Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
Mixing video and audio tracks
Lev_S_
Can I use media-for-mobile for mixing video and audio tracks like this?
I saw Audio Effect Processing from INDE Android examples but it seems to be impossible to add offset before audio. Any solution?
Lev
Harshdeep_B_Intel
Hi Lev,
Above use case is/should be possible, by extending the audio effect. Unfortunately, we do not a sample, showcasing exact use case. But, you use samples on gitbub (https://github.com/INDExOS/media-for-mobile) to start of and modify them for your scenario. Since you have access to every single audio sample, you can change the data from any track (1,2,3,4 etc).
