Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
Missing .so files
MasDennis
When building and running the latest code from GitHub I get this message:
"Could not load library: ippresample"
This happens when I run the samples app and try to launch Video Processing > Audio Effect.
When I look at the Android build instructions (which seem to be outdated) the native libs are mentioned:
7. Since the sample application depends on native libraries from <install-folder>\libs folder, you should copy <install-folder>\libs\armeabi and <install-folder>\libs\x86 subfolders to <install-folder>\samples\apps\libs folder, here is a screenshot with required folders structure:
But they are nowhere to be found in the GitHub repositories nor can I find them anywhere else.
Am I missing something? Any help would be appreciated.
Thanks!
Jeffrey_M_Intel1
Media for Mobile is out of the scope of this forum.  Please report the issue to the Media for Mobile github community.
