MediaSamples_Linux_6.0 generated failed
然_魏_
Hi, I tried to generated MediaSamples with MediaServerStudioEssentials2015R6. following
\MediaSamples_Linux_6.0.16043175.175\Media_Samples_Guide.pdf
Error details:
[ samples]# perl build.pl --cmake=intel64,make,debug --build --clean
cd /home/MediaSDK_R6/MediaSamples_Linux_6.0.16043175.175/samples/__cmake/intel64.make.debug/sample_plugins/rotate_opencl && /bin/c++   -DLINUX -DLINUX32 -DLINUX64 -DMFX_FILE_VERSION=\"0.15.11.30\" -DMFX_PRODUCT_VERSION=\"0.0.000.0000\" -DUNIX -D_FILE_OFFSET_BITS=64 -D__USE_LARGEFILE64 -Dsample_plugin_opencl_EXPORTS -m64 -msse4.2 -pipe -fPIC -O0 -Wall -Wno-unknown-pragmas -Wno-unused -g -D_DEBUG -fPIC -I/opt/intel/mediasdk/include -I/home/MediaSDK_R6/MediaSamples_Linux_6.0.16043175.175/samples/sample_common/include -I/home/MediaSDK_R6/MediaSamples_Linux_6.0.16043175.175/samples/sample_plugins/rotate_opencl/include    -DCL_USE_DEPRECATED_OPENCL_1_1_APIS  -I/usr/include  -DLIBVA_SUPPORT  -o CMakeFiles/sample_plugin_opencl.dir/src/opencl_filter_va.cpp.o -c /home/MediaSDK_R6/MediaSamples_Linux_6.0.16043175.175/samples/sample_plugins/rotate_opencl/src/opencl_filter_va.cpp
In file included from /home/MediaSDK_R6/MediaSamples_Linux_6.0.16043175.175/samples/sample_plugins/rotate_opencl/src/opencl_filter_va.cpp:13:0:
/home/MediaSDK_R6/MediaSamples_Linux_6.0.16043175.175/samples/sample_plugins/rotate_opencl/include/opencl_filter_va.h:25:23: fatal error: CL/va_ext.h: No such file or directory
 #include <CL/va_ext.h>
compilation terminated.
gmake[2]: *** [sample_plugins/rotate_opencl/CMakeFiles/sample_plugin_opencl.dir/src/opencl_filter_va.cpp.o] Error 1
gmake[2]: Leaving directory `/home/MediaSDK_R6/MediaSamples_Linux_6.0.16043175.175/samples/__cmake/intel64.make.debug'
gmake[1]: *** [sample_plugins/rotate_opencl/CMakeFiles/sample_plugin_opencl.dir/all] Error 2
gmake[1]: Leaving directory `/home/MediaSDK_R6/MediaSamples_Linux_6.0.16043175.175/samples/__cmake/intel64.make.debug'
gmake: *** [all] Error 2
[ intel64.make.debug                                 State: FAIL ]
However, I had installed OpenCL successfully:
[samples]# find / -name libOpenCL.so*
/opt/intel/opencl/libOpenCL.so.1
/opt/intel/opencl/libOpenCL.so.1.2
[samples]#
[ samples]# find / -name va_ext.h
/opt/intel/mediasdk/MediaSamples_Linux_5.0.1604371.71/samples/opencl_motionestimation/common/CL/va_ext.h
/opt/intel/mediasdk/MediaSamples_Linux_5.0.1604371.71/samples/opencl_motionestimation/MotionEstimation/CL/va_ext.h
/opt/intel/opencl/include/CL/va_ext.h
[ samples]#
Have I done something wrong? Can anyone help me? Thanks~
Platform:
      8  Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
00:02.0 VGA compatible controller [0300]: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics Controller
[8086:0412] (rev 06)
Surbhi_M_Intel
Hi there,
Can you tell us which OS you are working on? Can you please confirm if you went through software requirements from the samples guide which advice to install gcc compiler and also the build instructions from the sample guide?
Surbhi
然_魏_
Surbhi M. (Intel) wrote:
Hi there,
Surbhi
Hi~
My OS is CentOS 7.1, and I have built instructions from the sample guide. (\MediaSamples_Linux_6.0.16043175.175\Media_Samples_Guide.pdf)
Besides, we bought 4 Intel's server with the same configuration. I installed and run this sample successfully on one of them, and this error:
"/home/MediaSDK_R6/MediaSamples_Linux_6.0.16043175.175/samples/sample_plugins/rotate_opencl/include/opencl_filter_va.h:25:23: fatal error: CL/va_ext.h: No such file or directory
should not be occured.
althouth I have just solved this error by add include path on $PATH.
And it is, this error "solved", but when I run sample_decode_drm, another error occured:
_________________________________________________________________________
# pwd
/home/MediaSDK_R6/MediaSamples_Linux_6.0.16043175.175/samples/__cmake/intel64.make.debug/__bin/debug
[root@storm109 debug]# ./sample_decode_drm h264 -i bbb720pMov.264 -o bbbIntelSampDeco.yuv
libva info: VA-API version 0.35.0
libva info: va_getDriverName() returns 0
libva info: User requested driver 'iHD'
libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so
libva info: Found init function __vaDriverInit_0_32
libva info: va_openDriver() returns 0
Decoding Sample Version 0.0.000.0000
Input video     AVC
Output format   YUV420
Resolution      1280x720
Crop X,Y,W,H    0,0,0,0
Frame rate      0.00
Memory type             system
MediaSDK impl           hw
MediaSDK version        1.16
Decoding started
Frame number:    0, fps: 0.000, fread_fps: 0.000, fwrite_fps: 0.000
Return on error: error code -1, /home/MediaSDK_R6/MediaSamples_Linux_6.0.16043175.175/samples/sample_decode/src/pipeline_decode.cpp 1340
Return on error: error code 1,  /home/MediaSDK_R6/MediaSamples_Linux_6.0.16043175.175/samples/sample_decode/src/sample_decode.cpp   531
It's so weird...
Jiandong_Z_Intel
Hi, Have you upgraded your KMD ? You can use following command line check your KMD $ uname -r $ ls -l /dev/dri ## You should find renderD128 if KMD is OK. You can refer Page 3 Getting Started Guide - Linux* Installation to upgrade KMD. https://software.intel.com/sites/default/files/media_server_studio_getting_started_guide.pdf Thanks Zachary
然_魏_
$ uname -r
You can refer Page 3 Getting Started Guide - Linux* Installation to upgrade KMD. https://software.intel.com/sites/default/files/media_server_studio_getti...
Zachary
I have solved this problem by
#rpm --force -Uvh /MSS/rpmbuild/RPMS/x86_64/*.rpm
although I don't know why ...
 even more puzzling is:
both
.../MediaSamples_Linux_6.0.16043175.175/samples/_bin/x64/sample_decode_drm
and
.../MediaSamples_Linux_6.0.16043175.175/samples/__cmake/intel64.make.debug/__bin/debug/sample_decode_drm
get the same results(same fps...), it's seemed that MediaSamples_Linux_6.0 generate useless, why is this happening?
Surbhi_M_Intel
Glad, you got that part working!
Not sure why would you expect same sample to generate different results, but sample_decode_drm in the above pointed location is being generated from same sample. Can you please explain your expectation?
-Surbhi
然_魏_
-Surbhi
(Well, I'm hammering at OpenCL study recently...)
Since get the same result, so why we should build samples following  …\MediaSamples_Linux_6.0.16043175.175\Media_Samples_Guide.pdf? Why don’t we use the …\MediaSamples_Linux_6.0.16043175.175\samples\_bin\x64\*drm directly?
