In my code, the "_mfx_session.InitEx" return -3("MFX_ERR_UNSUPPORTED = -3, /* undeveloped feature */").
I compare with the decode sample, sample use "ExtBufHolder<mfxInitParam>", but I use "mfxInitParam",
Is the new version of media SDK incompatible with the previous program?
Operating System: Windows 10 专业版 64-bit (10.0, Build 19041) (19041.vb_release.191206-1406)
Processor: 11th Gen Intel(R) Core(TM) i5-1145G7 @ 2.60GHz (8 CPUs), ~2.6GHz
Driver Version: 27.20.100.9268
mfxStatus sts = MFX_ERR_NONE;
mfxInitParam initPar;
memset(&initPar, 0x00, sizeof(initPar));
memset(&_mfx_video_params, 0x00, sizeof(_mfx_video_params));
// we set version to 1.0 and later we will query actual version of the library which will got leaded
initPar.Version.Major = 1;
initPar.Version.Minor = 0;
initPar.GPUCopy = MFX_GPUCOPY_ON;
// try searching on all display adapters
initPar.Implementation = MFX_IMPL_HARDWARE_ANY;
if (RENDER_DX11_HW == m_renderType){
initPar.Implementation |= MFX_IMPL_VIA_D3D11;
//_mfx_video_params.mfx.FrameInfo.FourCC = MFX_MAKEFOURCC('N', 'V', '1', '2');
//_mfx_video_params.mfx.FrameInfo.ChromaFormat = 1;
MSDK_ZERO_MEMORY(m_DecodeErrorReport);
m_DecodeErrorReport.Header.BufferId = MFX_EXTBUFF_DECODE_ERROR_REPORT;
unique_lock_t lock(_g_mutex);
sts = _mfx_session.InitEx(initPar);
the newest sample code:
using mfxInitParamlWrap = ExtBufHolder<mfxInitParam>;
mfxInitParamlWrap initPar;
initPar.GPUCopy = pParams->gpuCopy;
if (pParams->nThreadsNum)
auto threadsPar = initPar.AddExtBuffer<mfxExtThreadsParam>();
threadsPar->NumThread = pParams->nThreadsNum;
if (pParams->SchedulingType)
threadsPar->SchedulingType = pParams->SchedulingType;
if (pParams->Priority)
threadsPar->Priority = pParams->Priority;
if (pParams->eDeinterlace)
m_diMode = pParams->eDeinterlace;
if (pParams->bUseFullColorRange)
m_bVppFullColorRange = pParams->bUseFullColorRange;
bool bResolutionSpecified = pParams->Width || pParams->Height; // potentially VPP can be inserted
if (bResolutionSpecified)
m_bDecOutSysmem = pParams->bUseHWLib ? false : true;
else
m_bDecOutSysmem = m_memType == SYSTEM_MEMORY;
m_eWorkMode = pParams->mode;
m_monitorType = pParams->monitorType;
// create device and allocator
#if defined(LIBVA_SUPPORT)
m_libvaBackend = pParams->libvaBackend;
#endif // defined(MFX_LIBVA_SUPPORT)
sts = GetImpl(*pParams, initPar.Implementation);
MSDK_CHECK_STATUS(sts, "GetImpl failed");
sts = m_mfxSession.InitEx(initPar);
hi, I chI changed the code of sample to be the same as mine, which also returns -3.
The sample code I modified has been uploaded as an attachment, thank you very much. @Mark_L_Intel1
//mfxInitParamlWrap initPar;
else
MSDK_CHECK_STATUS(sts, "m_mfxSession.InitEx failed");
@Gael_H_Intel @Mark_L_Intel1
Why didn't anyone pay attention to my question?
Shouldn't the new Intel drivers be compatible with old applications?
In addition, my original code is normal in other versions. Only in this version can initex fail.
Thanks for reaching out to us. We are extremely sorry for the delay.
Could you please share the following details:
1) Media SDK version?
2) API version reported when running your code?
3) Is it possible to use the same tutorial code available along with the Media SDK?
1)Media SDK version: 1.34
2)API version: 1.20
3)Because the code of the mediasdk header file used in our program has been modified by us, direct replacement is not feasible and it is very difficult to combine.
----PS:I tracked it with SDK tracker and found that it was caused by the failure to load libmfxhw32.dll. Why can sample load successfully, but my program can't load successfully?
@AthiraM_Intel
After I updated libmfx.lib in the new SDK this afternoon, the problem was solved, There are recent updates to this library, right?
Glad to know that your issue is resolved.
The latest Media SDK version for windows is 2021 R1.
To know more about the changes in the latest release please refer the below link :
https://software.intel.com/content/www/us/en/develop/download/media-sdk-windows-release-notes.html
Hope this helps.
Could you please give us an update? Has the solution provided helped?
I assume that the solution provided helped. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
