I'm compiling up the DirectShow H.264 Encoder, trying to get it to work. However i cannot get it to connect to any source filters.
it's failing on this line
mfx_video_enc_filter.cpp:944 sts = m_pEncoder->m_pmfxVPP->QueryIOSurf(&m_mfxParamsVPP, mfxVppRequest);
sts is MFX_ERR_INVALID_VIDEO_PARAM
The source filter works on my own x264 filter, as wells as elecard's encoder, Main concepts, and LEAD's h.264 encoder. The source outputs 1080p, RGB32, 25fps.
I'm just starting to get into QuickSync programing, and would appreciate any help.
Processor Type:Intel(R) Core(TM) i5-5250U CPU @ 1.60GHz
Driver Version:Intel(R) HD Graphics 6000 10.18.14.4156
Operating System:Microsoft Windows 8.1 Pro
Media SDK System Analyzer:
Version Target Supported Dec Enc
1.0 HW Yes X X
1.0 SW Yes X X
1.1 HW Yes X X
1.1 SW Yes X X
1.3 HW Yes X X
1.3 SW Yes X X
1.4 HW Yes X X
1.4 SW Yes X X
1.5 HW Yes X X
1.5 SW Yes X X
1.6 HW Yes X X
1.6 SW Yes X X
1.7 HW Yes X X
1.7 SW Yes X X
1.8 HW Yes X X
1.8 SW Yes X X
What I've discovered is if i set the resolution to a power of 32, eg 1920*1088 sometimes it works.
Hi Kevin, thanks for your updates. Your system is based on Broadwell architecture. Currently Media SDK doesn't support Broadwell. Please refer to this thread (http://software.intel.com/en-us/forums/topic/545094) for related information. Thanks.
It also does not work on
Processor Type:Intel(R) Core(TM) i5-4250U CPU @ 1.30GHz 1.90GHz
I noticed you mentioned that you are providing "1080p, RGB32, 25fps" input.
It has been a while since I looked at the older Direct Show sample encoder, however I believe it only accepts NV12 (YUV 420) input.
