hi, all,
I am test vpp composite filter mfxExtVPPComposite in intel MSDK. I have 2 input streams, both are 1920x1080. The render target is 1920x1088. I want to scale down these two inputs stream and put it into rende rtarget with background color. 1st stream downscale from 1920x1080 to DstXYWH (0, 0, 1920, 640), 2nd downscale from 920x1080 to DstXYWH (64,64, 640, 480). I setup related MFX_EXTBUFF_VPP_COMPOSITE and mfxExtVPPComposite struct. The result I got not as my expected, I only got an output which from 1st stream with resolution 1920x1088. I didn't see the background color and the second steams in output frame. Does anyone tell me where I am wrong?
The code is based on msdk sample "mediasdk-tutorials-0.0.3\simple_4_vpp_resize_denoise" and my logic is in simple_vpp.cpp . Cmd option I used to run this sample is "-hw -g 1920x1080 in.nv12 out.nv12".
Thanks a lot.
Blues
Does anyone have idea about this? Thanks for your help.
Hello there, thanks for your question. I am trying to reproduce your issue and will keep you posted. In the meantime, can you send what is the status returned by the following piece of code in simple_vpp.cpp?
// Initialize Media SDK VPP
sts = mfxVPP.Init(&VPPParams);
Can you also please provide details on your system (from running mediasdk_system_analyzer_<arch>.exe from tools/ in mediasdk install folder)?
Hello, SRAVANTHI K:
The return values of
is MFX_WRN_FILTER_SKIPPED;
Here is the info from my system, hope it can help you to reproduce the issue:
C:\Program Files\Intel\Media SDK 2014 R2 for Clients\tools\mediasdk_sys_analyzer>mediasdk_system_alyzer_64.exe
Intel Media SDK System Analyzer (64 bit)
The following versions of Media SDK API are supported by platform/driver:
Version Target Supported Dec Enc
1.0 HW Yes X X
1.0 SW Yes X X
1.1 HW Yes X X
1.1 SW Yes X X
1.3 HW Yes X X
1.3 SW Yes X X
1.4 HW Yes X X
1.4 SW Yes X X
1.5 HW Yes X X
1.5 SW Yes X X
1.6 HW Yes X X
1.6 SW Yes X X
1.7 HW Yes X X
1.7 SW Yes X X
1.8 HW Yes X X
1.8 SW Yes X X
Graphics Devices:
Name Version State
Intel(R) HD Graphics Family 10.18.10.3652 Active
NVIDIA GeForce GT 720M 9.18.13.3165 Active
System info:
CPU: Intel(R) Core(TM) i5-4200U CPU @ 1.60GHz
OS: Microsoft Windows 8 Pro
Arch: 64-bit
Installed Media SDK packages (be patient...processing takes some time):
Intel?Media SDK Video Processing Sample 5.0.461.91752
Intel Media SDK DirectShow* Sample 5.0.337.78585
Intel?Media SDK Video Encoding Sample 5.0.461.91752
Intel?Media SDK Video Decoding Sample 5.0.461.91752
Intel?Media SDK Video Transcoding Sample 5.0.461.91752
Intel?Media SDK Video Conferencing Sample 5.0.461.91752
Intel?Media SDK 2014 R2 for Clients (x64)
Installed Media SDK DirectShow filters:
Installed Intel Media Foundation Transforms:
Intel?Hardware M-JPEG Decoder MFT : {00C69F81-0524-48C0-A353-4DD9D54F9A6E}
Intel?Hardware VP8 Sync Decoder MFT : {451E3CB7-2622-4BA5-8E1D-44B3C41D0924}
Intel?Hardware VP8 Decoder MFT : {6D856398-834E-4A89-8EE5-071BB3F58BE4}
Intel?Quick Sync Video H.264 Encoder MFT : {4BE8D3C0-0515-4A37-AD55-E4BAE19AF471}
Hello there, thanks for your quick response. According to your analyzer report, the host machine has Windows OS on it. Currently, composition is supported only in Linux version of Media SDK and you can refer to sample_vpp as an example for the correct usage. I understand this may be an inconvenience for you - I will keep you posted on any developments.
Thank SRAVANTHIK for the clarification. By the way, do Intel MSDK have a plan to support VPP composition filter on the version for Windows ?
Hello there, yes, we do have plans to support the VPP Composition on Windows, and will update when it is. Stay tuned.
