Need Help with Interlaced Encoding
Arpan_P_
How-To perform Interlaced Encoding using Intel Media SDK.
Hi Everyone,
    I would like to know how to perform interlaced (MFX_PICSTRUCT_FIELD_TFF) (field by field) encoding from NV12 input to H264 (Main). I have a working source code which performs Progressive (MFX_PICSTRUCT_PROGRESSIVE) encoding for the same. Now if I change the params.mfx.FrameInfo.PicStruct to MFX_PICSTRUCT_FIELD_TFF, I have to provide full resolution (width * height) frame to the encoder then only it will do the encoding. What I need is to give Top Field first frame (odd lines first) (width * (height/2)) and then followed by Bottom Field frame (width * (height/2)) to the encoder in 2 successive calls and the encoder should give me full resolution encoded frame synchronous or asynchronous. Unable to find a solution for few days now, kindly help with some source code or refer to some solution.
Details about my setup:
CPU & Processor: Intel Core i3-5005U CPU @2GHz 2 Cores 4 Logical Processors
OS & Version: Windows 10 Pro (10.0.14393) - x64 bit
Intel HD Graphics 5500 Driver Version: 20.19.15.4549
Intel Media SDK Version: Major 1 Minor 20
Thanks in Advance,
Arpan
