Community
cancel
Showing results for
Search instead for
Did you mean:
song_l_
Output Size of H264 encode is strange
I used one image data to compress into  a AVC video.the output buffer size is strange.
GopPicSize =1;  AsyncDepth=1;
for (int i = 0; i < 100; ++i){
    DWORD dt = GetTickCount();
    memset(&bitStream, 0, sizeof(mfxBitstream));
    bitStream.MaxLength = bufferSize;
    bitStream.Data = buffer;
    for (;;)
        status = MFXVideoENCODE_EncodeFrameAsync(session, NULL, &surface, &bitStream, &syncp);
        //....some common routing....
    MFXVideoCORE_SyncOperation(session, syncp, INFINITE);
    printf("%ld, %ld\r\n", bitStream.DataLength, GetTickCount() - dt);
 The output is:
49747, 15
43905, 16
38935, 0
35141, 0
29245, 0
25950, 16
23541, 0
18919, 0
16195, 0
16195, 16
16195, 0
16195, 0
16195, 0
16195, 0
16195, 16
16195, 0
16195, 0
16195, 0
16195, 0
16195, 0
16195, 0
16195, 16
16195, 0
16195, 0
16195, 0
 The problem is :
1)The output DataLength should be the same when GopPicSize =1(I Frame only).
Maybe the first frame will be a little bigger because of some header information.
2) The encode time is not the same. if there is a cache, It should be 16, 0,0,0,0......
Is there anyone who can explain the output data?
Jeffrey_M_Intel1
Many things could affect frame size -- especially the input stream.  To understand expected behavior you can start with the tutorials.  The simple_3_encode tutorial is designed to be simple so you can quickly add your own modifications to GOP parameters, BRC, etc.  I suspect you will see different behavior (perhaps more like you expect?) if you switch to CQP instead of CBR/VBR.
For encode time, since the implementation is asynchronous the time/latency to encode is not expected to be constant.  The low latency tutorials can be used as a starting point/reference for tracking encode time by frame.
Regards, Jeff
song_l_
TO:Jeffrey Mcallister (Intel)
    Thanks for you answer。
