2999 Discussions
MediaServerStudioEssentials2017编码使用HW模式问题
志才_吴_
系统是cenos7.2
MediaServerStudioEssentials2017编码使用HW模式会导致v4L2采集卡死,SW模式没问题。有人遇到同样问题的吗?
还有sample里面的v4L2怎么打开,我执行perl build.pl --cmake=intel64.make.debug --build --clean命令,编译出来的sample_encoder是没有打开v4L2采集的。手动在intel64.make.debug/sample_encode/CMakeFiles/sample_encode.dir/build.make文件增加-DENABLE_V4L2_SUPPORT,报很多v4L2的api函数找不到
Anna_B_Intel
Could you please translate your question into English?
Best wishes,
Anna
志才_吴_
Hardware: CPU: I5-6500) motherboard: asus Z170 Pro
System: centos7.2 msdk2017
Using the environment:
4 road start using v4l2 collecting 1920 x2160 high-resolution video, encode  or VPP open HW mode, acquisition will be stuck;use SW mode, collection is ok.
Msdk2015 on I5-4590 is ok
