3030 Discussions
Possible hevc 10 bit HW decoding bug in current drivers
Celio_A_
Hi, i'm trying to decode and encode 10 bit HEVC using hardware on Kabylake i7 7700 processor, command line used
sample_multi_transcode -i::h265 "D:\Intel Media SDK Plugins\4K Demos\Samsung Journey Of Color 4K Demo.265" -o::h265 D:\TESTE.hevc -hw -async 10 -pe hevce_gacc -pd hevcd_hw -cqp -qpi 20 -qpp 22 -qpb 24 -u balanced -l 1 -gop_size 24 -dist 4 -num_ref 6 -bref -bpyr -ec::p010 -w 1920 -h 1080 -WeightedPred::implicit -WeightedBiPred::implicit -amfs:on -extbrc::implicit -pp
I'm on Windows 10, tryed the first media sdk driver release and the latest, both produce same problems, if i use hevc decode plugin from Media SDK 2018R1 it works perfectly but are too slow for decode > encode, i have uploaded the result hevc stream in attachment
Mark_L_Intel1
Hi Celio,
I am investigating, I did a brief test and I got an error, is it the same as yours?
Pipeline surfaces number (EncPool): 19
Pipeline surfaces number (DecPool): 16
MFX HARDWARE Session 0 API ver 1.26 parameters:
Input  video: HEVC
Output video: HEVC
MFX dll: C:\Program Files\Intel\Media SDK\libmfxhw64.dll
Session 0 was NOT joined with other sessions
Transcoding started
ERROR: No free surfaces in decoder pool (during long period)
[ERROR], sts=MFX_ERR_MEMORY_ALLOC(-4), TranscodingSample::CTranscodingPipeline::Transcode, Decode<One|Last>Frame failed at src\pipeline_transcode.cpp:1713
Transcoding finished
Common transcoding time is 20.0306 sec
*** session 0 FAILED (MFX_ERR_MEMORY_ALLOC) 20.0257 sec, 13 frames
-i::h265 SamsungJuourneyOfColor4KDemo.265 -o::h265 out.hevc -hw -async 10 -pe hevce_gacc -pd hevcd_hw -cqp -qpi 20 -qpp 22 -qpb 24 -u balanced -l 1 -gop_size 24 -dist 4 -num_ref 6 -bref -bpyr -ec::p010 -w 1920 -h 1080 -WeightedPred::implicit -WeightedBiPred::implicit -amfs:on -extbrc::implicit -pp
The test FAILED
[ERROR], sts=MFX_ERR_MEMORY_ALLOC(-4), wmain, transcode.ProcessResult failed at src\sample_multi_transcode.cpp:920
Mark
Celio_A_
No, i don't get error it simple transcode with wrong colors, like the example mentioned above, it finish sucessfully but with wrong colors, the hevcd_hw decoder don't decode correctly the 10bit sample but software hevcd_sw works with no problem, but are too slow, can u investigate further?
Mark_L_Intel1
Hi Celio,
Apologized for the long delay.
Dev team had review this issue and confirmed the issue solved.
Here are the detail if you want to check it:
  • This issue was fixed in our latest release which has integrated the hevc_hw plugin, you can run it directly or run with "-hw" argument.
  • Run directly will be successfully, run with plugin can reproduce the issue.
If you still have question, please post a new request so it can be tracked immediately.
Mark
Celio_A_
Any news about this? I tested with the latet drivers from intel site and have same problem, this will be fixed in next drivers version?
Mark_L_Intel1
Yes, I can reproduce the issue now, here is the output:
sample_multi_transcode.exe -i::h265 SamsungJuourneyOfColor4KDemo.265 -o::h265 out.hevc -hw -async 10 -pe hevce_gacc -pd hevcd_hw -cqp -qpi 20 -qpp 22 -qpb 24 -u balanced -l 1 -gop_size 24 -dist 4 -num_ref 6 -bref -bpyr -ec::p010 -w 1920 -h 1080 -WeightedPred::implicit -amfs:on -extbrc::implicit -pp
Multi Transcoding Sample Version 8.4.27.378
External allocator will be used as some cmd line paremeters request it.
Session 0:
plugin_loader.h :178 [INFO] Plugin was loaded from GUID: { 0x33, 0xa6, 0x1c, 0x0b, 0x4c, 0x27, 0x45, 0x4c, 0xa8, 0xd8, 0x5d, 0xde, 0x75, 0x7c, 0x6f, 0x8e } (Intel (R) Media SDK HW plugin for HEVC DECODE)
Preset-controlled parameters (Default):
RateControlMethod: 3 (original preset value: 2)
AdaptiveMaxFrameSize: 16 (original preset value: 0)
AsyncDepth: 10 (original preset value: 4)
BRefType: 2 (original preset value: 0)
EnableBPyramid: 1 (original preset value: 0)
GopRefDist: 4 (original preset value: 0)
IntRefCycleDist: 0
IntRefCycleSize: 0
IntRefQPDelta: 0
IntRefType: 0
LowDelayBRC: 0
TargetUsage: 4 (original preset value: 4)
WeightedBiPred: 0
WeightedPred: 3 (original preset value: 0)
GopPicSize: 24 (original preset value: 119)
MaxFrameSize: 0
LookAheadDepth: 0
plugin_loader.h :178 [INFO] Plugin was loaded from GUID: { 0xe5, 0x40, 0x0a, 0x06, 0xc7, 0x4d, 0x41, 0xf5, 0xb1, 0x2d, 0x43, 0x0b, 0xba, 0xa2, 0x3d, 0x0b } (Intel (R) Media SDK GPU-Accelerated plugin for HEVC ENCODE)
MFX HARDWARE Session 0 API ver 1.27 parameters:
Input  video: HEVC
Output video: HEVC
Transcoding started
[ERROR], sts=MFX_ERR_UNDEFINED_BEHAVIOR(-16), CSmplBitstreamWriter::WriteNextFrame, pMfxBitstream->DataLength!=nBytesWritten error at src\sample_utils.cpp:428
[ERROR], sts=MFX_ERR_UNDEFINED_BEHAVIOR(-16), TranscodingSample::CTranscodingPipeline::PutBS, m_pBSProcessor->ProcessOutputBitstream failed at src\pipeline_transcode.cpp:2051
[ERROR], sts=MFX_ERR_UNDEFINED_BEHAVIOR(-16), TranscodingSample::CTranscodingPipeline::Transcode, PutBS failed at src\pipeline_transcode.cpp:2000
Common transcoding time is 134.088 sec
*** session 0 FAILED (MFX_ERR_UNDEFINED_BEHAVIOR) 134.035 sec, 2033 frames
The test FAILED
[ERROR], sts=MFX_ERR_UNDEFINED_BEHAVIOR(-16), wmain, transcode.ProcessResult failed at src\sample_multi_transcode.cpp:948
plugin_loader.h :204 [INFO] MFXBaseUSER_UnLoad(session=0x000002025736E5E0), sts=0
The next step is to check if which component cause this problem, I will keep you updated.
Mark
Ranganadh_K_Intel
Hi
I am trying to run msdk_decode sample in ubuntu 16.04 LTS .
In the software implementation I am able to run without any issues...
but in the  Hardware implementation, I am getting the following errors
  • WARNING: Unsupported the FMO/ASO constraints!!!
  • undefined behaviour   . src/msdk_decode.cpp 160
can anybody help me in resolving this issue?
Ranganadh .K
Mark_L_Intel1
Hi Ranganadh,
Could you have a different post?
I am also not sure what command line are you using.
Mark
Mark_L_Intel1
Hi Celio,
I didn't check this issue for a while because of other project, do you still have it?
I have report this issue to dev team and I am waiting for their response.
Mark
