Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
2965 Discussions
NAL head after use Encoder indicaate: Access unit delimiter
zheng_s_
I use the same code to design a transcode app  which inlcude  Decode/VAPP/ Encode functions.
then I try to test the h264 video generated from Intel encoder and it is not playable by VLC.  I dump the header of each frame and  found follwoing interesting:
The orignal  H264 frame:
000141ffffff9affffffc05ffffff80ffffff8bffffffc165ffffff8d1ffffff8cffffff9c6069ffffff94ffffff82ffffff97ffffff84ffffffad7d1ffffff99ffffffe5ffffffe0ffffffdfffffffee606b586027fffffff1ffffffd661ffffffc4722bffffffd4604c7cb2544ffffffcc157932ffffffbfffffff86ffffffe91ffffffdfffffffa0fffffffbffffffd571ffffffe6574fffffffff133afffffff919ffffff964861ffffffe4ffffff96ffffffb165ffffffc95d3272ffffffcbb75ffffffcdffffff95ffffff95ffffffa7ffffffeaffffffd5ffffffc4ffffffcbffffff946781d8fffffffcffffffc03fffffffbffffffdcffffffd1ffffffdf256effffffc66e486e2f27ffffff98ffffffe05e385ffffffe12b2673ffffffbb2ffffff9a756ffffffffe58ffffffd0ffffffc3fffffff4ffffffbc23744dffffffc6ffffff9cffffffa81ddffffff9948ffffffe8ffffffd57246ffffff84cffffffe9ffffff9873ffffffe2ffffffa35fffffff51effffffcf6466fffffff8ffffffcb1c7effff
And here is the output from Intel Encoder:
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
I didn’t copy the full buffer, since it is huge. The first 4 bytes is 0001 which is h264 NAL start prefix code, then followed by 0x09, indicate access unit delimiter. But I don’t know why the header/NAL type could be different after encoder. Anyone get experience in h264  format? And how to make the output from encode is playable
Anthony_P_Intel
Is your source video an "elementary" stream (without audio, etc.)?
Do you reproduce the issue by using  sample_multi_transcode.exe application?  If so, can you provide the parameters you are using?
