I used one image data to compress into a AVC video.the output buffer size is strange.
GopPicSize =1; AsyncDepth=1;
for (int i = 0; i < 100; ++i){
DWORD dt = GetTickCount();
memset(&bitStream, 0, sizeof(mfxBitstream));
bitStream.MaxLength = bufferSize;
bitStream.Data = buffer;
for (;;)
status = MFXVideoENCODE_EncodeFrameAsync(session, NULL, &surface, &bitStream, &syncp);
//....some common routing....
MFXVideoCORE_SyncOperation(session, syncp, INFINITE);
printf("%ld, %ld\r\n", bitStream.DataLength, GetTickCount() - dt);
The output is:
49747, 15
43905, 16
38935, 0
35141, 0
29245, 0
25950, 16
23541, 0
18919, 0
16195, 0
16195, 16
16195, 0
16195, 0
16195, 0
16195, 0
16195, 16
16195, 0
16195, 0
16195, 0
16195, 0
16195, 0
16195, 0
16195, 16
16195, 0
16195, 0
16195, 0
The problem is :
1)The output DataLength should be the same when GopPicSize =1(I Frame only).
Maybe the first frame will be a little bigger because of some header information.
2) The encode time is not the same. if there is a cache, It should be 16, 0,0,0,0......
Is there anyone who can explain the output data?
Many things could affect frame size -- especially the input stream. To understand expected behavior you can start with the tutorials. The simple_3_encode tutorial is designed to be simple so you can quickly add your own modifications to GOP parameters, BRC, etc. I suspect you will see different behavior (perhaps more like you expect?) if you switch to CQP instead of CBR/VBR.
For encode time, since the implementation is asynchronous the time/latency to encode is not expected to be constant. The low latency tutorials can be used as a starting point/reference for tracking encode time by frame.
Regards, Jeff
TO:Jeffrey Mcallister (Intel)
Thanks for you answer。
