The monochrome 10bit images from openCV should be compressed in a H.265 file with Kaby Lake HW accelerator (Ubuntu 19.10).
Because the supported formats are not b/w I changed to an RGB (CV_16UC3) image which is converted to YUV using cvtBGRtoTwoPlaneYUV.
int fourcc = cv::VideoWriter::fourcc('H', '2', '6', '5'); ... params.mfx.CodecId = codecId; params.mfx.TargetUsage = MFX_TARGETUSAGE_BALANCED; params.mfx.TargetKbps = (mfxU16)cvRound(frameSize.area() * fps / 500); // TODO: set in options params.mfx.RateControlMethod = MFX_RATECONTROL_VBR; params.mfx.FrameInfo.FrameRateExtN = cvRound(fps * 1000); params.mfx.FrameInfo.FrameRateExtD = 1000; params.mfx.FrameInfo.BitDepthLuma = 10; // added by customer params.mfx.FrameInfo.BitDepthChroma = 10; // added by customer params.mfx.FrameInfo.FourCC = MFX_FOURCC_P010; // modified by customer params.mfx.FrameInfo.Shift = 1; // added by customer params.mfx.FrameInfo.ChromaFormat = MFX_CHROMAFORMAT_YUV420; params.mfx.FrameInfo.PicStruct = MFX_PICSTRUCT_PROGRESSIVE; params.mfx.FrameInfo.CropX = 0; params.mfx.FrameInfo.CropY = 0; params.mfx.FrameInfo.CropW = (mfxU16)frameSize.width; params.mfx.FrameInfo.CropH = (mfxU16)frameSize.height; params.mfx.FrameInfo.Width = (mfxU16)alignSize(frameSize.width, 32); params.mfx.FrameInfo.Height = (mfxU16)alignSize(frameSize.height, 32); params.IOPattern = MFX_IOPATTERN_IN_SYSTEM_MEMORY;
The changes from the openCV videoio code are highlighted. This results in the output:
FrameInfo: | FourCC: P010 (0x30313050) | Size: 288x288 | ROI: (0;0) 288x288 | BitDepth(L/C): 10 / 10 | Shift: 1 | TemporalID: 0 | FrameRate: 10000/1000 | AspectRatio: 0x0 | PicStruct: 1 | ChromaFormat: 1
By calling write_one I get the output:
MFX GetVideoParam: MFX_ERR_NONE (0) requested 414 kB BS Open /home/appVideo/data/o.mp4 -> 1 BS Allocate 847872 bytes (0.808594 Mb) Calling with surface: 0x7fffec042450 ERR_MORE_DATA Calling with surface: 0x7fffec042508 ERR_MORE_DATA Calling with surface: 0x7fffec0425c0 ERR_MORE_DATA Calling with surface: 0x7fffec042678 ERR_MORE_DATA Calling with surface: 0x7fffec042730 MFX: Sync error: MFX_ERR_UNDEFINED_BEHAVIOR (-16) Calling with surface: 0x7fffec0427e8 MFX: Sync error: MFX_ERR_UNDEFINED_BEHAVIOR (-16) Calling with surface: 0x7fffec0428a0 MFX: Sync error: MFX_ERR_UNDEFINED_BEHAVIOR (-16) Calling with surface: 0x7fffec042958 MFX: Sync error: MFX_ERR_UNDEFINED_BEHAVIOR (-16) Calling with surface: 0x7fffec042a10
The ERR_MORE_DATA is normal according to the documentation. Because I did not find any documentation about the message MFX_ERR_UNDEFINED_BEHAVIOR I would like to ask the experts for support. Please let me know if I should take other formats to handle 10bit mono frames, etc. - Thank you, Christoph
- Tags:
- Development Tools
- Graphics
- Intel® Media SDK
- Intel® Media Server Studio
- Media Processing
- Optimization
Since you're on Linux you can debug it manually using opensource MediaSDK. But most likely the error is due to wrong surface initialization:
surface.Data.Y = dataPtr;
surface.Data.UV = dataPtr + width * height;
surface.Data.PitchLow = width & 0xFFFF;
surface.Data.PitchHigh = (width >> 16) & 0xFFFF;
You want 10 bit surface. 10 bits are stored in two bytes, not in 1,25 bytes. So pointers to Y/U/V has to be set accordingly: https://github.com/Intel-Media-SDK/MediaSDK/blob/master/samples/sample_common/src/sysmem_allocator.cpp#L176
This is also wrong: "oneSize(width * height * bpp / 8)".
