Installation follows the pattern described in this thread:https://software.intel.com/en-us/forums/intel-media-sdk/topic/691360
Outputs from all tests etc (below). look very encouraging. But running the multi_transcode example fails with error code -3. strace reveals a failure to find igfx_registry.txt? What have I missed here?
-----------------elided strace---------------------
open("/opt/intel/opencl/libdrm_intel.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/local/lib/libdrm_intel.so", O_RDONLY|O_CLOEXEC) = 6
read(6, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\2200\0\0\0\0\0\0"..., 832) = 832
fstat(6, {st_mode=S_IFREG|0755, st_size=445016, ...}) = 0
close(6) = 0
ioctl(3, _IOC(_IOC_READ|_IOC_WRITE, 0x64, 0x76, 0x10), 0x7ffe767de990) = -1 EINVAL (Invalid argument)
open("/etc/igfx_registry.txt", O_RDONLY) = -1 ENOENT (No such file or directory)
write(1, "\n", 1
) = 1
write(1, "Return on error: error code -3,\t"..., 167Return on error: error code -3, /home/lab_msdk/buildAgentDir/buildAgent_MediaSDK4/git/mdp_msdk-samples/samples/sample_multi_transcode/src/pipeline_transcode.cpp 2924
) = 167
write(1, "\n", 1
) = 1
write(1, "Return on error: error code -3,\t"..., 170Return on error: error code -3, /home/lab_msdk/buildAgentDir/buildAgent_MediaSDK4/git/mdp_msdk-samples/samples/sample_multi_transcode/src/sample_multi_transcode.cpp 307
-------------------------snip---------------------------------
jevans@nuci5:~/Intel$ uname -a
Linux nuci5 4.4.0-31-generic #50-Ubuntu SMP Wed Jul 13 00:07:12 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
jevans@nuci5:~/Intel$ vainfo
libva info: VA-API version 0.99.0
libva info: va_getDriverName() returns 0
libva info: User requested driver 'iHD'
libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so
libva info: Found init function __vaDriverInit_0_32
libva info: va_openDriver() returns 0
vainfo: VA-API version: 0.99 (libva 1.67.0.pre1)
vainfo: Driver version: 16.5.55964-ubit
vainfo: Supported profile and entrypoints
VAProfileH264ConstrainedBaseline: VAEntrypointVLD
VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice
VAProfileH264ConstrainedBaseline: <unknown entrypoint>
VAProfileH264Main : VAEntrypointVLD
VAProfileH264Main : VAEntrypointEncSlice
VAProfileH264Main : <unknown entrypoint>
VAProfileH264High : VAEntrypointVLD
VAProfileH264High : VAEntrypointEncSlice
VAProfileH264High : <unknown entrypoint>
VAProfileMPEG2Simple : VAEntrypointEncSlice
VAProfileMPEG2Simple : VAEntrypointVLD
VAProfileMPEG2Main : VAEntrypointEncSlice
VAProfileMPEG2Main : VAEntrypointVLD
VAProfileVC1Advanced : VAEntrypointVLD
VAProfileVC1Main : VAEntrypointVLD
VAProfileVC1Simple : VAEntrypointVLD
VAProfileJPEGBaseline : VAEntrypointVLD
VAProfileJPEGBaseline : VAEntrypointEncPicture
VAProfileVP8Version0_3 : VAEntrypointEncSlice
VAProfileVP8Version0_3 : VAEntrypointVLD
VAProfileVP8Version0_3 : <unknown entrypoint>
VAProfileVP9Profile0 : <unknown entrypoint>
<unknown profile> : VAEntrypointVideoProc
VAProfileNone : VAEntrypointVideoProc
VAProfileNone : <unknown entrypoint>
jevans@nuci5:~/Intel$ python sys_analyzer_linux.py
Hardware readiness checks:
[ OK ] Processor name: Intel(R) Core(TM) i5-5250U CPU @ 1.60GHz
OS readiness checks:
[ OK ] GPU visible to OS
Intel(R) Media Server Studio Install:
[ OK ] user in video group
[ OK ] libva.so.1 found
[ OK ] vainfo reports valid codec entry points
[ OK ] /dev/dri/renderD128 connects to Intel i915
Media SDK Plugins available:
(for more info see /opt/intel/mediasdk/plugins/plugins.cfg)
H264LA Encoder = 588f1185d47b42968dea377bb5d0dcb4
VP8 Decoder = f622394d8d87452f878c51f2fc9b4131
HEVC Decoder = 33a61c0b4c27454ca8d85dde757c6f8e
HEVC Encoder = 6fadc791a0c2eb479ab6dcd5ea9da347
Component Smoke Tests:
[ OK ] Media SDK HW API level:1.19
[ OK ] Media SDK SW API level:1.19
[ OK ] OpenCL check:platform:Intel(R) OpenCL GPU OK CPU OK
jevans@nuci5:~/Intel$ /opt/intel/mediasdk/samples/sample_multi_transcode -i::h264 ~/Intel/test_stream.264 -o::h264 ~/Intel/out.h264 -hw -la
Multi Transcoding Sample Version 7.0.16053497
Pipeline surfaces number (DecPool): 59
Return on error: error code -3, /home/lab_msdk/buildAgentDir/buildAgent_MediaSDK4/git/mdp_msdk-samples/samples/sample_multi_transcode/src/pipeline_transcode.cpp2924
I am not quite clear your installation process but I think that is the problem. From the error message, it seems libdrm is not the correct version, but the problem might happens all i915-i965-libdrm-libva stack, so please clarify these software components carefully.
The script was originally wrote for Ubuntu14.04, it should be ok for 16.04 but there might be little bit difference.
Mark
Hi JME,
I'm getting the exact same error as yours,
How did you fix the problem?
Hi joo,
Did you install it in ubuntu ?
Can you Share the steps ?
