Metrics Monitor in 2015R3 Does Not Run
John_H_7
I've installed the Media Server Professional 2015R3 on a CentOS 7 system. The install went well, and encode and decode samples are working fine.
Not so lucky with the Metrics Monitor.  When I either run the provided binary our build and run the sample, it immediately fails when CTTMetrics_Init(0 is called with:
ERROR: Failed to initialize metrics monitor, error code -10
Doc is no help; it list no error return possibilities.
Any suggestions on getting it going?
John
Sravanthi_K_Intel
Hi John,
Can you provide more details on the system you are using?
Just to clarify, you ran the ./build.sh script from the metrcis_monitor/sample folder, and then ran ./run.sh?
John_H_7
Thanks for the reply.
The system is a Supero X10SLH-F.  It has 8 cores -  Intel(R) Xeon(R) CPU E3-1285 v3 @ 3.60GHz. It has 12GB of memory.
And yes, it builds fine with the script, but does not run when the script is executed.
Decode and encode samples run fine.
John
John_H_7
I'm still interested in getting the Metrics Monitor going.
Suggestions, please?
-John
Sravanthi_K_Intel
Hi John - Apologies for the delayed response. The metrics_monitor tool needs to be run as root (not sudo, but as root). Can you please ensure you are doing that, and get back to us? Thanks.
John_H_7
Nothing quite so obvious as running non-root:
[root@sut-1300 metrics_monitor]# ls -l
total 24
-rwxr-xr-x 1 root root   95 Dec 13 02:41 build.sh
-rwxr-xr-x 1 root root 2947 Feb  2 13:14 cttmetrics_sample.cpp
-rwxr-xr-x 1 root root 9122 Feb  2 13:15 metrics_monitor
-rwxr-xr-x 1 root root   72 Dec 13 02:41 run.sh
[root@sut-1300 metrics_monitor]# file metrics_monitor
metrics_monitor: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.32, BuildID[sha1]=0xf2730210de6ae8dcc6b74b6700a56210afaaf352, not stripped
[root@sut-1300 metrics_monitor]# whoami
root
[root@sut-1300 metrics_monitor]# cat run.sh
export LD_LIBRARY_PATH=$PWD/../_bin:$LD_LIBRARY_PATH
./metrics_monitor
[root@sut-1300 metrics_monitor]# ./run.sh
Sravanthi_K_Intel
The error you are observing corresponds to -     CTT_ERR_DRIVER_NO_INSTRUMENTATION   = -10, /* i915 driver has no instrumentation */
(This is available in the <msdk install>/tools/metrics_monitor/include/cttmetrics.h )
This could be an issue with the stack or kernel or metrics_monitor issue itself. To understand more, could you please provide the following information? I could take a look at it and also escalate it. Provide the output of:
- uname -ar
- lmsod | grep i915
- what is the MSS version i use (the latest one on the web is the R4 version, hope you re using that).
John_H_7
Ok, here you are:
[root@sut-1300 Intel-Samples]# uname -ar
Linux sut-1300 3.10.0-123.9.3.29573.MSSr3.el7.x86_64 #1 SMP Thu Jan 29 18:15:47 EST 2015 x86_64 x86_64 x86_64 GNU/Linux
[root@sut-1300 Intel-Samples]# lsmod | grep i915
i915                  734314  3
drm_kms_helper         52758  2 ast,i915
drm                   297577  6 ast,ttm,i915,drm_kms_helper
i2c_algo_bit           13413  3 ast,igb,i915
i2c_core               40325  7 ast,drm,igb,i915,i2c_i801,drm_kms_helper,i2c_algo_bit
video                  19267  1 i915
MSS version is from this last January -  MediaServerStudioProfessionalEvaluation2015R3 Perhaps there's a new release out now? Would that help?
John
Sravanthi_K_Intel
Thanks for the information. Will get back to you soon.
MSS version is from this last January -  MediaServerStudioProfessionalEvaluation2015R3 Perhaps there's a new release out now? Would that help? --> Yes, please update to the latest version available now (which is R4)
Sravanthi_K_Intel
Hi John - Can you verify the KMD driver installation? The metrics monitor requires instrumented KMD driver from the Media Server Studio package, and please make sure that driver is installed correctly (we package 2 install scripts and getting started guide, which goes over install instructions including KMD driver install).
Sravanthi_K_Intel
Smoke test to check if KMD driver w/instrumentation was installed from MSS correctly - if this file does not exist, then KMD from MSS needs to be installed again “/sys/kernel/debug/dri/0/i915_ringstats"
If this file above exists and you still get the error, please let us know. Thanks.
John_H_7
No, it's not there.
I'm going to upgrade to 2015R4 anyway, so let's see what happens then.  I presume this file should still be there when 2015R4 is installed?
Sravanthi_K_Intel
John - Yes, please update to R4 and you should find the instrumentation file in it. (Although there is no reason why it should not already be part of R3 - it is included. My guess being KMD driver from MSS was probably not installed correctly).
gabriel_p_2
Any news ? I am running Iris Pro 580 everithing is OK, except metrics monitor
[root@localhost sample]# ./run.sh
ERROR: Failed to subscribe for metrics, error code 1
Stan_S_
I have exactly the same problem and it is very embaransing not to have metrics on the Iris!
Would be very helpfull if somebody from Intel responds to this!
Mark_L_Intel1
Hi gabriel and Stan,
There is the other thread is talking about this issue too, someone in Ubuntu changed the complier version go g++4.9 and fixed it temporarily before the reboot. This is like a software issue.
https://software.intel.com/en-us/forums/intel-media-sdk/topic/733549
Mark
rasko_N_
We have same problem, so i pass this problem and now using intel_gpu_top from intel-gpu-tolols package, it works!
Rashad
Mark_L_Intel1
Hi rasko,
Sorry for the late response, the update and workaround are posted at:
Please try it and let me know if it doesn't work
Mark
