I have recently downloaded and tested the sample for the screen capture plugin, but the sample that comes with the plugin from this link: https://software.intel.com/en-us/articles/intel-media-sdk-screen-capture does not work.
I have been able to make it work with the DX 9 API and YUV NV12 format. But if I use ARGB or AYUV it fails to create the DX surfaces.
If I use the DX 11 API for surface allocation, I only end up with blank frames.
Have anyone been able to utilize the screen capture plugin successfully with the DX 11 API?
My system has a Xeon E5-120 v3 and I'm using the software implementation for the SDK with the screen capture plugin.
Hi There,
Are you using the most new MSDK edition.
https://software.intel.com/en-us/intel-media-server-studio
https://software.intel.com/en-us/media-sdk
Can you share the log of mediasdk_sys_analyzer for understand your system info ?
Zachary
Hi Danilo, what version of Windows operating system you are using? Also what is display adapter installed on your system. Depending on OS and display adapter dx11 path can be not supported.
