_attachment) = 0xdfd6347f is needed by kmod-ukmd-16.5-55964.el7.x86_64 kernel(fput) = 0x76bcc79d is needed by kmod-ukmd-16.5-55964.el7.x86_64 kernel(i2c_new_device) = 0x62f8040e is needed by kmod-ukmd-16.5-55964.el7.x86_64 kernel(i2c_transfer) = 0x5e7d6573 is needed by kmod-ukmd-16.5-55964.el7.x86_64 kernel(i2c_unregister_device) = 0x609ae14e is needed by kmod-ukmd-16.5-55964.el7.x86_64 kernel(perf_tp_event) = 0x66a49d27 is needed by kmod-ukmd-16.5-55964.el7.x86_64 Installation done.
Does anyone know how to solve it? Thanks!
Hi Huihai,
I'am actually facing the same issue. Did you found the answer ?
F.Deschamps
