Media (Intel® oneAPI Video Processing Library, Intel Media SDK)
Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
MediaSDK : Chroma 4:1:1 (YUV411) JPEG Encoding
Prakash__Sree
As per the JPEG manual ("mediasdkjpeg-man.pdf"), ENCODE is supported for Chroma 4:1:1 (Page 6 of 9),
However, there is hardly any reference to the support in the sample (sample_encode.sln).
What I am trying to figure out is which FourCC enum in mfxStructures.h should be used to represent Chroma 4:1:1 (YUV411).
MFX_FOURCC_UYVY represents YUV422.
MFX_FOURCC_NV12 can be used for YUV420.
But which FourCC enum represents YUV411 ?
And is it actually supported as claimed in the documentation?
Mark_L_Intel1
Hi Prakash,
I will check what the solution.
Initially, you could use other chroma format with enum since the chroma format implies some kind of memory mapping during decoding.
So you can try YUV422 or YUV420, if this doesn't work, you could check the FourCC for the memory layout of the frame in different chroma format to get a clue.
Mark
Mark_L_Intel1
Hi Prakash,
I think there is a mistake in JPEG manual, if you see the following document, you can find it at page 116:
https://github.com/Intel-Media-SDK/MediaSDK/tree/master/doc
MFX_CHROMAFORMAT_YUV411
Mark
