Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
3058 Discussions
Performance degradation after update from 2017R3 to 2018R1
VASILY_V_
We've encounter performance degradation after update from 2017R3 to 2018R1 Intel Media SDK community edition for Linux on Intel(R) Xeon(R) CPU E3-1585L v5 @ 3.00GHz
After update the overall performance decreases up to 25% and now our server can handle less streams then before update (we use only AVC as codec)
What we can see as difference, that on 2017R3 metrics_monitor shows us VIDEO2 module and load on it:
RENDER usage: 90.00,	VIDEO usage: 36.00,	VIDEO_E usage: 68.00	VIDEO2 usage: 45.00	GT Freq: 1100.00
RENDER usage: 79.00,	VIDEO usage: 21.00,	VIDEO_E usage: 53.00	VIDEO2 usage: 45.00	GT Freq: 1100.00
RENDER usage: 82.00,	VIDEO usage: 32.00,	VIDEO_E usage: 58.00	VIDEO2 usage: 43.00	GT Freq: 1100.00
RENDER usage: 92.00,	VIDEO usage: 26.00,	VIDEO_E usage: 72.00	VIDEO2 usage: 48.00	GT Freq: 1100.00
RENDER usage: 83.00,	VIDEO usage: 21.00,	VIDEO_E usage: 63.00	VIDEO2 usage: 49.00	GT Freq: 1100.00
RENDER usage: 79.00,	VIDEO usage: 24.00,	VIDEO_E usage: 61.00	VIDEO2 usage: 38.00	GT Freq: 1100.00
but after update, on 2018R1 we can't see VIDEO2 and RENDER module always 100% load:
RENDER usage: 100.00,	VIDEO usage: 49.00,	VIDEO_E usage: 73.00	GT Freq: 1100.00
RENDER usage: 100.00,	VIDEO usage: 41.00,	VIDEO_E usage: 70.00	GT Freq: 1100.00
RENDER usage: 100.00,	VIDEO usage: 47.00,	VIDEO_E usage: 73.00	GT Freq: 1100.00
RENDER usage: 100.00,	VIDEO usage: 47.00,	VIDEO_E usage: 71.00	GT Freq: 1100.00
RENDER usage: 100.00,	VIDEO usage: 45.00,	VIDEO_E usage: 75.00	GT Freq: 1100.00
RENDER usage: 99.00,	VIDEO usage: 42.00,	VIDEO_E usage: 74.00	GT Freq: 1050.00
RENDER usage: 100.00,	VIDEO usage: 38.00,	VIDEO_E usage: 71.00	GT Freq: 1050.00
Also you may notice that GT Freq has small fluctuations that we also don't observe on 2017R3
Dmesg initialization log seems the same for both SDK versions:
[Mon Dec 24 12:49:26 2018] [drm] Initialized drm 1.1.0 20060810
[Mon Dec 24 12:49:26 2018] [drm] Found 128MB of eLLC
[Mon Dec 24 12:49:26 2018] [drm] Memory usable by graphics device = 4096M
[Mon Dec 24 12:49:26 2018] [drm] Replacing VGA console driver
[Mon Dec 24 12:49:26 2018] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[Mon Dec 24 12:49:26 2018] [drm] Driver supports precise vblank timestamp query.
[Mon Dec 24 12:49:27 2018] [drm] failed to retrieve link info, disabling eDP
[Mon Dec 24 12:49:27 2018] [drm] RC6 disabled, disabling runtime PM support
[Mon Dec 24 12:49:27 2018] [drm] Initialized i915 1.6.0 20151010 for 0000:00:02.0 on minor 0
[Mon Dec 24 12:49:27 2018] [drm] Cannot find any crtc or sizes - going 1024x768
[Mon Dec 24 12:49:27 2018] i915 0000:00:02.0: fb1: inteldrmfb frame buffer device
[Mon Dec 24 12:49:28 2018] [drm] RC6 off
[Mon Dec 24 12:49:28 2018] [drm] The Ring/GT multiplier is 2
What can we do? How to debug this problem? Why that can be?
Dmitry_E_Intel
Hi Vasily,
Please say which OS and Linux kernel you use. Please provide  output from "uname -a", "modinfo i915", "cat /proc/cmdline".
Have you tried MSS 2018 R2?  If not, please do.
Can you please try to reproduce the issue on open source media stack: https://github.com/Intel-Media-SDK/MediaSDK/releases/tag/intel-mediasdk-18.3.0 with one of the latest 4.19 kernel?
Dmitry
VASILY_V_
I've attached listings for system with and without problem. cat /proc/cmdline it both cases just 'auto'
No, I haven't tried MSS 2018 R2, It's not such simple to migrate my system for this SDK. Also I haven't tried opensource version of SDK.
But it's definitely should be OK on 2018R1, don't it?
Or it's known problem with performance regression?
Dmitry_E_Intel
There is no such regression observed on our side.
I guess somehow the 2nd VDBOX has been disabled within kernel update.
What you your particular usage case ? Single or multiple AVC encode? Or transcode to AVC?  If multiple, what is the number of channels?
Please provide us a reproducer via sample_encode or sample_multi_transcode which would be similar to the pipeline used in your application. Besides, I'd like to see performance results using perf command, like:
perf stat -a -e i915/bcs0-busy/,i915/rcs0-busy/,i915/vcs0-busy/,i915/vcs1-busy/,i915/vecs0-busy/ ./sample_multi_transcode <command line options>
for both 2017 R3 and 2018 R1.
Please also send output from "ls -l /sys/kernel/debug/dri/ && cat /sys/kernel/debug/dri/*/i915_ringstats"
