3001 Discussions
Play VP8 format file with Intel Hardware VP8 Sync Decoder MFT causes memory leak
Raven_T_
I'm doing some video decoder survey with Media Foundation.
I create MFTopology myself and set the transform node with Intel Hardware VP8 Sync Decoder MFT as the following:
CComPtr<IMFTopologyNode>pNode = NULL;
// Create the node.
HRESULT hr = MFCreateTopologyNode(MF_TOPOLOGY_TRANSFORM_NODE, &pNode);
// Set the CLSID attribute.
if (SUCCEEDED(hr))
    hr = pNode->SetGUID(MF_TOPONODE_TRANSFORM_OBJECTID, clsid);
where the clsid was one of the Intel VP8 decoder's GUID found from MFTEnum function.
When I shutdown the player and release the topology and create a new one with this decoder CLSID again, the system memory almost doubled.
For example, the memory usage is about 130MB when first topology is created, when I destroy the topology and create a new one, the system memory usage goes to ~230MB.
System Information
      Time of this report: 10/26/2017, 18:11:59
             Machine name: DESKTOP-VCSA53L
               Machine Id: {2F239B72-F683-4F3A-9F1E-31327D5B6A89}
         Operating System: Windows 10 家庭版 32-bit (10.0, Build 14393) (14393.rs1_release.161220-1747)
                 Language: Chinese (Traditional) (Regional Setting: Chinese (Traditional))
      System Manufacturer: ECS
             System Model: Palm stick
                     BIOS: PS02F-08
                Processor: Intel(R) Atom(TM) x5-Z8350  CPU @ 1.44GHz (4 CPUs), ~1.4GHz
                   Memory: 2048MB RAM
      Available OS Memory: 1956MB RAM
                Page File: 1412MB used, 1247MB available
              Windows Dir: C:\Windows
          DirectX Version: DirectX 12
      DX Setup Parameters: Not found
         User DPI Setting: Using System DPI
       System DPI Setting: 96 DPI (100 percent)
          DWM DPI Scaling: Disabled
                 Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
           DxDiag Version: 10.00.14393.0000 32bit Unicode
DxDiag Notes
      Display Tab 1: No problems found.
        Sound Tab 1: No problems found.
          Input Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (retail)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
          Card name: Intel(R) HD Graphics
       Manufacturer: Intel Corporation
          Chip type: Intel(R) HD Graphics
           DAC type: Internal
        Device Type: Full Device
         Device Key: Enum\PCI\VEN_8086&DEV_22B0&SUBSYS_72708086&REV_36
      Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Device Problem Code: No Problem
Driver Problem Code: Unknown
     Display Memory: 1092 MB
   Dedicated Memory: 114 MB
      Shared Memory: 978 MB
       Current Mode: 1920 x 1080 (32 bit) (59Hz)
       Monitor Name: Generic PnP Monitor
      Monitor Model: Acer T231H
         Monitor Id: ACR0184
        Native Mode: 1920 x 1080(p) (60.000Hz)
        Output Type: HDMI
        Driver Name: igdumdim32.dll,igd10iumd32.dll,igd10iumd32.dll,igd12umd32.dll
Driver File Version: 20.19.0015.4424 (English)
     Driver Version: 20.19.15.4424
        DDI Version: 12
     Feature Levels: 11_1,11_0,10_1,10_0,9_3,9_2,9_1
       Driver Model: WDDM 2.0
Graphics Preemption: Triangle
 Compute Preemption: Thread group
           Miracast: Supported
Hybrid Graphics GPU: Integrated
     Power P-states: Not Supported
  Driver Attributes: Final Retail
   Driver Date/Size: 2016/3/31 上午 08:00:00, 38207848 bytes
        WHQL Logo'd: Yes
    WHQL Date Stamp: Unknown
  Device Identifier: {D7B78E66-61F0-11CF-7EF2-7F528AC2D935}
          Vendor ID: 0x8086
          Device ID: 0x22B0
          SubSys ID: 0x72708086
        Revision ID: 0x0036
 Driver Strong Name: oem5.inf:5f63e5342b627028:iCHVM_w10:20.19.15.4424:pci\ven_8086&dev_22b0
     Rank Of Driver: 00D12001
        Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
        DXVA2 Modes: DXVA2_ModeMPEG2_VLD  DXVA2_ModeMPEG2_IDCT  DXVA2_ModeVC1_D2010  DXVA2_ModeWMV9_IDCT  DXVA2_ModeVC1_IDCT  DXVA2_ModeH264_VLD_NoFGT  DXVA2_ModeHEVC_VLD_Main
   Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
       D3D9 Overlay: Supported
            DXVA-HD: Supported
       DDraw Status: Enabled
         D3D Status: Enabled
         AGP Status: Enabled
           MPO Caps: RGB,YUV,HIGH_FILTER
        MPO Stretch: 1.000X - 1.000X
    MPO Media Hints:
        MPO Formats: YUY2,R16G16B16A16_FLOAT,R10G10B10A2_UNORM,R8G8B8A8_UNORM,B8G8R8A8_UNORM
Sound Devices
            Description: Acer T231H (Intel SST Audio Device (WDM))
 Default Sound Playback: Yes
 Default Voice Playback: Yes
            Hardware ID: ACPI\VEN_8086&DEV_22A8
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            Driver Name: isstrtc.sys
         Driver Version: 604.10135.2747.11324 (English)
            WHQL Logo'd: Yes
          Date and Size: 2016/1/12 上午 12:00:00, 634872 bytes
            Other Files:
        Driver Provider: Intel
         HW Accel Level: Basic
              Cap Flags: 0xF1F
    Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
 Static/Strm HW 3D Bufs: 0, 0
              HW Memory: 0
       Voice Management: No
 EAX(tm) 2.0 Listen/Src: No, No
   I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
Video Capture Devices
Number of Devices: 1
           FriendlyName: Kingcome 2M Camera
           SymbolicLink: \\?\usb#vid_2b7e&pid_211f&mi_00#6&2fe040ef&0&0000#{e5323777-f976-4f5b-9b55-b94699c46e44}\global
           Manufacturer: Microsoft
             HardwareID: USB\VID_2B7E&PID_211F&REV_0102&MI_00,USB\VID_2B7E&PID_211F&MI_00
             DriverDesc: USB ????
         DriverProvider: Microsoft
          DriverVersion: 10.0.14393.82
      DriverDateEnglish: 6/21/2006 00:00:00
    DriverDateLocalized: 2006/6/21 上午 12:00:00
                Service: usbvideo
                  Class: Image
          DevNodeStatus: 180200A[DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
            ContainerId: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}
            ProblemCode: No Problem
  BusReportedDeviceDesc: Kingcome 2M Camera
                 Parent: USB\VID_2B7E&PID_211F\20151117
      DriverProblemDesc: n/a
           UpperFilters: n/a
           LowerFilters: n/a
                  Stack: \Driver\usbvideo,\Driver\usbccgp
      ContainerCategory: Imaging
DirectInput Devices
      Device Name: 鼠?
         Attached: 1
    Controller ID: n/a
Vendor/Product ID: n/a
        FF Driver: n/a
      Device Name: ??
         Attached: 1
    Controller ID: n/a
        FF Driver: n/a
      Device Name: USB Keyboard
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x04F2, 0x0402
        FF Driver: n/a
      Device Name: USB Mouse
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x09DA, 0xC10A
        FF Driver: n/a
      Device Name: 已??便?式??控制?置
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x045E, 0x0000
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
      Device Name: HID Button over Interrupt Driver
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB 根集?器(xHCI)
| Vendor/Product ID: 0x8086, 0x22B5
| Matching Device ID: USB\ROOT_HUB30
| Service: USBHUB3
| Driver: USBHUB3.SYS, 7/16/2016 16:24:57, 430944 bytes
+-+ 通用 USB 集?器
| | Vendor/Product ID: 0x1A40, 0x0101
| | Matching Device ID: USB\USB20_HUB
| | Service: USBHUB3
| +-+ USB ?入??
| | | Matching Device ID: USB\Class_03&SubClass_01
| | | Service: HidUsb
| | | Driver: hidusb.sys, 3/1/2017 13:51:55, 26624 bytes
| | | Driver: hidclass.sys, 3/1/2017 13:51:55, 116224 bytes
| | | Driver: hidparse.sys, 3/1/2017 13:51:55, 31744 bytes
| | +-+ HID-compliant mouse
| | | | Matching Device ID: HID_DEVICE_SYSTEM_MOUSE
| | | | Service: mouhid
| | | | Driver: mouhid.sys, 7/16/2016 16:24:57, 23040 bytes
| | | | Driver: mouclass.sys, 7/16/2016 16:24:57, 44896 bytes
| +-+ USB Composite Device
| | | Matching Device ID: USB\COMPOSITE
| | | Service: usbccgp
| | | Driver: usbccgp.sys, 7/16/2016 16:24:57, 126816 bytes
| | +-+ USB ?入??
| | | | Service: HidUsb
| | | +-+ HID Keyboard Device
| | | | | Matching Device ID: HID_DEVICE_SYSTEM_KEYBOARD
| | | | | Service: kbdhid
| | | | | Driver: kbdhid.sys, 3/1/2017 13:51:55, 28672 bytes
| | | | | Driver: kbdclass.sys, 7/16/2016 16:24:57, 47456 bytes
Gameport Devices
PS/2 Devices
| Service: kbdhid
Disk & DVD/CD-ROM Drives
      Drive: C:
 Free Space: 17.6 GB
Total Space: 28.6 GB
File System: NTFS
      Model: SanDisk DF4032
System Devices
     Name: PCI ?准主机 CPU ?
Device ID: PCI\VEN_8086&DEV_2280&SUBSYS_72708086&REV_36\3&11583659&0&00
   Driver: n/a
     Name: Qualcomm Atheros QCA61x4A Wireless Network Adapter
Device ID: PCI\VEN_168C&DEV_003E&SUBSYS_3360168C&REV_32\4&1CE6206D&0&00E0
   Driver: C:\Windows\system32\DRIVERS\Qcamain10x86.sys, 12.00.0000.0270 (English), 8/4/2016 06:24:54, 1922488 bytes
   Driver: C:\Windows\system32\DRIVERS\qca61x4_2_2.bin, 8/4/2016 06:24:54, 1087248 bytes
   Driver: C:\Windows\system32\DRIVERS\Data61x4_2_2.msc, 8/4/2016 06:24:54, 97210 bytes
   Driver: C:\Windows\system32\DRIVERS\eeprom_ar6320_3p0_NFA324i_5.bin, 7/16/2016 16:24:57, 8124 bytes
     Name: PCI Express 根端口
Device ID: PCI\VEN_8086&DEV_22C8&SUBSYS_72708086&REV_36\3&11583659&0&E0
   Driver: C:\Windows\system32\DRIVERS\pci.sys, 10.00.14393.0594 (Chinese (Simplified)), 3/1/2017 13:51:55, 261984 bytes
     Name: Intel(R) Trusted Execution Engine Interface
Device ID: PCI\VEN_8086&DEV_2298&SUBSYS_72708086&REV_36\3&11583659&0&D0
   Driver: C:\Windows\system32\DRIVERS\TXEI.sys, 2.00.0000.1094 (English), 10/14/2015 02:01:00, 132376 bytes
     Name: PCI ?准 ISA ?
Device ID: PCI\VEN_8086&DEV_229C&SUBSYS_72708086&REV_36\3&11583659&0&F8
   Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 10.00.14393.0000 (English), 7/16/2016 16:24:54, 16224 bytes
     Name: Intel(R) USB 3.0 可?展主机控制器 - 1.0 (Microsoft)
Device ID: PCI\VEN_8086&DEV_22B5&SUBSYS_72708086&REV_36\3&11583659&0&A0
   Driver: C:\Windows\system32\DRIVERS\USBXHCI.SYS, 10.00.14393.0000 (Chinese (Simplified)), 7/16/2016 16:24:57, 289120 bytes
     Name: Intel(R) Imaging Signal Processor 2401
Device ID: PCI\VEN_8086&DEV_22B8&SUBSYS_72708086&REV_36\3&11583659&0&18
   Driver: C:\Windows\system32\DRIVERS\iaisp32.sys, 1.00.0000.0001 (English), 1/28/2016 11:18:54, 33784 bytes
     Name: Intel(R) HD Graphics
Device ID: PCI\VEN_8086&DEV_22B0&SUBSYS_72708086&REV_36\3&11583659&0&10
   Driver: C:\Windows\system32\DRIVERS\igdkmd32lp.sys, 20.19.0015.4424 (English), 4/20/2016 14:15:28, 6637536 bytes
   Driver: C:\Windows\system32\igd10iumd32.dll, 20.19.0015.4424 (English), 4/20/2016 14:15:24, 11625632 bytes
   Driver: C:\Windows\system32\igd10idpp32.dll, 20.19.0015.4424 (English), 4/20/2016 14:15:24, 274504 bytes
   Driver: C:\Windows\system32\igd11dxva32.dll, 20.19.0015.4424 (English), 4/20/2016 14:15:26, 34194968 bytes
   Driver: C:\Windows\system32\igd12umd32.dll, 20.19.0015.4424 (English), 4/20/2016 14:15:28, 4123096 bytes
   Driver: C:\Windows\system32\igdumdim32.dll, 20.19.0015.4424 (English), 4/20/2016 14:15:30, 38207848 bytes
   Driver: C:\Windows\system32\igdail32.dll, 20.19.0015.4424 (English), 4/20/2016 14:15:28, 156160 bytes
   Driver: C:\Windows\system32\igfxcmrt32.dll, 5.00.0000.1148 (English), 4/20/2016 14:15:32, 140056 bytes
   Driver: C:\Windows\system32\igfx11cmrt32.dll, 5.00.0000.1148 (English), 4/20/2016 14:15:32, 140056 bytes
   Driver: C:\Windows\system32\igfxcmjit32.dll, 5.00.0000.1148 (English), 4/20/2016 14:15:32, 1161216 bytes
   Driver: C:\Windows\system32\igdde32.dll, 20.19.0015.4424 (English), 4/20/2016 14:15:28, 161192 bytes
   Driver: C:\Windows\system32\igdusc32.dll, 20.19.0015.4424 (English), 4/20/2016 14:15:32, 4958432 bytes
   Driver: C:\Windows\system32\igc32.dll, 20.19.0015.4424 (English), 4/20/2016 14:15:24, 13229360 bytes
   Driver: C:\Windows\system32\igdmd32.dll, 20.19.0015.4424 (English), 4/20/2016 14:15:28, 1421376 bytes
   Driver: C:\Windows\system32\iglhxs32lp.vp, 4/20/2016 14:15:32, 81748 bytes
   Driver: C:\Windows\system32\iglhxo32.vp, 1/7/2016 00:14:28, 40329 bytes
   Driver: C:\Windows\system32\iglhxc32.vp, 1/7/2016 00:14:28, 39602 bytes
   Driver: C:\Windows\system32\iglhxg32.vp, 1/7/2016 00:14:28, 40596 bytes
   Driver: C:\Windows\system32\iglhxo32_dev.vp, 1/7/2016 00:14:28, 40833 bytes
   Driver: C:\Windows\system32\iglhxc32_dev.vp, 1/7/2016 00:14:28, 39770 bytes
   Driver: C:\Windows\system32\iglhxg32_dev.vp, 1/7/2016 00:14:28, 41184 bytes
   Driver: C:\Windows\system32\iglhxa32.vp, 1/7/2016 00:14:28, 1125 bytes
   Driver: C:\Windows\system32\iglhxa32.cpa, 1/7/2016 00:14:28, 2108679 bytes
   Driver: C:\Windows\system32\iglhcp32.dll, 3.00.0001.0026 (English), 1/7/2016 01:06:00, 184352 bytes
   Driver: C:\Windows\system32\iglhsip32.dll, 9.00.0030.9000 (English), 1/7/2016 01:06:00, 1765408 bytes
   Driver: C:\Windows\system32\IntelCpHeciSvc.exe, 9.00.0031.9015 (English), 4/20/2016 14:15:32, 284144 bytes
   Driver: C:\Windows\system32\IntelCpHDCPSvc.exe, 1.00.0000.0001 (English), 4/20/2016 14:15:32, 461808 bytes
   Driver: C:\Windows\system32\cp_resources.bin, 1/7/2016 00:14:28, 511260 bytes
   Driver: C:\Windows\system32\igfxDH.dll, 6.15.0010.3682 (English), 4/20/2016 14:15:32, 655872 bytes
   Driver: C:\Windows\system32\igfxDHLib.dll, 1.00.0000.0000 (Invariant Language), 4/20/2016 14:15:32, 67072 bytes
   Driver: C:\Windows\system32\igfxDHLibv2_0.dll, 1.00.0000.0000 (Invariant Language), 4/20/2016 14:15:32, 77824 bytes
   Driver: C:\Windows\system32\igfxDI.dll, 6.15.0010.3682 (English), 4/20/2016 14:15:32, 352256 bytes
   Driver: C:\Windows\system32\igfxDILib.dll, 1.00.0000.0000 (Invariant Language), 4/20/2016 14:15:32, 11776 bytes
   Driver: C:\Windows\system32\igfxDILibv2_0.dll, 1.00.0000.0000 (Invariant Language), 4/20/2016 14:15:32, 11776 bytes
   Driver: C:\Windows\system32\igfxLHM.dll, 6.15.0010.3682 (English), 4/20/2016 14:15:32, 2007040 bytes
   Driver: C:\Windows\system32\igfxLHMLib.dll, 1.00.0000.0000 (Invariant Language), 4/20/2016 14:15:32, 5120 bytes
   Driver: C:\Windows\system32\igfxLHMLibv2_0.dll, 1.00.0000.0000 (Invariant Language), 4/20/2016 14:15:32, 5120 bytes
   Driver: C:\Windows\system32\igfxSDK.exe, 4/20/2016 14:15:32, 852464 bytes
   Driver: C:\Windows\system32\igfxSDKLib.dll, 1.00.0000.0000 (Invariant Language), 4/20/2016 14:15:32, 83456 bytes
   Driver: C:\Windows\system32\igfxSDKLibv2_0.dll, 1.00.0000.0000 (Invariant Language), 4/20/2016 14:15:32, 94208 bytes
   Driver: C:\Windows\system32\igfxEM.exe, 6.15.0010.3682 (English), 4/20/2016 14:15:32, 280560 bytes
   Driver: C:\Windows\system32\igfxEMLib.dll, 1.00.0000.0000 (Invariant Language), 4/20/2016 14:15:32, 10240 bytes
   Driver: C:\Windows\system32\igfxEMLibv2_0.dll, 1.00.0000.0000 (Invariant Language), 4/20/2016 14:15:32, 10240 bytes
   Driver: C:\Windows\system32\GfxUIEx.exe, 6.15.0010.3682 (English), 4/20/2016 14:15:22, 404464 bytes
   Driver: C:\Windows\system32\Gfxv4_0.exe, 8.15.0010.3682 (Chinese (Traditional)), 4/20/2016 14:15:22, 949232 bytes
   Driver: C:\Windows\system32\Gfxv4_0.exe.config, 1/7/2016 00:15:30, 935 bytes
   Driver: C:\Windows\system32\Gfxv2_0.exe, 8.15.0010.3682 (Chinese (Traditional)), 4/20/2016 14:15:22, 945136 bytes
   Driver: C:\Windows\system32\Gfxv2_0.exe.config, 1/7/2016 00:15:30, 895 bytes
   Driver: C:\Windows\system32\GfxResources.dll, 8.15.0010.3682 (Chinese (Traditional)), 4/20/2016 14:15:22, 8468992 bytes
   Driver: C:\Windows\system32\MetroIntelGenericUIFramework.dll, 1.00.0000.0000 (Chinese (Traditional)), 1/7/2016 00:15:34, 615424 bytes
   Driver: C:\Windows\system32\igfxCUIServicePS.dll, 4/20/2016 14:15:32, 80384 bytes
   Driver: C:\Windows\system32\igfxCUIService.exe, 6.15.0010.3682 (English), 4/20/2016 14:15:32, 302064 bytes
   Driver: C:\Windows\system32\igfxCPL.cpl, 4/20/2016 14:15:32, 233472 bytes
   Driver: C:\Windows\system32\igfxTray.exe, 4/20/2016 14:15:32, 407024 bytes
   Driver: C:\Windows\system32\igfxDTCM.dll, 6.15.0010.3682 (English), 4/20/2016 14:15:32, 199168 bytes
   Driver: C:\Windows\system32\igfxHK.exe, 6.15.0010.3682 (English), 4/20/2016 14:15:32, 212976 bytes
   Driver: C:\Windows\system32\igfxOSP.dll, 6.15.0010.3682 (English), 4/20/2016 14:15:32, 318976 bytes
   Driver: C:\Windows\system32\DPTopologyApp.exe, 8.15.0010.3682 (Chinese (Traditional)), 4/20/2016 14:15:22, 215536 bytes
   Driver: C:\Windows\system32\DPTopologyApp.exe.config, 1/7/2016 00:15:30, 935 bytes
   Driver: C:\Windows\system32\DPTopologyAppv2_0.exe, 8.15.0010.3682 (Chinese (Traditional)), 4/20/2016 14:15:22, 215536 bytes
   Driver: C:\Windows\system32\DPTopologyAppv2_0.exe.config, 1/7/2016 00:15:30, 895 bytes
   Driver: C:\Windows\system32\igfxext.exe, 6.15.0010.3682 (English), 4/20/2016 14:15:32, 182256 bytes
   Driver: C:\Windows\system32\igfxexps.dll, 6.15.0010.3682 (English), 4/20/2016 14:15:32, 38640 bytes
   Driver: C:\Windows\system32\ColorImageEnhancement.wmv, 1/7/2016 00:15:32, 375173 bytes
   Driver: C:\Windows\system32\ImageStabilization.wmv, 1/7/2016 00:15:32, 403671 bytes
   Driver: C:\Windows\system32\FilmModeDetection.wmv, 1/7/2016 00:15:32, 641530 bytes
   Driver: C:\Windows\system32\ig8icd32.dll, 20.19.0015.4424 (English), 4/20/2016 14:15:24, 10245120 bytes
   Driver: C:\Windows\system32\Intel_OpenCL_ICD32.dll, 2.00.0002.0000 (English), 1/7/2016 00:14:32, 86528 bytes
   Driver: C:\Windows\system32\IntelOpenCL32.dll, 20.19.0015.4424 (English), 4/20/2016 14:15:32, 301056 bytes
   Driver: C:\Program Files\Common Files\Intel\OpenCL\llvm_release_license.txt, 1/7/2016 00:15:26, 1981 bytes
   Driver: C:\Program Files\Common Files\Intel\OpenCL\readme.txt, 1/7/2016 00:15:26, 9788 bytes
   Driver: C:\Program Files\Common Files\Intel\OpenCL\version.ini, 1/7/2016 00:15:26, 34 bytes
   Driver: C:\Program Files\Common Files\Intel\OpenCL\bin\x86\task_executor32.dll, 5.02.0000.10094 (English), 1/7/2016 00:15:28, 355840 bytes
   Driver: C:\Program Files\Common Files\Intel\OpenCL\bin\x86\OclCpuBackend32.dll, 5.02.0000.10094 (English), 1/7/2016 00:15:28, 7109120 bytes
   Driver: C:\Program Files\Common Files\Intel\OpenCL\bin\x86\intelocl32.dll, 5.02.0000.10094 (English), 1/7/2016 00:15:28, 1391104 bytes
   Driver: C:\Program Files\Common Files\Intel\OpenCL\bin\x86\cpu_device32.dll, 5.02.0000.10094 (English), 1/7/2016 00:15:28, 505344 bytes
   Driver: C:\Program Files\Common Files\Intel\OpenCL\bin\x86\clbltfnn8.rtl, 1/7/2016 00:15:28, 1223604 bytes
   Driver: C:\Program Files\Common Files\Intel\OpenCL\bin\x86\clbltfnn8_img_cbk.o, 1/7/2016 00:15:28, 296664 bytes
   Driver: C:\Program Files\Common Files\Intel\OpenCL\bin\x86\clbltfnn8_img_cbk.rtl, 1/7/2016 00:15:28, 389300 bytes
   Driver: C:\Program Files\Common Files\Intel\OpenCL\bin\x86\clbltfng9.rtl, 1/7/2016 00:15:28, 1157132 bytes
   Driver: C:\Program Files\Common Files\Intel\OpenCL\bin\x86\clbltfng9_img_cbk.o, 1/7/2016 00:15:28, 287436 bytes
   Driver: C:\Program Files\Common Files\Intel\OpenCL\bin\x86\clbltfng9_img_cbk.rtl, 1/7/2016 00:15:28, 389180 bytes
   Driver: C:\Program Files\Common Files\Intel\OpenCL\bin\x86\clbltfns9.rtl, 1/7/2016 00:15:28, 785172 bytes
   Driver: C:\Program Files\Common Files\Intel\OpenCL\bin\x86\clbltfns9_img_cbk.o, 1/7/2016 00:15:28, 249992 bytes
   Driver: C:\Program Files\Common Files\Intel\OpenCL\bin\x86\clbltfns9_img_cbk.rtl, 1/7/2016 00:15:28, 350952 bytes
   Driver: C:\Program Files\Common Files\Intel\OpenCL\bin\x86\clang_compiler32.dll, 5.02.0000.10094 (English), 1/7/2016 00:15:28, 225280 bytes
   Driver: C:\Program Files\Common Files\Intel\OpenCL\bin\x86\__ocl_svml_n8.dll, 3.04.0000.0000 (English), 1/7/2016 00:15:28, 5005312 bytes
   Driver: C:\Program Files\Common Files\Intel\OpenCL\bin\x86\__ocl_svml_g9.dll, 3.04.0000.0000 (English), 1/7/2016 00:15:28, 5342720 bytes
   Driver: C:\Program Files\Common Files\Intel\OpenCL\bin\x86\__ocl_svml_s9.dll, 3.04.0000.0000 (English), 1/7/2016 00:15:28, 5220864 bytes
   Driver: C:\Program Files\Common Files\Intel\OpenCL\bin\common\clbltfnshared.rtl, 1/7/2016 00:15:26, 1026520 bytes
   Driver: C:\Program Files\Common Files\Intel\OpenCL\bin\x86\tbb\tbbmalloc.dll, 4.02.2014.0601 (Chinese (Traditional)), 1/7/2016 00:15:28, 191120 bytes
   Driver: C:\Program Files\Common Files\Intel\OpenCL\bin\x86\tbb\tbb.dll, 4.02.2014.0601 (Chinese (Traditional)), 1/7/2016 00:15:28, 342672 bytes
   Driver: C:\Program Files\Common Files\Intel\OpenCL\bin\x86\tbb\tbb_preview.dll, 4.02.2013.1002 (), 1/7/2016 00:15:28, 338576 bytes
   Driver: C:\Windows\system32\igdbcl32.dll, 20.19.0015.4424 (English), 4/20/2016 14:15:28, 371200 bytes
   Driver: C:\Windows\system32\igdrcl32.dll, 20.19.0015.4424 (English), 4/20/2016 14:15:30, 4362240 bytes
   Driver: C:\Windows\system32\common_clang32.dll, 4.00.0000.0000 (English), 8/20/2015 18:07:36, 19844096 bytes
   Driver: C:\Windows\system32\igdmcl32.dll, 20.19.0015.4424 (English), 4/20/2016 14:15:28, 3952640 bytes
   Driver: C:\Windows\system32\igdfcl32.dll, 20.19.0015.4424 (English), 4/20/2016 14:15:28, 207872 bytes
   Driver: C:\Windows\system32\igdclbif.bin, 1/7/2016 00:40:50, 5799386 bytes
   Driver: C:\Program Files\Intel\Media SDK\libmfxhw32.dll, 7.16.0003.0014 (English), 4/20/2016 14:15:34, 9219512 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfxplugin32_hw.dll, 1.16.0003.0014 (English), 4/20/2016 14:15:34, 4541080 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfx_mft_h264ve_32.dll, 7.16.0003.0015 (English), 4/20/2016 14:15:34, 1353384 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfx_mft_mjpgvd_32.dll, 7.16.0003.0015 (English), 4/20/2016 14:15:34, 1276056 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfx_mft_vp8vd_32.dll, 7.16.0003.0015 (English), 4/20/2016 14:15:34, 1283736 bytes
   Driver: C:\Program Files\Intel\Media SDK\he_32.vp, 4/20/2016 14:15:22, 53725 bytes
   Driver: C:\Program Files\Intel\Media SDK\c_32.cpa, 12/18/2015 08:51:50, 846855 bytes
   Driver: C:\Program Files\Intel\Media SDK\cpa_32.vp, 4/20/2016 14:15:22, 993 bytes
   Driver: C:\Program Files\Intel\Media SDK\dev_32.vp, 4/20/2016 14:15:22, 21523 bytes
   Driver: C:\Program Files\Intel\Media SDK\mj_32.vp, 4/20/2016 14:15:34, 49957 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfx_mft_vp9vd_32.dll, 7.16.0003.0015 (English), 4/20/2016 14:15:34, 1283736 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfx_mft_h265ve_32.dll, 7.16.0003.0015 (English), 4/20/2016 14:15:34, 1369912 bytes
   Driver: C:\Program Files\Intel\Media SDK\h265e_32.vp, 4/20/2016 14:15:22, 54957 bytes
   Driver: C:\Windows\system32\IntelWiDiMCComp32.dll, 6.05.0057.0000 (English), 1/7/2016 00:14:26, 316888 bytes
   Driver: C:\Windows\system32\IntelWiDiUMS32.exe, 6.05.0057.0000 (English), 4/20/2016 14:15:34, 501744 bytes
   Driver: C:\Windows\system32\igfxCoIn_v4424.dll, 1.03.0014.0000 (English), 4/20/2016 14:15:32, 160256 bytes
   Driver: C:\Windows\system32\DisplayAudiox86.cab, 4/20/2016 14:15:22, 735220 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,10.00.14393.0000
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,10.00.14393.0000
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,10.00.14393.0000
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,10.00.14393.0000
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,10.00.14393.0000
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,10.00.14393.0000
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,10.00.14393.0000
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,10.00.14393.0000
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,10.00.14393.0000
Acer MP4 Source 2,0x00600003,0,0,AcerMP4Splitter2.ax,
DV Muxer,0x00400000,0,0,qdv.dll,10.00.14393.0000
Color Space Converter,0x00400001,1,1,quartz.dll,10.00.14393.0000
Acer MKV Splitter,0x00600000,1,1,AcerMKVSplitter.ax,
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.14393.0000
AVI Splitter,0x00600000,1,1,quartz.dll,10.00.14393.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,10.00.14393.0000
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,10.00.14393.0000
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,10.00.14393.0594
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,10.00.14393.0000
Acer Mpeg Audio Splitter,0x00400001,1,1,AcerMpegAudioSplitter.ax,
StreamBufferSink,0x00200000,0,0,sbe.dll,10.00.14393.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,10.00.14393.0000
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,10.00.14393.0000
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,10.00.14393.0000
Acer VC1 Decoder,0x00200000,1,1,AcerVC1Decoder.ax,
VBI Codec,0x00600000,1,4,VBICodec.ax,10.00.14393.0000
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,10.00.14393.0000
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,10.00.14393.0000
SBE2FileScan,0x00200000,0,0,sbe.dll,10.00.14393.0000
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.14393.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,10.00.14393.0000
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,10.00.14393.0000
Acer Subtitle,0x00800002,2,1,AcerSubtitle.dll,
Acer MP4 Source,0x00600002,0,0,AcerMP4Splitter.ax,
DV Splitter,0x00600000,1,2,qdv.dll,10.00.14393.0000
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,10.00.14393.0000
Acer Audio Decoder,0x40000001,1,1,AcerAudioDecoder.ax,
Acer Mpeg Audio Source,0x00400001,0,0,AcerMpegAudioSplitter.ax,
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,10.00.14393.0000
ACM Wrapper,0x00600000,1,1,quartz.dll,10.00.14393.0000
Video Renderer,0x00800001,1,0,quartz.dll,10.00.14393.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,10.00.14393.0000
Line 21 Decoder,0x00600000,1,1,qdvd.dll,10.00.14393.0187
Video Port Manager,0x00600000,2,1,quartz.dll,10.00.14393.0000
Video Renderer,0x00400000,1,0,quartz.dll,10.00.14393.0000
Acer FLV Splitter,0x00800001,1,1,AcerFLVSplitter.ax,
VPS Decoder,0x00200000,0,0,WSTPager.ax,10.00.14393.0000
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.14393.0000
Acer Splitter,0x00800004,1,1,AcerSplitter.ax,
Acer MKV Source,0x00600000,0,0,AcerMKVSplitter.ax,
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,
File writer,0x00200000,1,0,qcap.dll,10.00.14393.0000
Acer Mpeg Splitter,0x00400001,1,1,AcerMpegSplitter.ax,
Acer Splitter Source,0x00800004,0,1,AcerSplitter.ax,
Acer Mpeg Source,0x00200000,0,0,AcerMpegSplitter.ax,
DVD Navigator,0x00200000,0,3,qdvd.dll,10.00.14393.0187
Acer MP4 Splitter,0x00600002,1,1,AcerMP4Splitter.ax,
Overlay Mixer2,0x00200000,1,1,qdvd.dll,10.00.14393.0187
AVI Draw,0x00600064,9,1,quartz.dll,10.00.14393.0000
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.14393.0000
WST Pager,0x00200000,1,1,WSTPager.ax,10.00.14393.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,10.00.14393.0000
DV Video Decoder,0x00800000,1,1,qdv.dll,10.00.14393.0000
SampleGrabber,0x00200000,1,1,qedit.dll,10.00.14393.0000
Null Renderer,0x00200000,1,0,qedit.dll,10.00.14393.0000
Acer Sound Photo Source,0x00400000,0,1,AcerSoundPhoto.dll,
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,10.00.14393.0000
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,10.00.14393.0206
StreamBufferSource,0x00200000,0,0,sbe.dll,10.00.14393.0000
Acer FLV Source,0x00600001,0,0,AcerFLVSplitter.ax,
Acer AMR Decoder,0x00600000,1,1,AcerAMRDecoder.ax,
Smart Tee,0x00200000,1,2,qcap.dll,10.00.14393.0000
Overlay Mixer,0x00200000,0,0,qdvd.dll,10.00.14393.0187
AVI Decompressor,0x00600000,1,1,quartz.dll,10.00.14393.0000
Acer MP4 Splitter 2,0x00600003,1,1,AcerMP4Splitter2.ax,
AVI/WAV File Source,0x00400000,0,2,quartz.dll,10.00.14393.0000
Wave Parser,0x00400000,1,1,quartz.dll,10.00.14393.0000
MIDI Parser,0x00400000,1,1,quartz.dll,10.00.14393.0000
Multi-file Parser,0x00400000,1,1,quartz.dll,10.00.14393.0000
File stream renderer,0x00400000,1,1,quartz.dll,10.00.14393.0000
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,10.00.14393.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,10.00.14393.0000
AVI Mux,0x00200000,1,0,qcap.dll,10.00.14393.0000
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,10.00.14393.0000
File Source (Async.),0x00400000,0,1,quartz.dll,10.00.14393.0000
File Source (URL),0x00400000,0,1,quartz.dll,10.00.14393.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,10.00.14393.0000
Enhanced Video Renderer,0x00200000,1,0,evr.dll,10.00.14393.0000
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,10.00.14393.0000
MPEG Video Decoder,0x40000001,1,1,quartz.dll,10.00.14393.0000
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink ??程序,0x00200000,1,1,ksproxy.ax,10.00.14393.0000
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,10.00.14393.0000
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,10.00.14393.0000
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,10.00.14393.0000
DV Video Encoder,0x00200000,0,0,qdv.dll,10.00.14393.0000
MJPEG Compressor,0x00200000,0,0,quartz.dll,10.00.14393.0000
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,10.00.14393.0000
Intel IYUV ??解?器,0x00200000,1,1,qcap.dll,10.00.14393.0000
Microsoft RLE,0x00200000,1,1,qcap.dll,10.00.14393.0000
Microsoft Video 1,0x00200000,1,1,qcap.dll,10.00.14393.0000
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,10.00.14393.0000
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,10.00.14393.0000
IMA ADPCM,0x00200000,1,1,quartz.dll,10.00.14393.0000
Microsoft ADPCM,0x00200000,1,1,quartz.dll,10.00.14393.0000
GSM 6.10,0x00200000,1,1,quartz.dll,10.00.14393.0000
CCITT A-Law,0x00200000,1,1,quartz.dll,10.00.14393.0000
CCITT u-Law,0x00200000,1,1,quartz.dll,10.00.14393.0000
MPEG Layer-3,0x00200000,1,1,quartz.dll,10.00.14393.0000
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,10.00.14393.0351
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,10.00.14393.0351
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,10.00.14393.0351
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,10.00.14393.0000
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,10.00.14393.0000
WDM Streaming Capture Devices:
,0x00000000,0,0,,
Kingcome 2M Camera,0x00200000,1,1,ksproxy.ax,10.00.14393.0000
WDM Streaming Rendering Devices:
IntelSST Audio Wave for Hdmi,0x00200000,1,1,ksproxy.ax,10.00.14393.0000
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.14393.0000
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.14393.0000
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.14393.0000
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.14393.0000
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,10.00.14393.0000
Video Capture Sources:
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,10.00.14393.0000
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,10.00.14393.0000
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,10.00.14393.0000
Encrypt/Tag,0x00200000,0,0,EncDec.dll,10.00.14393.0000
PTFilter,0x00200000,0,0,EncDec.dll,10.00.14393.0000
XDS Codec,0x00200000,0,0,EncDec.dll,10.00.14393.0000
WDM Streaming Communication Transforms:
Audio Renderers:
Acer T231H (Intel SST Audio Device (WDM)),0x00200000,1,0,quartz.dll,10.00.14393.0000
Default DirectSound Device,0x00800000,1,0,quartz.dll,10.00.14393.0000
Default WaveOut Device,0x00200000,1,0,quartz.dll,10.00.14393.0000
DirectSound: Acer T231H (Intel SST Audio Device (WDM)),0x00200000,1,0,quartz.dll,10.00.14393.0000
Preferred DirectShow Filters
[HKEY_LOCAL_MACHINE\Software\Microsoft\DirectShow\Preferred]
<media subtype GUID>, [<filter friendly name>, ]<filter CLSID>
MEDIASUBTYPE_MPEG1Payload, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_MPEG1Packet, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_DVD_LPCM_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_VIDEO, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{78766964-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_mp4s, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{6C737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64697678-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{64687664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{58564944-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{5634504D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_MP4S, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MJPG, MJPEG Decompressor, CLSID_MjpegDec
{44495658-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVA, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mpg4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_h264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_H264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_WMV3, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_MP43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMV2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS2, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_M4S2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WVP2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_WMV1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS1, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_WVC1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_AVC1, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{20637664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MPEG_LOAS, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG_ADTS_AAC, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_WMAUDIO_LOSSLESS, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_WMAUDIO3, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
WMMEDIASUBTYPE_WMAudioV8, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
WMMEDIASUBTYPE_MP3, MP3 Decoder DMO, CLSID_CMP3DecMediaObject
MEDIASUBTYPE_MPEG1AudioPayload, MPEG Audio Decoder, CLSID_CMpegAudioCodec
WMMEDIASUBTYPE_WMSP2, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
WMMEDIASUBTYPE_WMSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms]
<category>:
  <transform friendly name>, <transform CLSID>, <flags>, [<merit>, ]<file name>, <file version>
Video Decoders:
  IntelR Hardware M-JPEG Decoder MFT, {00C69F81-0524-48C0-A353-4DD9D54F9A6E}, 0x6, 7, mfx_mft_mjpgvd_32.dll, 7.16.0003.0015
  IntelR Hardware VP9 Decoder MFT, {0C69E30B-A112-4A86-B496-35120CD745D5}, 0x6, mfx_mft_vp9vd_32.dll, 7.16.0003.0015
  IntelR Hardware VP8 Decoder MFT, {6D856398-834E-4A89-8EE5-071BB3F58BE4}, 0x6, mfx_mft_vp8vd_32.dll, 7.16.0003.0015
  IntelR Hardware VP9 Sync Decoder MFT, {07AB4BD2-1979-4FCD-A697-DF9AD15B34FE}, 0x1, mfx_mft_vp9vd_32.dll, 7.16.0003.0015
  Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}, 0x1, msmpeg2vdec.dll, 10.00.14393.0594
  DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}, 0x1, mfdvdec.dll, 10.00.14393.0000
  Microsoft H265 Video Decoder MFT, {420A51A3-D605-430C-B4FC-45274FA6C562}, 0x1, hevcdecoder.dll, 10.00.14393.0479
  IntelR Hardware VP8 Sync Decoder MFT, {451E3CB7-2622-4BA5-8E1D-44B3C41D0924}, 0x1, mfx_mft_vp8vd_32.dll, 7.16.0003.0015
  Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT, 0x1, mp4sdecd.dll, 10.00.14393.0000
  Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT, 0x1, msmpeg2vdec.dll, 10.00.14393.0594
  WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject, 0x1, wmvsdecd.dll, 10.00.14393.0000
  WMVideo Decoder MFT, CLSID_CWMVDecMediaObject, 0x1, wmvdecod.dll, 10.00.14393.0000
  MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}, 0x1, mfmjpegdec.dll, 10.00.14393.0000
  Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject, 0x1, mp43decd.dll, 10.00.14393.0000
  Microsoft WebM MF VP8 Decoder Transform, {E3AAF548-C9A4-4C6E-234D-5ADA374B0000}, 0x1, MSVP9DEC.dll, 10.00.14393.0594
  WebM MF VP8 Decoder Transform, {ED311120-5211-11DF-94AF-0026B977EEAA}, 0x1, webmmfvp8dec32.dll, 1.00.0001.0002
  Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject, 0x1, mpg4decd.dll, 10.00.14393.0000
Video Encoders:
  IntelR Quick Sync Video H.264 Encoder MFT, {4BE8D3C0-0515-4A37-AD55-E4BAE19AF471}, 0x4, 7, mfx_mft_h264ve_32.dll, 7.16.0003.0015
  H264 Encoder MFT, {6CA50344-051A-4DED-9779-A43305165E35}, 0x1, mfh264enc.dll, 10.00.14393.0000
  WMVideo8 Encoder MFT, CLSID_CWMVXEncMediaObject, 0x1, wmvxencd.dll, 10.00.14393.0000
  Microsoft MF VPX Encoder Transform, {AEB6C755-2546-4881-82CC-E15AE5EBFF3D}, 0x1, MSVPXENC.dll, 10.00.14393.0206
  H263 Encoder MFT, {BC47FCFE-98A0-4F27-BB07-698AF24F2B38}, 0x1, mfh263enc.dll, 10.00.14393.0000
  WMVideo9 Encoder MFT, CLSID_CWMV9EncMediaObject, 0x1, wmvencod.dll, 10.00.14393.0000
  Microsoft MPEG-2 Video Encoder MFT, {E6335F02-80B7-4DC4-ADFA-DFE7210D20D5}, 0x2, msmpeg2enc.dll, 10.00.14393.0000
  H265 Encoder MFT, {F2F84074-8BCA-40BD-9159-E880F673DD3B}, 0x1, mfh265enc.dll, 10.00.14393.0000
Video Effects:
  Frame Rate Converter, CLSID_CFrameRateConvertDmo, 0x1, mfvdsp.dll, 10.00.14393.0000
  Resizer MFT, CLSID_CResizerDMO, 0x1, vidreszr.dll, 10.00.14393.0000
  VideoStabilization MFT, {51571744-7FE4-4FF2-A498-2DC34FF74F1B}, 0x1, MSVideoDSP.dll, 10.00.14393.0000
  Color Control, CLSID_CColorControlDmo, 0x1, mfvdsp.dll, 10.00.14393.0000
  Color Converter MFT, CLSID_CColorConvertDMO, 0x1, colorcnv.dll, 10.00.14393.0000
Video Processor:
  Microsoft Video Processor MFT, {88753B26-5B24-49BD-B2E7-0C445C78C982}, 0x1, msvproc.dll, 10.00.14393.0351
Audio Decoders:
  Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}, 0x1, DolbyDecMFT.dll, 10.00.14393.0351
  MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}, 0x1, MSAMRNBDecoder.dll, 10.00.14393.0000
  WMAudio Decoder MFT, CLSID_CWMADecMediaObject, 0x1, WMADMOD.DLL, 10.00.14393.0000
  Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT, 0x1, MSAudDecMFT.dll, 10.00.14393.0000
  A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}, 0x1, mfcore.dll, 10.00.14393.0693
  GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}, 0x1, mfcore.dll, 10.00.14393.0693
  WMAPro over S/PDIF MFT, CLSID_CWMAudioSpdTxDMO, 0x1, WMADMOD.DLL, 10.00.14393.0000
  Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}, 0x1, MSOpusDecoder.dll, 10.00.14393.0000
  Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}, 0x1, MSFlacDecoder.dll, 10.00.14393.0000
  Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}, 0x1, MSAudDecMFT.dll, 10.00.14393.0000
  WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject, 0x1, WMSPDMOD.DLL, 10.00.14393.0000
  G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}, 0x1, mfcore.dll, 10.00.14393.0693
  IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}, 0x1, mfcore.dll, 10.00.14393.0693
  MP3 Decoder MFT, CLSID_CMP3DecMediaObject, 0x1, mp3dmod.dll, 10.00.14393.0000
  Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}, 0x1, MSAlacDecoder.dll, 10.00.14393.0000
  ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}, 0x1, mfcore.dll, 10.00.14393.0693
  Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}, 0x1, mfaudiocnv.dll, 10.00.14393.0479
  DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}, 0x1, mfaudiocnv.dll, 10.00.14393.0479
  WebM MF Vorbis Decoder Transform, {ED311130-5211-11DF-94AF-0026B977EEAA}, 0x1, webmmfvorbisdec32.dll, 1.00.0001.0002
Audio Encoders:
  LPCM DVD-Audio MFT, {068A8476-9229-4CC0-9D49-2FC699DCD30A}, 0x1, mfaudiocnv.dll, 10.00.14393.0479
  MP3 Encoder ACM Wrapper MFT, {11103421-354C-4CCA-A7A3-1AFF9A5B6701}, 0x1, mfcore.dll, 10.00.14393.0693
  Microsoft FLAC Audio Encoder MFT, {128509E9-C44E-45DC-95E9-C255B8F466A6}, 0x1, MSFlacEncoder.dll, 10.00.14393.0000
  WM Speech Encoder DMO, CLSID_CWMSPEncMediaObject2, 0x1, WMSPDMOE.DLL, 10.00.14393.0000
  MS AMRNB Encoder MFT, {2FAE8AFE-04A3-423A-A814-85DB454712B0}, 0x1, MSAMRNBEncoder.dll, 10.00.14393.0000
  Microsoft MPEG-2 Audio Encoder MFT, {46A4DD5C-73F8-4304-94DF-308F760974F4}, 0x1, msmpeg2enc.dll, 10.00.14393.0000
  WMAudio Encoder MFT, CLSID_CWMAEncMediaObject, 0x1, WMADMOE.DLL, 10.00.14393.0000
  Microsoft AAC Audio Encoder MFT, {93AF0C51-2275-45D2-A35B-F2BA21CAED00}, 0x1, mfAACEnc.dll, 10.00.14393.0000
  Microsoft ALAC Audio Encoder MFT, {9AB6A28C-748E-4B6A-BFFF-CC443B8E8FB4}, 0x1, MSAlacEncoder.dll, 10.00.14393.0000
  Microsoft Dolby Digital Encoder MFT, {AC3315C9-F481-45D7-826C-0B406C1F64B8}, 0x1, msac3enc.dll, 10.00.14393.0206
Audio Effects:
  AEC, CLSID_CWMAudioAEC, 0x1, mfwmaaec.dll, 10.00.14393.0000
  Resampler MFT, CLSID_CResamplerMediaObject, 0x1, resampledmo.dll, 10.00.14393.0000
Multiplexers:
  Microsoft MPEG2 Multiplexer MFT, {AB300F71-01AB-46D2-AB6C-64906CB03258}, 0x2, mfmpeg2srcsnk.dll, 10.00.14393.0693
Others:
  Microsoft H264 Video Remux (MPEG2TSToMP4) MFT, {05A47EBB-8BF0-4CBF-AD2F-3B71D75866F5}, 0x1, msmpeg2vdec.dll, 10.00.14393.0594
  DX11 Video Renderer, {83A1FDBC-AB3A-4376-A529-80E18C206534}, 0x1, DX11VideoRenderer.dll,
Media Foundation Enabled Hardware Categories
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\HardwareMFT]
EnableEncoders = 1
EnableDecoders = 1
Media Foundation Byte Stream Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\ByteStreamHandlers]
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\Preferred]
<file ext. or MIME type>, <handler CLSID>, <brief description>[, Preferred]
.3g2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.ac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.adt, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.am?, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler
.amr, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler, Preferred
.asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
.dvr-ms, {65964407-A5D8-4060-85B0-1CCD63F768E2}, dvr-ms Byte Stream Handler, Preferred
.dvr-ms, {A8721937-E2FB-4D7A-A9EE-4EB08C890B6E}, MF SBE Source ByteStreamHandler
.ec3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
.m2t, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m2ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mk3d, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mka, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mks, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mkv, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mov, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp2v, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mpg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.nsc, {B084785C-DDE0-4D30-8CA8-05A373E185BE}, NSC Byte Stream Handler, Preferred
.sami, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.smi, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.tod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.uvu, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.vob, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
.webm, {ED311111-5211-11DF-94AF-0026B977EEAA}, WebM MF Byte-Stream Handler
.wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wtv, {65964407-A5D8-4060-85B0-1CCD63F768E2}, WTV Byte Stream Handler, Preferred
audio/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/aacp, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/eac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/L16, {3FFB3B8C-EB99-472B-8902-E1C1B05F07CF}, LPCM Byte Stream Handler, Preferred
audio/mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/MP4A-LATM, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/vnd.dlna.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/vnd.dolby.dd-raw, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
audio/webm, {ED311111-5211-11DF-94AF-0026B977EEAA}, WebM MF Byte-Stream Handler
audio/x-aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/x-m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
audio/x-mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-ms-wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
audio/x-wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
video/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/vnd.dece.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/vnd.dlna.mpeg-tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/webm, {ED311111-5211-11DF-94AF-0026B977EEAA}, WebM MF Byte-Stream Handler
video/x-m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
video/x-ms-asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
Media Foundation Scheme Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\SchemeHandlers]
<URL type>, <handler CLSID>, <brief description>[, Preferred]
file:, {477EC299-1421-4BDD-971F-7CCB933F21AD}, File Scheme Handler, Preferred
http:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler
http:, {9EC4B4F9-3029-45AD-947B-344DE2A249E2}, Urlmon Scheme Handler
http:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpd:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler, Preferred
httpnd:, {2EEEED04-0908-4CDB-AF8F-AC5B768A34C9}, Drm Scheme Handler, Preferred
https:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpsd:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcast:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcrecv:, {FA6D33D4-9405-4BA5-9983-12604AC8E77A}, Miracast Sink Scheme Handler, Preferred
mms:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
ms-appdata:, {CFC81939-3886-4ACF-9692-DA58037AE716}, MsAppData Scheme Handler, Preferred
ms-appx-web:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppxWeb Scheme Handler, Preferred
ms-appx:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppx Scheme Handler, Preferred
ms-winsoundevent:, {F79A6BF9-7415-4CF3-AE10-4559509ABC3C}, Sound Event Scheme Handler, Preferred
rtsp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
sdp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
Preferred Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\Preferred]
<media subtype GUID>, [<transform friendly name>, ]<transform CLSID>
{EB27CEC4-163E-4CA3-8B74-8E25F91B517E}, Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}
{E06D802C-DB46-11CF-B4D1-00805F6CBBEA}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFVideoFormat_MPEG2, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MEDIASUBTYPE_DOLBY_DDPLUS, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
{A2E58EB7-0FA9-48BB-A40C-FA0E156D0645}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{73616D72-767A-494D-B478-F29D25DC9037}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
MEDIASUBTYPE_mp4s, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_DVSL, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVSD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVHD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_MP4V, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{53564548-0000-0010-8000-00AA00389B71}, Microsoft H265 Video Decoder MFT, {420A51A3-D605-430C-B4FC-45274FA6C562}
MFVideoFormat_MP4S, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{53314356-0000-0010-8000-00AA00389B71}, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MJPG, MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}
{43564548-0000-0010-8000-00AA00389B71}, Microsoft H265 Video Decoder MFT, {420A51A3-D605-430C-B4FC-45274FA6C562}
MEDIASUBTYPE_WMVA, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{3F40F4F0-5622-4FF8-B6D8-A17A584BEE5E}, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MEDIASUBTYPE_mpg4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_H264, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MFVideoFormat_WMV3, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{33363248-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_mp43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MFVideoFormat_MP43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_WMV2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS2, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_M4S2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_WVP2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_WMV1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS1, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_MPG1, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MFVideoFormat_WVC1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{30395056-0000-0010-8000-00AA00389B71}, Microsoft WebM MF VP8 Decoder Transform, {E3AAF548-C9A4-4C6E-234D-5ADA374B0000}
{30385056-0000-0010-8000-00AA00389B71}, Microsoft WebM MF VP8 Decoder Transform, {E3AAF548-C9A4-4C6E-234D-5ADA374B0000}
MFVideoFormat_DVC, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{0000F1AC-0000-0010-8000-00AA00389B71}, Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}
{00007361-0000-0010-8000-00AA00389B71}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
{0000704F-0000-0010-8000-00AA00389B71}, Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}
{00006C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
{00002001-0000-0010-8000-00AA00389B71}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{00002000-0000-0010-8000-00AA00389B71}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFAudioFormat_AAC, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
{00001600-0000-0100-0800-000aa00389b71}, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_WMAudio_Lossless, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV9, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV8, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_MP3, MP3 Decoder MFT, CLSID_CMP3DecMediaObject
MFAudioFormat_MPEG, Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}
{00000031-0000-0010-8000-00AA00389B71}, GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}
{00000011-0000-0010-8000-00AA00389B71}, IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}
MFAudioFormat_MSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
KSDATAFORMAT_SUBTYPE_MULAW, G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}
{00000006-0000-0010-8000-00AA00389B71}, A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}
KSDATAFORMAT_SUBTYPE_ADPCM, ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}
Disabled Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\DoNotUse]
<transform CLSID>
Disabled Media Sources
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\DoNotUse]
<media source CLSID>
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
  Quality Flags: 2576
    Enabled:
    Force throttling
    Allow half deinterlace
    Allow scaling
    Decode Power Usage: 100
  Balanced Flags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force half deinterlace
    Force scaling
    Decode Power Usage: 50
  PowerFlags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force scaling
    Decode Power Usage: 0
